Call Processing Report
wkhanagov
Does anyone know of a way to create create call processing reports for a Call Manager cluster?  A high lever overview would be sufficient, i.e. total number of processed calls in a week or month.
Chris Lee
Would something like this suffice?
It's a third-party app, Variphy Insight.  Ask for a trial online from them, mention the Cisco Support Forum, and get a 90 license key for the trial instead of the nominal 15 days.
Chris Lee
Anas Abueideh
Level 9
Level 9
you can use cdr report to view the calls.
Anas
please rate if it is helpful
Sent from Cisco Technical Support Android App
