06-06-2018 11:35 AM - edited 03-17-2019 12:58 PM
Hi Guys,
Need your help for one of my customer. His phone is registered with CME and in our setup, we also have CUCM which is connected with CUBE (ITSP trunk). CUCM and CME are integrated via SIP trunk. By this setup, we are able to make calls from CME to CUCM and vice-versa. Now the user has a request that he wants to dial 1800XXXXXXX pattern from CME that has to go through CUCM via CUBE as a PSTN call.
So it is possible to do. If so then can you please let me know how can I achieve this.
Raj
06-06-2018 01:19 PM - edited 06-06-2018 08:26 PM
Hi there
How about configuring a dial-peer in CME pointing 1800XXXXXXX to a dummy number in CUCM (say 6161). Create a Route Pattern in CUCM forwarding to 1800XXXXXXX thru your CUBE.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
06-06-2018 04:06 PM
First, figure out exactly how they want to dial to know how to configure this.
Then, configure a DP in CME pointing to CUCM as they wish to dial.
In CUCM make sure there is a RP to match what they want to dial.
Make sure the inbound CSS of the SIP trunk to CME can reach the required RP.
If required, do digit manipulation as necessary in your system(s)
06-07-2018 09:32 AM
Hi Jaime,
I have already created the dial peer and route pattern that should route through CUBE
Dial peer in CME:
dial-peer voice 708 voip
description Outgoing call to SIP trunk
preference 1
destination-pattern 91800.......
session protocol sipv2
session target ipv4:<CUCM_IP>
dtmf-relay sip-notify rtp-nte
codec g711ulaw
Route pattern:
9.1800XXXXXXX --> RL --> RG --> SIP trunk (CUBE).
But the dial peer which I created it not taking. Instead, it is taking the dial peer of destination-pattern 900T.
dial-peer voice 59 pots
trunkgroup PSTN-TRUNK
description **CCA*International**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE ( rule 1 /^9/ //)
preference 5
forward-digits all
no sip-register
Please guide me
Raj
06-07-2018 11:18 AM
Can you get debugs for a failed call? I'm not seeing how it would hunt to that other dial peer.
debug ccsip message
debug voip ccapi inout
Thanks!
06-11-2018 12:13 PM
Please find the attachment which is debug output (debug voip ccapi inout). Also I have given the details about calling and called number and the dial peer which is getting triggered
Calling number: 104
Called number: 918005532447
preference 5
forward-digits all
no sip-register
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-rule 1112
rule 1 /^9/ //
Raj
06-11-2018 12:49 PM
Can you send the current configuration?
The debugs show only 1 then 8 dialed and then it errors out: (Digit collect failed).
Should you be dialing a 9 first?
06-11-2018 01:56 PM
Yes, we are dialing as 918005532447 and don't know why it is taken the pattern 900T. This is the logs which were pulled at the time of testing.
Raj
06-11-2018 03:31 PM
06-13-2018 06:37 AM
06-13-2018 07:33 AM
06-07-2018 04:16 AM
