10-25-2010 01:53 PM - edited 03-16-2019 01:32 AM
I'm having a issue when trying to make calls through a gatekeeper from CUCM.
The scenario is the following:
CUCM->ICTrunk->Gatekeper->another CUCMEs and CUCMs
When I try to make a call through the gatekeeper for an unknown number (i dont want to configure arq reject-unknown-prefix), the call setup lasts about 70 seconds and then return fast busy. I want to have fast busy immediately.(if i configure arq reject-unknown-prefix it works, but i need to solve the problem without this command on GK).
Log in CUCM shows this, several times for each failed call:
10/25/2010 18:15:39.460 CCM|DRQ Billing Information - DISCONNECT_REASON=2,TIME=1288026869,DURATION=70,DISCONNECT_STRING=switch congestion,ORIGIN=1,LINE_NUMBER=gtk01_ICTH225,OUTBOUND_GW_IP=<cucm_ip>
10/25/2010 18:15:39.534 CCM|ConnectionManager - wait_AuDisconnectRequest ERROR:NO ENTRY FOUND IN TABLE,CI(44412509,44412510),dcType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
Is there any parameter or workaround for this problem?
thank you
met.
Solved! Go to Solution.
10-26-2010 07:02 AM
Hi Met,
Well its not up to the CCM to stop it unless u can ensure very explicit/tight
route patterns so that call doesn't even hit the GK.
GK behavior is going to be as mentioned in the previous post. It will try
to find a GW in the source zone and likely route it to the EP/GW that is
being used for default tech prefix.
HTH,
DK
10-25-2010 08:04 PM
Hi Met,
In short, it sounds like its working as intended/designed.
I am assuming that dialed digits presented in ARQ to the GK in this case does not match
with any configured zone prefix?
If that's the case then configuring arq reject-unknown-prefix CLI will cause GK to immediately
reject such calls. In the absence of this command, for the calls where dialed digits does not
match any known zone prefix, the gatekeeper will attempt to hairpin the call out through a
local gateway
http://www.cisco.com/en/US/docs/routers/access/as5300/software/notes/0042gk.html#wp7440
Can u pull GK debugs (deb h225 asn1, deb gatek main 10) with and without this CLI and check
if it returns ARJ (with CLI) and ACF (without) ?
HTH,
DK
10-26-2010 02:56 AM
Hello Dilip,
Yes, you are completely right and that works that way, I tested.
The million dollar question is...If I don't use arq reject-unknown-prefix, can CUCM deal with it to stop the H.225 setup immediately instead of staying about 1 minute with silence?
Thanks!
10-26-2010 07:02 AM
Hi Met,
HTH,
DK
10-26-2010 08:04 AM
Thank you my friend, guess it's really better to use arq reject-unknown-prefix on GK.
+5!
rgds!
