Call Transfer Recall in CUCM 8.6
albinashaikh
The way we have call transfer recall feature in CME. Is it this feature supported in CUCM version 8.6. As per the feature guide i could find hold revision feature. but not the call transfer recall.
As per the below mentioned support community link this configuration is not possible:
https://supportforums.cisco.com/thread/2120107
Albina Shaikh
Jaime Valencia
And the thread is correct, if you do a blind transfer, you lose control of the call.
Only when doing a supervised transfer if the other end doesn't answer, you can resume the call.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
