Call terminates when timer expires
We have SIP Trunk that is connected to the CUBE  ( cisco router as a voice gateway). I created SIP Trunk from CUCM to the voice gateway. I also configured translation pattern in order to redirect my incoming calls to the UCCX, but it did not work. But if I configure the translation pattern to redirect the calls to specific directory number that is registered in CUCM it works. I checked the Cisco Real Time Monitoring tool and it says that the session has been expired as attached below.
How can the expiry timer be changed and how can I find the root cause? Should I have to change CUCM configuration or CUBE?
HARIS_HUSSAIN
To redirect the call to UCCX, Make sure UCCX is registered to CUCM via CTI Port i.e APplication trigger configured in UCCX with a valid script. Then you can just configure call forwarding to the CTI Port.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Thank you for your response.
CTI route point is registered and and has been applied to an application and I can dial the trigger number locally, but it does not execute while placing from out side.
HARIS_HUSSAIN
Haris
