Call signaling issue
HamzaD
I have a CUCM V11 connected to a PBX System using a VG.
The calls from and to the two systems works fine, the problem is the following:
-when calling from the IP phones registered to the CUCM to the PBX system the call works but I didn't get the ring back tone neither the caller name on my IP Phone.
-when calling from PBX System to the CUCM I get no audio (I can't hear anything) only one way.
I am a beginner and I know that the problem is probably in the voice gateway!
Any help would be much appreciated.
Thank you all.
5 Replies 5
silvervoip
Can you please confirm below flow?
IP Phone --> (SIP or SCCP ? ) --> CUCM --> (MGCP/SIP/H323 ?) --> Voice Gateway
Model of VG?
IOS code of VG?
Thanks.
Model of VG?
IOS code of VG?
Thanks.
Sorry for the delay.
IP Phones: SIP
H.323 Gateway:
Cisco 2811
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(15)T9,
Configuration of the Cisco Gateway:
sh run
Building configuration...
Current configuration : 4304 bytes
hostname CCO-VG-01
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 4096
aaa new-model
aaa authentication login defu local
aaa session-id common
network-clock-participate wic 0
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp pool srst
   network 192.168.3.0 255.255.255.0
   option 150 ip 192.168.27.1
   default-router 192.168.27.50
isdn switch-type primary-qsig
voice-card 0
 no dspfarm
voice class h323 1
 h225 timeout tcp establish 3
crypto pki trustpoint TP-self-signed-1473155935
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1473155935
 revocation-check none
 rsakeypair TP-self-signed-1473155935
archive
 log config
  hidekeys
controller E1 0/0/0
 pri-group timeslots 1-31
controller E1 0/0/1
 framing NO-CRC4
interface FastEthernet0/0
 description CONNECTED TO CORE SWITCH
 ip address 192.168.27.50 255.255.255.0
 duplex auto
 speed auto
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 192.168.27.50
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 logging event nfas-status
 logging event subif-link-status
 isdn timer T310 60000
 isdn overlap-receiving
 isdn protocol-emulate network
 isdn incoming-voice voice
 isdn send-alerting
 no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.27.251
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
logging 192.168.29.210
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 0/0/0:15
dial-peer voice 100 voip
 tone ringback alert-no-PI
 preference 2
 destination-pattern 4...$
 voice-class h323 1
 session target ipv4:192.168.27.1
 dtmf-relay h245-alphanumeric
 ip qos dscp cs5 media
dial-peer voice 101 voip
 preference 3
 session target ipv4:192.168.27.2
dial-peer voice 1 pots
 destination-pattern .T
 direct-inward-dial
 port 0/0/0:15
 forward-digits all
dial-peer voice 4123 voip
 preference 1
 destination-pattern 4123$
 no vad
dial-peer voice 120 voip
 shutdown
 destination-pattern 45..$
 voice-class h323 1
 session target ipv4:192.168.123.187
 no vad
dial-peer voice 200 voip
 preference 4
 destination-pattern [5-7,9]...$
 voice-class h323 1
 session target ipv4:172.16.255.2
dial-peer voice 201 voip
 preference 5
 session target ipv4:172.16.255.1
dial-peer voice 211 voip
 destination-pattern 4501$
dial-peer voice 212 voip
 preference 1
call-manager-fallback
 max-conferences 4 gain -6
 transfer-system full-consult
 ip source-address 192.168.27.50 port 2000
 max-ephones 30
 max-dn 30
 time-zone 25
 time-format 24
 date-format dd-mm-yy
privilege exec level 2 show
privilege exec level 2 debug
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 privilege level 15
 login authentication defu
 transport input telnet ssh
line vty 5 15
 privilege level 15
line vty 16 515
scheduler allocate 20000 1000
end
What is the model of your pbx? Have you checked the documentation for integrating it to cucm? There may be specific configuration required which the documentation may point out.
One way audio is usually related to IP connectivity. We need to see where your media is terminated and then check if your phones have IP connectivity to the IP address..
You can do tests call and attach the following debug. Note they need to be enabled together
debug h225 asn1
debug h245 asn1
debug VoIP ccapi inout
Please rate all useful posts
-when calling from the IP phones registered to the CUCM to the PBX system the call works but I didn't get the ring back tone neither the caller name on my IP Phone. >> you need to check from the PBX.
-when calling from PBX System to the CUCM I get no audio (I can't hear anything) only one way.>>> add route on PBX to IP Phone network
Response Signature
For ringback you may need the following in your outbound pots dial peer.
progress_ind alert enable 8
