Call Transfer between SIP and SCCP on CME
James Hawkins
Collaborator
Collaborator
I am configuring a CME 7.1 system to which both SCCP and SIP phones are registered - the SIP phones are DECT cordess phones but are seen as 7960 phones as CME.
When I make a call from a SIP phone to an SCCP phone the call works but when I then try to transfer the call to another SIP phone I get reorder tone.
Is there anything I need to do to enable these types of transfer?
Jaime Valencia
Have you already configured the appropriate transfer-pattern to allow the calls between SCCP and SIP?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
12 Replies 12
Jaime Valencia
java
java
Thanks Java - problem solved
I have the same scenario and the same issue. I can´t transfer calls from my SIP phone to my SCCP phones. I´ve already configured the correct transfer-patter under telephony-service. What else do I need to do?
regards,
Felipe
Hi Felipe,
have you found a solution to this problem?
i am facing the same problem. Call transfers from sip to sccp phones fail.
Thenk you in advance
Yes, I´ve found a solution. I could not found a way to attach my configuration, so please check bellow.
RT_Matriz
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.08.14 15:51:12 =~=~=~=~=~=~=~=~=~=~=~=
show run
Building configuration...
Current configuration : 7466 bytes
! Last configuration change at 11:46:20 GMT-3 Tue Aug 14 2012 by cisco
version 15.1
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
hostname RT_Matriz
boot-start-marker
boot system flash0 flash0:c2900-universalk9-mz.SPA.151-3.T3.bin
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization console
aaa authorization exec default local
aaa session-id common
clock timezone GMT-3 -3 0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1 10.10.10.20
ip dhcp excluded-address 10.10.10.254
ip dhcp excluded-address 10.10.20.254
ip dhcp excluded-address 10.10.20.1 10.10.20.10
ip dhcp excluded-address 10.10.30.254
ip dhcp excluded-address 10.10.30.1 10.10.30.10
ip dhcp pool LABLYNC
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.254
   domain-name lanlink.com.br
   dns-server 10.10.10.1
ip dhcp pool LABLYNC-vlan20
   network 10.10.20.0 255.255.255.0
   default-router 10.10.20.254
ip dhcp pool LABLYNC-vlan30
   network 10.10.30.0 255.255.255.0
   default-router 10.10.30.254
no ip domain lookup
ip domain name lanlink.com.br
ip name-server 10.10.10.1
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/2
  bind media source-interface GigabitEthernet0/2
  registrar server expires max 36000 min 600
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
codec preference 4 g711alaw
voice class h323 1
  h225 timeout tcp establish 0
voice register global
mode cme
source-address 10.10.10.254 port 5060
max-dn 10
max-pool 10
timezone 17
time-format 24
hold-alert
tftp-path flash:
create profile sync 0003325632230674
voice register dn  1
number 9156
name Felipe
label Felipe
voice register dn  2
number 9111
name Lucas
label Lucas
voice register dn  3
number 9123
name David
label David
voice register template  1
voice register pool  1
id mac 0026.9EB7.4192
number 1 dn 1
template 1
dtmf-relay rtp-nte sip-notify
voice-class codec 1
username 9156 password cisco
voice register pool  2
id mac 3C4A.924B.0A80
number 1 dn 2
template 1
voice-class codec 1
username 9111 password cisco
voice register pool  3
id mac 0026.2DFA.16C7
number 1 dn 3
template 1
voice-class codec 1
username 9123 password cisco
voice translation-rule 1000
rule 1 /^71../ /687393255/
rule 2 /^72../ /687393255/
voice translation-rule 2000
rule 1 /^04000..../ /687393255/
voice translation-rule 4000
rule 1 /\(^80..\)/ /+3466\1/
voice translation-rule 4001
rule 1 /\(^73..\)/ /+4000\1/
voice translation-profile LYNC_FILIAL
translate called 4001
voice translation-profile LYNC_MATRIZ
translate called 4000
voice translation-profile LYNC_MATRIZ_REROUTE
translate called 2000
voice translation-profile PSTN
translate called 1000
license udi pid CISCO2921/K9 sn FTX1615AL86
hw-module pvdm 0/0
username cisco privilege 15 password 0 cisco
redundancy
ip ftp username anonymous
ip ftp password t@123.com
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 200.200.200.1 255.255.255.252
duplex auto
speed auto
ip address 10.10.10.254 255.255.255.0
duplex auto
speed auto
router eigrp 10
network 10.10.10.0 0.0.0.255
network 200.200.200.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 10.10.20.0 255.255.255.0 10.10.10.253
control-plane
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory answer dualtone
soft-offhook
cptone BR
timeouts initial 1
timeouts call-disconnect 3
timeouts wait-release 3
connection plar opx 9056
description celular 085-8893-1099
station-id name Interface Celular Matriz
station-id number 8588931099
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
mgcp profile default
sccp local GigabitEthernet0/2
sccp ccm 10.10.10.254 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/2
associate ccm 1 priority 1
associate profile 1 register CME-TRANSC
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 2
associate application SCCP
dial-peer voice 100 voip
destination-pattern 71..
session target ipv4:10.71.1.254
voice-class h323 1
dial-peer voice 101 voip
destination-pattern 72..
voice-class h323 1
dial-peer voice 300 pots
destination-pattern 6[789].......
port 0/0/0
forward-digits 8
dial-peer voice 200 pots
translation-profile outgoing PSTN
preference 1
port 0/0/0
dial-peer voice 201 pots
preference 1
port 0/0/0
dial-peer voice 408 voip
translation-profile outgoing LYNC_MATRIZ
destination-pattern 80..
session protocol sipv2
session target ipv4:10.10.10.5:5068
session transport tcp
codec g711ulaw
dial-peer voice 409 voip
translation-profile outgoing LYNC_FILIAL
destination-pattern 73..
session target ipv4:10.71.1.10:5068
codec g711ulaw
dial-peer voice 301 pots
destination-pattern 0[34].......
port 0/0/0
forward-digits 8
dial-peer voice 302 pots
destination-pattern 00800.......
port 0/0/0
forward-digits 11
dial-peer voice 407 voip
translation-profile incoming LYNC_MATRIZ_REROUTE
incoming called-number 04000....
codec g711ulaw
gateway
timer receive-rtp 1200
gatekeeper
shutdown
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 2
sdspfarm tag 1 CME-TRANSC
no auto-reg-ephone
em logout 0:0 0:0 0:0
max-ephones 10
max-dn 10
ip source-address 10.10.10.254 port 2000
time-zone 17
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Aug 14 2012 09:00:45
ephone-dn  1
number 9056
label Felipe
name Felipe
ephone-dn  2
number 9011
label Lucas
name Lucas
ephone-dn  3
number 9023
label David
name David
ephone  1
mac-address 0026.9EB7.4192
button  1:1
ephone  2
mac-address 3C4A.924B.0A80
button  1:2
ephone  3
mac-address 0026.2DFA.16C7
button  1:3
banner login ^C
***      Roteador Matriz      ***
^C
line con 0
line aux 0
line vty 0 1
exec-timeout 1440 0
transport input all
line vty 2 4
transport input all
scheduler allocate 20000 1000
ntp server 200.200.200.1
end
RT_Matriz#exit
RT_Filial
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.08.14 15:52:06 =~=~=~=~=~=~=~=~=~=~=~=
show run
RT_Filial#show running-config
Current configuration : 6474 bytes
! Last configuration change at 11:14:19 GMT-3 Tue Aug 14 2012 by cisco
! NVRAM config last updated at 11:14:21 GMT-3 Tue Aug 14 2012 by cisco
version 15.1
service password-encryption
hostname RT_Filial
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.151-3.T3.bin
boot-end-marker
aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.71.1.254
   network 10.71.1.0 255.255.255.0
   default-router 10.71.1.254
   dns-server 10.71.1.10
no ip domain lookup
voice-card 0
dspfarm
voice service voip
sip
voice class codec 1
voice class h323 1
  h225 timeout tcp establish 2
mode cme
source-address 10.71.1.254 port 5060
max-dn 10
max-pool 10
timezone 17
time-format 24
hold-alert
tftp-path flash:
create profile sync 0003743326498813
voice register dn  1
number 7256
name Felipe-SSA
label Felipe-SSA
voice register dn  2
number 7211
name Lucas-SSA
label Lucas-SSA
voice register dn  3
number 7223
name David-SSA
label David
number 1 dn 1
template 1
voice-class codec 1
username 7256 password cisco
number 1 dn 2
template 1
voice-class codec 1
username 7211 password cisco
number 1 dn 3
template 1
voice-class codec 1
username 7223 password cisco
rule 1 /^03466..../ /688931099/
voice translation-profile LYNC_FILIAL_REROUTE
license udi pid CISCO2921/K9 sn FTX1615AL8H
hw-module pvdm 0/0
username cisco privilege 15 password 7 01100F175804
redundancy
no ip address
shutdown
duplex auto
speed auto
ip address 200.200.200.2 255.255.255.252
duplex auto
speed auto
ip address 10.71.1.254 255.255.255.0
duplex auto
speed auto
router eigrp 10
network 10.71.1.0 0.0.0.255
no ip http server
control-plane
voice-port 0/0/0
soft-offhook
cptone BR
timeouts initial 1
connection plar opx 7156
description celular 085-8739-3255
station-id name Interface Celular Filial
station-id number 8587393255
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
sccp ccm 10.71.1.254 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 2
destination-pattern 90..
session target ipv4:10.10.10.254
destination-pattern 91..
dtmf-relay rtp-nte
codec g711ulaw
codec g711ulaw
port 0/0/0
forward-digits 8
port 0/0/0
forward-digits 8
port 0/0/0
forward-digits 11
translation-profile incoming LYNC_FILIAL_REROUTE
incoming called-number 03466....
codec g711ulaw
gatekeeper
shutdown
telephony-service
sdspfarm units 5
no auto-reg-ephone
max-ephones 10
max-dn 10
ip source-address 10.71.1.254 port 2000
time-zone 17
time-format 24
create cnf-files version-stamp 7960 Aug 14 2012 09:00:10
ephone-dn  1
number 7156
label Felipe-SSA
name Felipe-SSA
ephone-dn  2
number 7111
label Lucas-SSA
name Lucas-SSA
ephone-dn  3
number 7123
label David
name David-SSA
ephone  1
button  1:1
ephone  2
button  1:2
ephone  3
button  1:3
banner login ^C
***      Roteador Filial
^C
line con 0
line aux 0
line vty 0 1
exec-timeout 1440 0
transport input all
line vty 2 4
transport input all
ntp server 200.20.186.76
end
RT_Filial#exit
Hi Felipe,
What exactly have you done to resolve the issue with the call transfer? I've looked at the Show Run output but could't find any changes..
Omni
I just want to make sure regarding transfer-patterns .
- having SIP trunks terminating on CME 8.6
- my SCCP extention is 311
- and SIP extension is 411
I can call from SIP to SCCP and vice versa as well. but the issue is if someone called in and SCCP answer the call, it then cannot transfer to SIP user.
Current configuration is:
   transfer-pattern .T
what could be the issue.
Thank you.
Zeeshan
Update IOS and check again.
Thank you for your reply.
Current situation:
RAM: 786 MB
Cisco router C2811: 15.1(4) M5    (C2800NM-ADVIPSERVICESK9-M)
CME Version 8.6
Are you suggesting to upgrade router IOS only or CME verison as well?
cheers
zeeshan
Probably it would not change anything.
Take "debug ccsip message" with "term mon" for a failed call transfer.
Zeeshan.  Try this:no supplementary-service sip refer
Hi Yousaf,
Thank you for your suggestion and it really helped me in resolving the issue.
For SIP Trunks terminating on CME, the above given command is essiential to disable the default behavior of referin to SIP proxy and now i can transfer incoming calls from SCCP to SIP clients.
really appreciate you guys.
regards,
Zeeshan
