Call record details
lpritchett
I need very basic call record details like call duration and # of call for a dn. In CM 4, I could access http://cmservername/art to get a web gui. Does CM 6 have something similar?
yes, the CAR services and parameters need to be setup and running before
java
if this helps, please rate
java
Jaime Valencia
CUCM also has CAR, you can access it thru the serviceability page or
https://IP/car/Logon.jsp
java
java
the /car/logon.asp site gives me an Apache error - no page found. Also, the serviceablilty page does not give me the information I'm looking for. Is it possible I need additional features/services activated?
java
java
I had to activate the CAR web service. Thank you.
