call tracing / troubleshooting on CUCM
carl_townshend
Hi All
Can anyone tell me if the call manager logs calls for troubleshooting etc?
What troubleshooting can be done on CUCM?
has anyone got a cheatsheet of some sort?
cheers
timspiller
You should be able to view/export the information you are looking for by using CDR.
By default CDR should be enabled on CUCM. You can verify the service is running by accessing the Cisco Unified Serviceability Page on your CUCM Server. Once you are there, click on - Tools > Control Center > Feature Services > Look for CDR Services and make sure both of the following "Cisco SOAP" and "CAR" are started and activated.
You can navigate to CDR by following the following menu path - Tools > CDR Analysis and Reporting > Once the page has loaded, click on "CDR" at the top menu pane. > From here you can search CDR records or export them.
Also, here are the (CDR) Call Detail Records Field Descriptions. - https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/11_0_1/cdrdef/CUCM_BK_RFDE0054_00_cucm-cdr-administration-guide-1101/cisco_call_detail_records_field_descriptions.pdf
If this helps, please mark helpful.
Tim
miket
Level 5
Level 5
If you search on Callmanager troubleshooting there are some great explainations on log locations packet capture etc. It is a great link that branches out and should answer all your questions
Here is one link https://community.cisco.com/t5/collaboration-voice-and-video/understanding-cucm-traces-end-to-end/ta-p/3161800
miket
Level 5
Level 5
George Sotiropoulos
I would also strongly suggest Real-Time-Monitoring-Tool for advanced troubleshooting, not only for CDR but also for phone registration and CUCM services (amongst others).
Attached you will find the Admistration Guide for the RTMT :
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/9_1_1/rtmt/CUCM_BK_C54E214A_00_cisco-unified-rtmt-administration-91/CUCM_BK_C54E214A_00_cisco-unified-rtmt-administration-91_chapter_01.html
You may find a lot of info within Community about the RTMT
George
Hope the above helps,
gsotirop
