04-28-2017 03:31 PM - edited 03-17-2019 10:11 AM
We just got our Cisco CM installed, so I am completely new to everything having come from an older Avaya system. My question is, I am trying figure out how to generate call reports for some of our managers. On our old system I could create create reports that would show our managers call detail reports for each of their employees. The reports would show (for a given date range) This employee made x number of calls, it would show the number called and the duration of the call, then it would total it at the bottom. We could schedule it to run on a given day each week and it would either be emailed or available for download to each manager.
Is there a way to do something similar with the CM system?
Thanks in advance!
04-29-2017 12:54 AM
Please configure CDR as per the following doc, its pretty easy and will give you various types of reports as per your requirement
https://supportforums.cisco.com/document/53056/understanding-cdr-call-detail-records
Manish
- Do rate helpful posts -
05-01-2017 11:29 AM
Thanks. I was able to get everything enabled per the instructions, but I cant seem to be able to schedule an "Automatic Report Generation" of a "Department Bill Detail", only "Department Bill Summary" is available for "Automatic Report Generation".
Also, is there a way to build my own reports?
