05-13-2021 09:45 AM
CUCM/Unity 12.5
I have a Unity call handler that is configure to play a greeting and then transfer the caller to extension 1234.
When the transfer takes place, I can see on my display that I'm ringing to extension 1234.
How can I mask that so I will not see the 1234 number or have it change to a different number like 5678?
Solved! Go to Solution.
05-13-2021 10:44 AM
I don't want the calling party to see the number the are being transferred to. Otherwise they may note the number and start calling it directly and bypassing Unity. Anyway, I figured it out.
Connected Party Transformations is the trick. I have unity transferring to a translation pattern that transforms to the number I ultimately want to reach. Restricting "connected party transformations" on the translation pattern will display the word "private" rather than 1234.
05-13-2021 10:39 AM
when some one call 1234 it should show that its ringing 1234. what's the use case ?
05-13-2021 10:44 AM
