The way we have call transfer recall feature in CME. Is it this feature supported in CUCM version 8.6. As per the feature guide i could find hold revision feature. but not the call transfer recall.
As per the below mentioned support community link this configuration is not possible:
https://supportforums.cisco.com/thread/2120107
Albina Shaikh
And the thread is correct, if you do a blind transfer, you lose control of the call.
Only when doing a supervised transfer if the other end doesn't answer, you can resume the call.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
