Call to PSTN required PIN SIP Phones
aelankoud
Hi Experts,
All IP Phones configured by SIP Protocol, for call security I want if someone wants to start a call to the outside (PSTN) he's obliged to enter his own PIN, Is there a way to configure that on CME 11.0 ?
thank you.
8 Replies 8
Brandon Buffin
You can use Forced Authorization Codes.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmefac.html
Brandon
Hi Brandon,
thank you for your quickly reply.
I have already configured this feature (FAC), but it doesn't work, when I start a call to PSTN, the IP Phone doesn't ask me the PIN, Here is the config :
voice lpcor enable
voice lpcor custom
 group 1 INTERNE
 group 2 FIX-NATIONAL
 group 3 FIX-GSM-NATIONAL
voice lpcor policy INTERNE
voice lpcor policy FIX-NATIONAL
 accept INTERNE fac
 accept FIX-NATIONAL fac
 service fac
voice lpcor policy FIX-GSM-NATIONAL
 accept INTERNE fac
 service fac
voice register pool  31
 busy-trigger-per-button 2
 id mac 70D3.7946.53F5
 type 7821
 number 1 dn 47
 cor incoming FIX-GSM-NATIONAL default
 cor outgoing FIX-GSM-NATIONAL default
 dtmf-relay rtp-nte
 voice-class codec 100
 username 1031 password cisco
 pin 1111
 no vad
 dial-peer voice 20 pots
 description ## the Calls to PSTN (FIX, GSM, Green Numbers) ##
 destination-pattern 0[5-8]........
 progress_ind setup enable 3
 progress_ind alert enable 8
 no digit-strip
 direct-inward-dial
 port 0/1/0:15
 forward-digits all
thank you.
Youssef.
Do you have the auth package configured such as:
application
package auth
 param passwd-prompt flash:en_bacd_welcome.au
 param passwd 54321
 param user-prompt flash:en_bacd_enter_dest.au
 param term-digit #
 param abort-digit *
 param max-digits 32
Do you have the username password configured such as:
username 786 password 0 54321
See the configuration example here:
This configuration that you gave me is for a single PIN Code
I want every IP Phone has its PIN Code, 50 PIN Codes for 50 IP Phones
thank you again.
Youssef.
So you would need 50 usernames/passwords:
username 787 password 0 98765
username 789 password 0 12345
One solution would be to make the usernames match extensions.
thank you,
But in this one will encounter another problem, each user can make calls from each IP Phone to the outside (PSTN).
I would like every user can just make PSTN calls, only by his phone or by his number.
And how I can download the audios (en_bacd_enter_dest.au, en_bacd_welcome.au), I have not found it in Cisco website
Youssef.
Hello
Did you find a solution for this problem please
Best regards
zineb
Hello
Best regards
