I have users that are reporting it is taking 9+ seconds for calls to be set up. Before going down this rabbit hole, I was wondering if there is an easy way to get this information through RTMT? Or will it be best to pull this information out of a SIP trace?
I assume you are referring to outgoing calls from CUCM. Most probably you have overlapping route/translation patterns. Look, first, into Call Routing -> Route Plan Report for overlapping patterns.
Georgios Please rate if you find this helpful.
