01-29-2012 08:49 PM - edited 03-16-2019 09:17 AM
We are using CUCM7.1(3), and try to integrate a fax server in the CUCM, call flow like this Fax server->CUCM trunk->h323 gateway->fax machine
When we do the debug isdn q931, we can see the call was setup, but after a while(around 10 seconds), the call was dropped. it seems that the far end(fax machine) send the disconnect request, please see the message
ISDN Se 0/0/1:15 Q931: RX<-DISCONNECT pd=8 callref = 0x9393
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
ISDN Se 0/0/1:15 Q931: call_disc: PI received in disconnect; Postpone Sending RELEASE for callid 0xE0ED
If I make a call to the fax number using IP phone, there is no problem at all, the call will be released until I hang up the phone
Thank you in advance
01-29-2012 09:26 PM
If you are a Cisco Partner, you can email your queries to Cisco_Fax_Server@external.cisco.com .
Pls rate helpful posts.
GP.
01-30-2012 02:40 PM
unfortunately we are not Cisco partner, any other suggestion regarding this issue
01-30-2012 02:58 PM
Can you provide your GW config and version?
Did you configure it as T.38 fax protocol?
Chris
01-31-2012 02:19 PM
Guys
Thank you for your suggestions, after I untick the option "Media Termination Point Required" in the h323 trunk between fax server and CUCM, it started to work
