Highlighted
Beginner
Call routing issue
Our provider change our did numbers range we have configured it on router and it working fine but the issue is we requested Provider to forward old call to new numbers call is landing to gateway but not destination
Channel ID i = 0xA9838E
                Exclusive, Channel 14
*Feb  9 07:31:06.842: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3A77
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x2180, '2133133840'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '3118452946'
                Plan:ISDN, Type:Subscriber(local)
*Feb  9 07:31:07.030: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xBA77
*Feb  9 07:31:07.034: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xBA77
        Cause i = 0x8281 - Unallocated/unassigned number
*Feb  9 07:31:07.034: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x3A77
*Feb  9 07:31:07.210: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xBA77
*Feb  9 07:31:07.214: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x93C9
        Cause i = 0x8081 - Unallocated/unassigned number
*Feb  9 07:31:07.394: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x13C9
*Feb  9 07:31:07.394: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x93C9
*Feb  9 07:31:11.590: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0xBA76
        Progress Ind i = 0x8284 - Call has returned to the ISDN
        Date/Time i = 0x1202090C2B13
                Date (dd-mm-yr)   = 18-02-09
                Time (hr:mnt:sec) = 12:43:19
*Feb  9 07:31:11.590: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x3A76
1 ACCEPTED SOLUTION
VIP Rising star
Re: Call routing issue
You should voip dial-peers (identical to 300,400,500,600) that would route the range that number 3118452946 is part of. Of-course, at the destination platform (eg 192.168.33.4) you should add the proper translation (you can look what you do for the 2133142[8-9].. range), so that 3118452946 is translated to some internal extension.
Georgios
Please rate if you find this helpful.
5 REPLIES 5
VIP Rising star
Is 3118452946 the old number? If yes, then you can use a translation-profile (or even num-exp) to convert that number to one of your internal extensions and route accordingly.
Georgios
Beginner
Yes can you please explain
VIP Rising star
How do you currently route your new DID range? Also, where does it end up to; CUCM, CME? Can you explain what the exact call route is?
Georgios
Beginner
Translation rule on CUCM configuration as below
Current configuration : 3680 bytes
! Last configuration change at 07:30:41 UTC Fri Feb 9 2018 by cisco
version 15.4
service password-encryption
hostname HC-PRI
boot-start-marker
boot-end-marker
card type e1 0 0
card type e1 0 1
enable secret 5 $1$TIC/$1Y9WwccdTa9x7txj/2.Sm0
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/0/0
ip dhcp excluded-address x.x.x.x x.x.x.x
ip dhcp pool IPT-HC-Voice
network x.x.x.x x.x.x.x
default-router x.x.x.x
domain-name dibpak.com
ip domain name dibpak.com
ip cef
no ipv6 cef
isdn switch-type primary-net5
cts logging verbose
voice-card 0
voice service voip
ip address trusted list
  ipv4 x.x.x.x x.x.x.x
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice iec syslog
voice statistics type iec
license udi pid CISCO2901/K9 sn FGL19352319
hw-module pvdm 0/0
hw-module pvdm 0/1
username admin password 7 045A0F0B062F
username cisco privilege 15 secret 5 $1$Gk8v$kKFiEIyilwgMWJKRBoHyy/
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/1/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address x.x.x.x x.x.x.x
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr x.x.x.x
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/1/0:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route x.x.x.x x.x.x.x
control-plane
voice-port 0/0/0:15
voice-port 0/1/0:15
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 200 pots
incoming called-number 311845[2-3]...
port 0/0/0:15
dial-peer voice 100 pots
destination-pattern .T
port 0/0/0:15
dial-peer voice 300 voip
destination-pattern 2133142[8-9]..
session target ipv4:192.168.33.4
codec g711ulaw
dial-peer voice 400 voip
destination-pattern 21331430..
dial-peer voice 500 voip
preference 1
session target ipv4:x.x.x.x
dial-peer voice 600 voip
preference 1
dial-peer voice 101 pots
destination-pattern 0T
port 0/0/0:15
dial-peer voice 2901 pots
destination-pattern 2901
port 0/3/0
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
line vty 5 15
login local
transport input none
scheduler allocate 20000 1000
VIP Rising star
Georgios
Content for Community-Ad
August's Community Spotlight Awards
