12-12-2011 11:36 PM - edited 03-16-2019 08:30 AM
Hi @ All,
we got a design problem with ucm 8.5.
A user (A) want to divert to the secretary (B) and when B don't answer the call should go to voicemail of A.
How can we realize this?
We have dealed with hunt pilot, but we can't access the Mailbox of A, even when the phone is directly diverted to the mailbox, the phone rings when you call the hunt pilot and not the mailbox.
Any hint out there?
Thx in advance!
Sven
12-13-2011 12:54 AM
while I realize this may not be the best way, or maybe even desired way, but how about using phone b as single number reach end point for phone a then configure the ring to ring phone b till just before phone a voicemail picks up?
12-13-2011 01:08 AM
Thats a hint I'll give a try.
Complex, but nice if it works.
I'll let you know about the result.
Thank you!
Sven
12-13-2011 01:13 AM
Hi again,
I will research on my end as I had a customer have this exact request for their executives a couple of years ago. I'll see what we ended up doing to close the ticket.
12-13-2011 05:58 AM
First results after some testing:
By now we only can access external numbers with remote destination no internal......
Maybe a wrong hook somewhere?...?...?
But the idea with the remote destination was good.
Sven
12-15-2011 03:31 PM
Your set up should work
Caller A rings user B
User B has cfna to User C
User C has cfna to vm
Normally caller A should be sent to User B VM. - check the forward settings in the service params. Is your vm a unity box?
12-15-2011 11:18 PM
No you missunderstod me.
The goal is to reach the vm of A.
12-15-2011 09:42 PM
You could set up a second line on the secretary's phone that forwards to voicemail for User A.
12-15-2011 11:22 PM
Yea, that's what we did.
Shared line of A on phone B.
If there noboy picks up vm of A answer.
Sometimes the simple way is the easiest
Never the less I'm very interested in the solution of dschlicht!
Sven
