Call transfert fail
florentgoue
I really need help.
We need help for trasfering an incoming call on the trunk SIP of the CME.
We set up a SIP trunk with the ITSP.
Nothing happens when you want to transfer a active call received by the switchboard operator to an internal extension.
the call remains on hold and is interrupted after pressing the tranfer button on the phone.
we have cisco 8845 and CME 12.6
Thx
9 Replies 9
Gregory Brunn
Can you post your configuration and ddebug ccsip message of your transfer attempt.
Hi Gegory
this is the config file
! Last configuration change at 00:02:11 UTC Mon Jun 24 2019 by admin
! NVRAM config last updated at 00:02:14 UTC Mon Jun 24 2019 by admin
version 16.11
service call-home
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname XXXXX
boot-start-marker
boot system flash isr4300-universalk9.16.11.01a.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging buffered 1000000
enable password XXXXX#
no aaa new-model
call-home
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
ip name-server 192.168.1.1 8.8.8.8
ip dhcp excluded-address 192.168.10.151 192.168.10.254
ip dhcp excluded-address 192.168.20.201 192.168.20.254
ip dhcp pool DATA
network 192.168.10.0 255.255.255.0
dns-server 192.168.1.1 8.8.8.8
default-router 192.168.10.254
lease 7
ip dhcp pool VOIX
network 192.168.20.0 255.255.255.0
default-router 192.168.20.254
option 150 ip 192.168.20.254
lease 5
login on-success log
subscriber templating
password encryption aes
isdn switch-type basic-ni
voice service voip
ip address trusted list
ipv4 10.203.0.0 255.255.0.0
ipv4 192.168.10.0 255.255.255.0
ipv4 192.168.1.0 255.255.255.0
dtmf-interworking rtp-nte
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
sip-profiles 1
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g722-64
codec preference 4 g729r8
voice class sip-profiles 1
request ANY sip-header SIP-Req-URI modify "xxx.ci:5060" "xxx.ci"
request ANY sip-header From modify "florent" "21598453"
request ANY sip-header From modify "goue" "21598450"
voice register global
mode cme
source-address 192.168.20.254 port 5060
max-dn 20
max-pool 20
load 8845 sip8845_65.11-2-3MSR1-1
authenticate realm 192.168.20.254
timezone 22
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0095600088106302
auto-register
voice register dn 1
number 800
allow watch
name florent
voice register dn 2
number 801
allow watch
name goue
voice register dialplan 1
voice register pool 1
busy-trigger-per-button 5
id mac 34F8.E76C.FA5E
type 8845
number 1 dn 1
dialplan 1
voice-class codec 1
username cisco password 6 FQEHQ\MSBLQdGV[XP\SGIBdL\D[KPadc`AAB
description florent
video
blf-speed-dial 2 801 label "goue"
voice register pool 2
busy-trigger-per-button 2
id mac CC70.ED34.034A
type 8845
number 1 dn 2
voice-class codec 1
username 801 password 6 JEifZe]KMTBgfU^OcIaE\fLcHSWSHSFMFAAB
description goue
call-forward b2bua busy 800
video
blf-speed-dial 2 800 label "florent"
voice translation-rule 1
rule 1 /800/ /21598450/
rule 2 /801/ /521598451/
voice translation-rule 2
rule 1 /.21598450/ /800/
rule 2 /.21598451/ /801/
voice translation-profile SDA-ORANGE-IN
translate called 2
voice translation-profile SDA-ORANGE-OUT
translate calling 1
voice-card 0/1
no watchdog
voice-card 0/4
no watchdog
license udi pid ISR4321/K9 sn FDO22222MWX
license accept end user agreement
diagnostic bootup level minimal
memory free low-watermark processor 75392
username admin privilege 15 secret 5 $1$o/fj$3MSkVt9usRIUGZUvet9Qc.
redundancy
mode none
interface GigabitEthernet0/0/0
description IP PHONE PORT
no ip address
negotiation auto
interface GigabitEthernet0/0/0.10
description Int-DATA
encapsulation dot1Q 10
ip address 192.168.10.254 255.255.255.0
ip nat inside
interface GigabitEthernet0/0/0.20
description Int-VOIX
encapsulation dot1Q 20
ip address 192.168.20.254 255.255.255.0
interface GigabitEthernet0/0/0.30
description Int-GESTION
encapsulation dot1Q 30
ip address 192.168.30.254 255.255.255.0
interface GigabitEthernet0/0/1
description INTERNET
ip address 192.168.1.254 255.255.255.0
ip nat outside
negotiation auto
interface Service-Engine0/1/4
interface Service-Engine0/4/0
vrf forwarding Mgmt-intf
no ip address
negotiation auto
interface BRI0/1/0:0
no ip address
isdn point-to-point-setup
isdn spid1 0
isdn spid2 0
isdn incoming-voice voice
isdn send-alerting
interface BRI0/1/1:0
interface BRI0/1/2:0
interface BRI0/1/3:0
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip tftp source-interface GigabitEthernet0/0/1
ip nat inside source list 1 interface GigabitEthernet0/0/1 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip ssh version 2
ip access-list standard 1
permit 192.168.10.0 0.0.0.255
dialer dnis group 1
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
telephony-service
encrypt password
max-conferences 8 gain -6
transfer-system full-consult
dial-peer cor custom
dial-peer voice 1 voip
description APPELS-SORTANTS
translation-profile outgoing SDA-ORANGE-OUT
destination-pattern ..T
session protocol sipv2
session target ipv4:10.203.5.137
session transport udp
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
voice-class sip early-offer forced
no voice-class sip pass-thru headers
no voice-class sip pass-thru content unsupp
no voice-class sip pass-thru content sdp
voice-class sip audio forced
dtmf-relay rtp-nte
no vad
dial-peer voice 2 voip
description APPELS ENTRANTS
translation-profile incoming SDA-ORANGE-IN
session target sip-server
incoming called-number 215984..
voice-class codec 1
presence
presence call-list
max-subscription 120
sip-ua
credentials number xxxx username xxxxx password 6 OBRNdELcXE\NZ^eOD`UbFUCRETPGaQeMiAAB realm xxxx
authentication username xxxx password 6 ][A`bOaUiRPa_GUKHOFO]C^GNQIE\LBOVAAB realm xxxx
no remote-party-id
retry invite 10
retry response 4
retry bye 1
retry register 10
timers trying 1000
timers expires 360000
timers connect 100
timers buffer-invite 500
registrar dns:xxxx expires 300
sip-server dns:xxxx
presence enable
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
ntp server pool.ntp.org
cns dhcp
wsma dhcp
end
Post your debug as well please
this is the debug log:
the caller numb is: 08305302
Content-Length: 0
Nov 21 11:58:02.123: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 11:58:02.127: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 11:58:02.128: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 11:58:02.128: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 11:58:02.129: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 11:58:02.130: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 11:58:02.134: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
There are no outstanding NOTIFY's
Nov 21 11:58:02.135: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 11:58:02.138: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:58:02.138: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 11:58:02.145: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:58:02.146: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 11:58:02.146: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:801@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK1d5bd658
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e100f59d93c09-6fad918d
To: <sip:801@192.168.20.254>;tag=4A6F54E1-BF8
Call-ID: 34f8e76c-fa5e06dd-75914939-58f736f7@192.168.20.14
Session-ID: 2494497900105000a00034f8e76cfa5e;remote=00000000000000000000000000000000
Date: Thu, 21 Nov 2019 11:58:01 GMT
CSeq: 1001 SUBSCRIBE
User-Agent: Cisco-CP8845/12.1.1
Event: presence
Accept: application/cpim-pidf+xml
Expires: 0
Max-Forwards: 70
Contact: <sip:267FD-2@192.168.20.14:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP34F8E76CFA5E"
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 0
Nov 21 11:58:02.147: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 11:58:02.148: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 11:58:02.148: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 11:58:02.150: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:805@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK1ec9bb9c
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e100c448e6580-3628836e
To: <sip:805@192.168.20.254>;tag=4A6F5239-14A5
Call-ID: 34f8e76c-fa5e06db-23adda6b-4816f7dc@192.168.20.14
Event: presence
Expires: 0
Max-Forwards: 70
Content-Length: 0
Nov 21 11:58:02.151: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 11:58:02.152: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 11:58:02.152: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 11:58:02.158: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:804@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK7670e6dd
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e1007122a52a9-315033ab
To: <sip:804@192.168.20.254>;tag=4A6F521B-17DC
Call-ID: 34f8e76c-fa5e06d6-0c430661-1bee3b00@192.168.20.14
Event: presence
Expires: 0
Max-Forwards: 70
Content-Length: 0
Nov 21 11:58:02.158: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 11:58:02.159: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 11:58:02.160: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 11:58:02.163: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:58:02.163: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 11:58:02.171: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:58:02.171: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 11:58:02.174: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:58:02.174: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 11:58:05.647: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:8@192.168.20.254;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK2b2a622c
From: "DIANE DOUAYE" <sip:800@192.168.20.254>;tag=34f8e76cfa5e10052db06d98-152d4169
To: <sip:8@192.168.20.254>
Call-ID: 34f8e76c-fa5e006a-255e3903-73beec19@192.168.20.14
Max-Forwards: 70
Session-ID: 2b0bacb000105000a00034f8e76cfa5e;remote=7f1a623900105000a000a093510fc10b
Date: Thu, 21 Nov 2019 11:58:05 GMT
CSeq: 101 CANCEL
Content-Length: 0
Nov 21 11:58:05.648: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Nov 21 11:58:05.649: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Nov 21 11:58:05.649: //120719/0064C53B94AC/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 21 11:58:05.649: //120719/0064C53B94AC/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:487, container:7FC70E9F6C88
Nov 21 11:58:05.650: //120719/0064C53B94AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Session-ID: 7f1a623900105000a000a093510fc10b;remote=2b0bacb000105000a00034f8e76cfa5e
Content-Length: 0
Nov 21 11:58:05.650: //120721/0064C53B94AC/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:804@192.168.20.7:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.254:5060;branch=z9hG4bK2023F924
From: "21598450" <sip:800@obusiness.ci>;tag=4A6F5645-FE5
To: <sip:804@192.168.20.7>
Date: Thu, 21 Nov 2019 11:58:02 GMT
Call-ID: D206B0-B8D11EA-94B3908E-D4685DC2@192.168.20.254
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1574337485
Reason: Q.850;cause=16
Session-ID: 2b0bacb000105000a00034f8e76cfa5e;remote=00000000000000000000000000000000
Content-Length: 0
Nov 21 11:58:05.651: //120719/0064C53B94AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 487 Request Cancelled
To: <sip:8@192.168.20.254>;tag=4A6F5692-129C
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-16.11.1a
Content-Length: 0
Nov 21 11:58:05.654: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIRemoveBranchName:
invalid ccb, bName or branch list for sipSPIRemoveBranchName
Nov 21 11:58:05.654: //120721/0064C53B94AC/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <sip:804@192.168.20.7>;tag=a093510fc10b0bd902e8ec8e-6fb0d1c1
Date: Thu, 21 Nov 2019 11:58:12 GMT
CSeq: 101 CANCEL
Server: Cisco-CP8845/12.0.1
Content-Length: 0
Nov 21 11:58:05.654: //120721/0064C53B94AC/SIP/Error/sipSPIDestroyRtpSession:
SRTP session not destroyed id: 218959117l
Nov 21 11:58:05.655: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:8@192.168.20.254;user=phone SIP/2.0
Session-ID: 2494497900105000a00034f8e76cfa5e;remote=2b0bacb000105000a00034f8e76cfa5e
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Nov 21 11:58:05.656: //120719/0064C53B94AC/SIP/Error/sipSPIDestroyRtpSession:
Nov 21 11:58:05.656: //120719/0064C53B94AC/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x7FC706673070
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 800
Called Number : 804
Source IP Address (Sig ): 192.168.20.254
Destn SIP Req Addr:Port : 192.168.20.14:5060
Destn SIP Resp Addr:Port : 192.168.20.14:5060
Destination Name : 192.168.20.14
Nov 21 11:58:05.656: //120719/0064C53B94AC/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 2
Media Stream : 1
Negotiated Codec : g711alaw
Negotiated Codec Bytes : 160
Nego. Codec payload : 8 (tx), 8 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.20.254
Source IP Port (Media): 9638
Destn IP Address (Media): 192.168.20.14
Destn IP Port (Media): 29322
Orig Destn IP Address:Port (Media): [ - ]:0
Nov 21 11:58:05.657: //120719/0064C53B94AC/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 2
Negotiated Codec : h264
Negotiated Codec Bytes : 0
Nego. Codec payload : 100 (tx), 97 (rx)
Source IP Port (Media): 9640
Destn IP Port (Media): 18498
Nov 21 11:58:05.657: //120719/0064C53B94AC/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 487
Nov 21 11:58:05.657: //120719/0064C53B94AC/SIP/Error/sipSPIFlushDeferredQueue:
Invalid deferredQueue
Nov 21 11:58:05.658: //120721/0064C53B94AC/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Contact: <sip:26814-6AF@192.168.20.7:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEPA093510FC10B";video
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "MOULAYE MOHAMEIDOU" <sip:804@192.168.20.254>;party=called;id-type=subscriber;privacy=off;screen=yes
Allow-Events: kpml,dialog
Content-Length: 0
Nov 21 11:58:05.659: //120721/0064C53B94AC/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7FC706698028
Called Number : 804
Destn SIP Req Addr:Port : 192.168.20.7:5060
Destn SIP Resp Addr:Port : 192.168.20.7:5060
Destination Name : 192.168.20.7
Nov 21 11:58:05.659: //120721/0064C53B94AC/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Negotiated Codec : No Codec
Nego. Codec payload : 255 (tx), 255 (rx)
Source IP Port (Media): 9642
Destn IP Address (Media): -
Destn IP Port (Media): 0
Media Stream : 2
Source IP Port (Media): 9644
Nov 21 11:58:05.659: //120721/0064C53B94AC/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:804@192.168.20.7:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Nov 21 11:58:06.038: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:800@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.7:5060;branch=z9hG4bK0b2eaacd
From: <sip:804@192.168.20.7>;tag=a093510fc10b0bda014dc8a7-4435771c
To: <sip:800@192.168.20.254>
Call-ID: a093510f-c10b039b-0369467a-625f4d81@192.168.20.7
Session-ID: 7c1e09b400105000a000a093510fc10b;remote=00000000000000000000000000000000
Date: Thu, 21 Nov 2019 11:58:13 GMT
CSeq: 1000 SUBSCRIBE
User-Agent: Cisco-CP8845/12.0.1
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 21 11:58:06.040: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 11:58:06.040: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.7:5060;branch=z9hG4bK161d67ef
From: <sip:804@192.168.20.7>;tag=a093510fc10b0bdb3decc60f-08208a54
Call-ID: a093510f-c10b039c-0eb5805d-3d321824@192.168.20.7
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 21 11:58:06.042: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 11:58:06.043: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 11:58:06.044: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Invalid parameters
Nov 21 11:58:06.050: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:08007779@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.7:5060;branch=z9hG4bK3ef93992
From: <sip:804@192.168.20.7>;tag=a093510fc10b0bdc31f63478-1bef0ef2
To: <sip:08007779@192.168.20.254>
Call-ID: a093510f-c10b039d-5b25d3c5-22b7fcdb@192.168.20.7
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 21 11:58:06.051: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 11:58:06.052: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 11:58:06.053: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 11:58:06.057: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:52474789@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.7:5060;branch=z9hG4bK52533ffd
From: <sip:804@192.168.20.7>;tag=a093510fc10b0bdd63a135be-08708a3e
To: <sip:52474789@192.168.20.254>
Call-ID: a093510f-c10b039e-5a3845a0-611e13fc@192.168.20.7
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 21 11:58:06.059: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 11:58:06.059: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:21598450@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.7:5060;branch=z9hG4bK47f1c21b
From: <sip:804@192.168.20.7>;tag=a093510fc10b0bde2665df5f-48d75fe1
To: <sip:21598450@192.168.20.254>
Call-ID: a093510f-c10b039f-70e11dad-5c0fe11d@192.168.20.7
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 21 11:58:06.062: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 11:58:06.063: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.7:5060;branch=z9hG4bK05a7d42f
From: <sip:804@192.168.20.7>;tag=a093510fc10b0bdf73ca0a3b-4bc0b2de
Call-ID: a093510f-c10b03a0-56f175ec-4056cdb1@192.168.20.7
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 21 11:58:06.065: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 11:58:06.066: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 11:58:06.067: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Invalid parameters
Nov 21 11:58:06.068: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 11:58:06.070: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:58:06.073: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:58:06.075: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:58:06.075: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 11:58:06.083: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:58:06.083: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 11:58:06.086: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:58:06.087: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 11:58:06.088: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:58:32.702: //120715/EF63BD4894A5/SIP/Error/act_sent_mid_invite_expire_timeout:
Expires timeout occurred.
Nov 21 11:58:32.702: //-1/xxxxxxxxxxxx/SIP/Error/sipAppGetHeader:
Corrupted/Freed Container=0x0
Nov 21 11:58:32.702: //120715/EF63BD4894A5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 21 11:58:32.702: //120715/EF63BD4894A5/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:408, container:0
Nov 21 11:58:32.702: //120715/EF63BD4894A5/SIP/Error/Session-Timer/sipSTSLMain: Null Container
Nov 21 11:58:32.702: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG:
No Inbound Container Created !!!
Nov 21 11:58:32.702: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931:
Nov 21 11:58:32.702: //120715/EF63BD4894A5/SIP/Error/sipSPI_ipip_ExtractAndAddPassthruCopyListDataToContainer:
Container is NULL
Nov 21 11:58:32.705: //120716/EF63BD4894A5/SIP/Error/sipSPIUpdateRtpSession:
voip_rtp_update_callinfo returns FALSE
Nov 21 11:58:32.705: //120715/EF63BD4894A5/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:08305302@10.203.5.137:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.1.254:5060;branch=z9hG4bK2024E19C1
From: <sip:+22521598450@10.203.5.137:5060;transport=udp;user=phone>;tag=4A6EE449-12E
To: "08305302"<tel:08305302;phone-context=+225>;tag=sbc0402zapxp3aa-CC-6
Date: Thu, 21 Nov 2019 11:58:00 GMT
Call-ID: asbcai3rxh2xlv3alxpzivz8h8lrgh82iz1p@ATS.cocats01.ims.orange.ci.6
User-Agent: Cisco-SIPGateway/IOS-16.11.1a
Max-Forwards: 70
Route: <sip:10.203.5.137:5060;transport=udp;lr>
Timestamp: 1574337512
CSeq: 102 BYE
Reason: Q.850;cause=86
Session-ID: 0c18eda100105000a00034f8e76cfa5e;remote=64f55fc4250f584a8d8acad3dfdd98ed
Content-Length: 0
Nov 21 11:58:32.706: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Nov 21 11:58:32.708: //120716/EF63BD4894A5/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:267FD-2@192.168.20.14:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.20.254:5060;branch=z9hG4bK2024F3AE
From: "08305302" <sip:08305302@obusiness.ci>;tag=4A6EE411-83B
To: <sip:800@192.168.20.14>;tag=34f8e76cfa5e100404ccae38-545a3487
Call-ID: EF64CE42-B8C11EA-94AB908E-D4685DC2@192.168.20.254
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=102
Session-ID: 64f55fc4250f584a8d8acad3dfdd98ed;remote=0c18eda100105000a00034f8e76cfa5e
Content-Length: 0
Nov 21 11:58:32.715: //120716/EF63BD4894A5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Thu, 21 Nov 2019 11:58:32 GMT
CSeq: 102 BYE
Server: Cisco-CP8845/12.1.1
Content-Length: 0
Nov 21 11:58:32.716: //120716/EF63BD4894A5/SIP/Error/sipSPIDestroyRtpSession:
Nov 21 11:58:32.716: //120716/EF63BD4894A5/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7FC7066A6CD8
Calling Number : 08305302
Called Number : 800
Nov 21 11:58:32.716: //120716/EF63BD4894A5/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 9632
Destn IP Port (Media): 17410
Media Stream : 2
Source IP Port (Media): 9634
Destn IP Port (Media): 25958
Disconnect Cause (CC) : 102
Disconnect Cause (SIP) : 200
Nov 21 11:58:32.717: //120716/EF63BD4894A5/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 11:58:32.718: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 11:58:32.718: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 11:58:32.738: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:58:32.831: //120715/EF63BD4894A5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.254:60538;branch=z9hG4bK2024E19C1
CSeq: 102 BYE
Content-Length: 0
Nov 21 11:58:32.831: //120715/EF63BD4894A5/SIP/Error/sipSPIDestroyRtpSession:
Nov 21 11:58:32.832: //120715/EF63BD4894A5/SIP/Error/sipSPIDestroyRtpSession:
Nov 21 11:58:32.832: //120715/EF63BD4894A5/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7FC706689378
Called Number : +22521598450
Source IP Address (Sig ): 192.168.1.254
Destn SIP Req Addr:Port : 10.203.5.137:5060
Destn SIP Resp Addr:Port : 10.203.5.137:5060
Destination Name : 10.203.5.137
Nov 21 11:58:32.832: //120715/EF63BD4894A5/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Address (Media): 192.168.1.254
Source IP Port (Media): 9630
Destn IP Address (Media): 10.203.3.137
Destn IP Port (Media): 24356
Media Stream : 2
Source IP Port (Media): 9636
Disconnect Cause (CC) : 86
Nov 21 11:58:32.832: //120715/EF63BD4894A5/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 11:58:37.660: //120721/0064C53B94AC/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 11:58:42.840: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 11:58:42.841: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 11:58:42.847: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
Nov 21 11:58:44.521: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 11:58:44.521: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 11:58:44.526: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 11:58:44.541: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 11:58:44.581: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 11:59:17.401: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 11:59:17.401: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 11:59:17.407: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:59:17.408: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 11:59:17.416: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.7:5060;branch=z9hG4bK2403e3da
From: <sip:804@192.168.20.7>;tag=a093510fc10b0be07c196e4e-41a49658
Call-ID: a093510f-c10b03a1-49dd4b4c-7f82b4c8@192.168.20.7
Date: Thu, 21 Nov 2019 11:59:24 GMT
Event: presence
Expires: 2147483647
Max-Forwards: 70
Content-Length: 0
Nov 21 11:59:17.417: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 11:59:17.418: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 11:59:17.418: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 11:59:17.424: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 11:59:17.964: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 11:59:17.964: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 11:59:17.970: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 11:59:19.820: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 11:59:19.820: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 11:59:19.825: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 11:59:19.861: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 11:59:20.541: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 11:59:20.541: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 11:59:20.546: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 11:59:21.490: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 11:59:21.490: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 11:59:21.496: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 11:59:22.208: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:808@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.8:5060;branch=z9hG4bK46ac94e1
From: <sip:807@192.168.20.8>;tag=7001b577f2340c21494ac4cf-1415558c
To: <sip:808@192.168.20.254>;tag=4A3BC828-C6F
Call-ID: 7001b577-f23403db-5032c5e6-3f4e3da8@192.168.20.8
Session-ID: 5411147d00105000a0007001b577f234;remote=00000000000000000000000000000000
Date: Thu, 21 Nov 2019 11:59:30 GMT
Event: presence
Expires: 2147483647
Max-Forwards: 70
Contact: <sip:26822-141D@192.168.20.8:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP7001B577F234"
Content-Length: 0
Nov 21 11:59:22.209: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 11:59:22.210: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 11:59:22.211: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 11:59:22.215: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 12:00:06.636: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.5:5060;branch=z9hG4bK11268351
From: <sip:802@192.168.20.254>;tag=cc70ed34188c0dd4727946be-3679dde8
To: <sip:802@192.168.20.254>
Call-ID: cc70ed34-188c0039-1be59280-3fc0d432@192.168.20.5
Max-Forwards: 70
Session-ID: da3bbf6400105000a000cc70ed34188c;remote=00000000000000000000000000000000
Date: Thu, 21 Nov 2019 11:59:58 GMT
CSeq: 2199 REGISTER
Contact: <sip:2680A-170C@192.168.20.5:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-cc70ed34188c>";+u.sip!devicename.ccm.cisco.com="SEPCC70ED34188C";+u.sip!model.ccm.cisco.com="36224";video
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Content-Length: 0
Expires: 3600
Nov 21 12:00:06.637: //120732/4B17B0EE94B4/SIP/Event/sact_idle_new_message_register:
ccsip_api_register_ind return value : SIP_SUCCESS
Nov 21 12:00:06.637: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Nov 21 12:00:06.638: //120732/4B17B0EE94B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:802@192.168.20.254>;tag=4A713D05-26D
Date: Thu, 21 Nov 2019 12:00:06 GMT
CSeq: 2199 REGISTER
Supported: X-cisco-cme-sis-9.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:802@192.168.20.5:5060>;expires=600
Expires: 600
Content-Length: 0
Nov 21 12:00:30.296: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.9:5060;branch=z9hG4bK43df506c
From: <sip:806@192.168.20.254>;tag=cc70ed3418680bed3d9725a1-186f30ee
To: <sip:806@192.168.20.254>
Call-ID: cc70ed34-18680002-2297a169-1c8d0ea4@192.168.20.9
Max-Forwards: 70
Session-ID: 258e186e00105000a000cc70ed341868;remote=00000000000000000000000000000000
Date: Thu, 21 Nov 2019 12:00:27 GMT
CSeq: 2198 REGISTER
Contact: <sip:2681D-2697@192.168.20.9:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-cc70ed341868>";+u.sip!devicename.ccm.cisco.com="SEPCC70ED341868";+u.sip!model.ccm.cisco.com="36224";video
Content-Length: 0
Expires: 3600
Nov 21 12:00:30.297: //120733/593213D994B5/SIP/Event/sact_idle_new_message_register:
Nov 21 12:00:30.298: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Nov 21 12:00:30.298: //120733/593213D994B5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:806@192.168.20.254>;tag=4A719972-62E
Date: Thu, 21 Nov 2019 12:00:30 GMT
CSeq: 2198 REGISTER
Contact: <sip:806@192.168.20.9:5060>;expires=600
Expires: 600
Content-Length: 0
Nov 21 12:00:34.071: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:00:34.071: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:00:34.078: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:00:34.260: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:+22521598450@obusiness.ci SIP/2.0
Via: SIP/2.0/UDP 10.203.5.137:5060;branch=z9hG4bKgwte3dtdde01wvgogkkz111ykT09662
Record-Route: <sip:10.203.5.137:5060;transport=udp;lr>
Call-ID: asbcpahpavhjpgzjhlzx0hagl8jjxlg02xap@19500.0.ATS.cocats01.ims.orange.ci.6
From: <sip:+22521598450@obusiness.ci>;tag=sbc04072giphxi2-CC-6
To: <sip:+22521598450@obusiness.ci>
CSeq: 1 NOTIFY
Contact: <sip:+22521598450@10.203.5.137:5060>
Max-Forwards: 69
Event: ua-profile
Subscription-State: active
P-Called-Party-ID: <sip:+22521598450@obusiness.ci>
Content-Length: 758
Content-Type: application/simservs+xml
<?xml version="1.0" encoding="UTF-8"?>
<ss:simservs xmlns:ss="http://uri.etsi.org/ngn/params/xml/simservs/xcap" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<ss:dial-tone-management>
<ss:dial-tone-pattern>standard-dial-tone</ss:dial-tone-pattern>
<ss:mcid-service>mcid-service-withdrawn</ss:mcid-service>
<ss:no-dialling-behaviour>rejectCall</ss:no-dialling-behaviour>
<ss:hold-service>hold-service-withdrawn</ss:hold-service>
<ss:toggle-service>toggle-service-withdrawn</ss:toggle-service>
<ss:three-pty-service>three-pty-service-provisioned</ss:three-pty-service>
<ss:cw-service>cw-service-withdrawn</ss:cw-service>
<ss:tp-service>tp-service-withdrawn</ss:tp-service>
</ss:dial-tone-management>
</ss:simservs>
Nov 21 12:00:34.262: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Nov 21 12:00:34.262: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 12:00:34.411: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK1a1ec148
From: <sip:800@192.168.20.254>;tag=34f8e76cfa5e101161ea3bd8-54f23f0a
Call-ID: 34f8e76c-fa5e0002-44df6bbb-56294a6d@192.168.20.14
Max-Forwards: 70
Date: Thu, 21 Nov 2019 12:00:34 GMT
CSeq: 2198 REGISTER
Contact: <sip:267FD-2@192.168.20.14:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-34f8e76cfa5e>";+u.sip!devicename.ccm.cisco.com="SEP34F8E76CFA5E";+u.sip!model.ccm.cisco.com="36224";video
Content-Length: 0
Expires: 3600
Nov 21 12:00:34.412: //120735/5BA5D2AE94B6/SIP/Event/sact_idle_new_message_register:
Nov 21 12:00:34.412: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Nov 21 12:00:34.413: //120735/5BA5D2AE94B6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:800@192.168.20.254>;tag=4A71A985-15B2
CSeq: 2198 REGISTER
Contact: <sip:800@192.168.20.14:5060>;expires=600
Expires: 600
Content-Length: 0
Nov 21 12:00:38.014: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.6:5060;branch=z9hG4bK60da4f5f
From: <sip:808@192.168.20.254>;tag=703509b485700b8159b6f284-429fcc31
Call-ID: 703509b4-85700002-3e86a76e-747259fd@192.168.20.6
Max-Forwards: 70
Session-ID: a89cd36200105000a000703509b48570;remote=00000000000000000000000000000000
Date: Thu, 21 Nov 2019 12:00:28 GMT
CSeq: 2198 REGISTER
Contact: <sip:26827-2046@192.168.20.6:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-703509b48570>";+u.sip!devicename.ccm.cisco.com="SEP703509B48570";+u.sip!model.ccm.cisco.com="36224";video
Content-Length: 0
Expires: 3600
Nov 21 12:00:38.015: //120736/5DCBC0E294B7/SIP/Event/sact_idle_new_message_register:
Nov 21 12:00:38.016: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Nov 21 12:00:38.016: //120736/5DCBC0E294B7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:808@192.168.20.254>;tag=4A71B798-1CD5
Date: Thu, 21 Nov 2019 12:00:38 GMT
CSeq: 2198 REGISTER
Contact: <sip:808@192.168.20.6:5060>;expires=600
Expires: 600
Content-Length: 0
Nov 21 12:00:38.637: //120732/4B17B0EE94B4/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 12:00:39.594: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.8:5060;branch=z9hG4bK05fad289
From: <sip:807@192.168.20.254>;tag=7001b577f2340c29351e21f6-79929612
To: <sip:807@192.168.20.254>
Call-ID: 7001b577-f2340004-78795eac-4feb18ae@192.168.20.8
Max-Forwards: 70
Date: Thu, 21 Nov 2019 12:00:47 GMT
CSeq: 2202 REGISTER
Contact: <sip:26822-141D@192.168.20.8:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-7001b577f234>";+u.sip!devicename.ccm.cisco.com="SEP7001B577F234";+u.sip!model.ccm.cisco.com="36224";video
Content-Length: 0
Expires: 3600
Nov 21 12:00:39.595: //120737/5EBCD5EF94B8/SIP/Event/sact_idle_new_message_register:
Nov 21 12:00:39.596: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Nov 21 12:00:39.596: //120737/5EBCD5EF94B8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:807@192.168.20.254>;tag=4A71BDC4-2098
Date: Thu, 21 Nov 2019 12:00:39 GMT
CSeq: 2202 REGISTER
Contact: <sip:807@192.168.20.8:5060>;expires=600
Expires: 600
Content-Length: 0
Nov 21 12:00:42.964: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:00:43.575: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.4:5060;branch=z9hG4bK452b9b12
From: <sip:803@192.168.20.254>;tag=7001b577e7720d3418b01ebe-7ee76d6b
To: <sip:803@192.168.20.254>
Call-ID: 7001b577-e7720004-22c19955-1d93bb3e@192.168.20.4
Max-Forwards: 70
Session-ID: 8d04db7f00105000a0007001b577e772;remote=00000000000000000000000000000000
Date: Thu, 21 Nov 2019 12:00:49 GMT
CSeq: 2202 REGISTER
Contact: <sip:2680F-63@192.168.20.4:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-7001b577e772>";+u.sip!devicename.ccm.cisco.com="SEP7001B577E772";+u.sip!model.ccm.cisco.com="36224";video
Content-Length: 0
Expires: 3600
Nov 21 12:00:43.576: //120739/611C49E594B9/SIP/Event/sact_idle_new_message_register:
Nov 21 12:00:43.576: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Nov 21 12:00:43.577: //120739/611C49E594B9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:803@192.168.20.254>;tag=4A71CD51-1289
Date: Thu, 21 Nov 2019 12:00:43 GMT
CSeq: 2202 REGISTER
Contact: <sip:803@192.168.20.4:5060>;expires=600
Expires: 600
Content-Length: 0
Nov 21 12:00:44.631: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:00:44.632: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:00:44.636: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:00:44.637: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:00:44.681: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:00:54.743: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.7:5060;branch=z9hG4bK2c246e2e
From: <sip:804@192.168.20.254>;tag=a093510fc10b0be1550bf619-3d6f7ad7
Call-ID: a093510f-c10b0004-3ecb4aa4-2cb905ae@192.168.20.7
Max-Forwards: 70
Date: Thu, 21 Nov 2019 12:01:01 GMT
CSeq: 2202 REGISTER
Contact: <sip:26814-6AF@192.168.20.7:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-a093510fc10b>";+u.sip!devicename.ccm.cisco.com="SEPA093510FC10B";+u.sip!model.ccm.cisco.com="36224";video
Content-Length: 0
Expires: 3600
Nov 21 12:00:54.743: //120743/67C43CC994BA/SIP/Event/sact_idle_new_message_register:
Nov 21 12:00:54.744: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Nov 21 12:00:54.744: //120743/67C43CC994BA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:804@192.168.20.254>;tag=4A71F8F0-26B5
Date: Thu, 21 Nov 2019 12:00:54 GMT
CSeq: 2202 REGISTER
Contact: <sip:804@192.168.20.7:5060>;expires=600
Expires: 600
Content-Length: 0
Nov 21 12:01:02.298: //120733/593213D994B5/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 12:01:05.850: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.5:5060;branch=z9hG4bK15d9ece8
From: <sip:802@192.168.20.5>;tag=cc70ed34188c0dcc5f1bdbd3-12e615d5
To: <sip:800@192.168.20.254>;tag=4A3CED1A-100C
Call-ID: cc70ed34-188c0523-463b5f0f-2360a62a@192.168.20.5
Date: Thu, 21 Nov 2019 12:00:57 GMT
Event: presence
Expires: 2147483647
Max-Forwards: 70
Contact: <sip:2680A-170C@192.168.20.5:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEPCC70ED34188C"
Content-Length: 0
Nov 21 12:01:05.851: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 12:01:05.852: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 12:01:05.852: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 12:01:05.857: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 12:01:06.414: //120735/5BA5D2AE94B6/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 12:01:10.016: //120736/5DCBC0E294B7/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 12:01:11.596: //120737/5EBCD5EF94B8/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 12:01:14.023: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.15:5060;branch=z9hG4bK14014460
From: <sip:801@192.168.20.254>;tag=cc70ed34034a0c156826f2b4-772cf891
Call-ID: cc70ed34-034a0002-15f0f4c2-069f63b5@192.168.20.15
Max-Forwards: 70
Session-ID: 1862424a00105000a000cc70ed34034a;remote=00000000000000000000000000000000
Date: Thu, 21 Nov 2019 12:01:13 GMT
CSeq: 2198 REGISTER
Contact: <sip:26803-905@192.168.20.15:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-cc70ed34034a>";+u.sip!devicename.ccm.cisco.com="SEPCC70ED34034A";+u.sip!model.ccm.cisco.com="36224";video
Content-Length: 0
Expires: 3600
Nov 21 12:01:14.024: //120744/7342233294BB/SIP/Event/sact_idle_new_message_register:
Nov 21 12:01:14.024: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Nov 21 12:01:14.025: //120744/7342233294BB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:801@192.168.20.254>;tag=4A724440-E84
Date: Thu, 21 Nov 2019 12:01:14 GMT
CSeq: 2198 REGISTER
Contact: <sip:801@192.168.20.15:5060>;expires=600
Expires: 600
Content-Length: 0
Nov 21 12:01:15.577: //120739/611C49E594B9/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 12:01:18.071: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:01:18.071: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:01:18.339: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:01:19.931: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:01:19.932: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:01:19.937: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:01:19.963: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:01:20.650: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:01:20.650: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:01:20.656: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:01:21.581: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:01:21.581: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:01:21.586: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:01:26.744: //120743/67C43CC994BA/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 12:01:46.024: //120744/7342233294BB/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 12:02:43.071: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:02:43.071: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:02:43.077: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:02:44.720: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:02:44.721: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:02:44.726: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:02:44.742: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:02:44.782: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:02:52.610: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:65515276@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.5:5060;branch=z9hG4bK191234d6
From: <sip:802@192.168.20.5>;tag=cc70ed34188c0dd53a4764d2-707de9ce
To: <sip:65515276@192.168.20.254>
Call-ID: cc70ed34-188c0526-492c0d25-6d1abbe6@192.168.20.5
Date: Thu, 21 Nov 2019 12:02:44 GMT
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 21 12:02:52.612: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 12:02:52.613: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 12:02:52.613: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 12:02:52.622: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 12:02:52.622: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 12:02:56.926: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:65515276@192.168.20.254;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.20.5:5060;branch=z9hG4bK495b21a9
From: "KASSIME CISSE" <sip:802@192.168.20.254>;tag=cc70ed34188c0dd672697f1f-7dcddc32
Call-ID: cc70ed34-188c0044-1b085583-79ddf5b4@192.168.20.5
Max-Forwards: 70
Session-ID: 3eea99d300105000a000cc70ed34188c;remote=00000000000000000000000000000000
Date: Thu, 21 Nov 2019 12:02:48 GMT
CSeq: 101 INVITE
Contact: <sip:2680A-170C@192.168.20.5:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEPCC70ED34188C";video
Expires: 180
Accept: application/sdp
Remote-Party-ID: "KASSIME CISSE" <sip:802@192.168.20.254>;party=calling;id-type=subscriber;privacy=off;screen=yes
Recv-Info: conference
Recv-Info: x-cisco-conference
Content-Length: 1173
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 23931 0 IN IP4 192.168.20.5
s=SIP Call
b=AS:4064
t=0 0
m=audio 17868 RTP/AVP 8 0 116 18 101
c=IN IP4 192.168.20.5
b=TIAS:64000
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
m=video 22646 RTP/AVP 100 126 97
b=TIAS:4000000
a=rtpmap:100 H264/90000
a=fmtp:100 profile-level-id=640C16;packetization-mode=1;level-asymmetry-allowed=1;max-mbps=108000;max-fs=3600;max-rcmd-nalu-size=256000
a=imageattr:* recv [x=800,y=480,q=0.60] [x=1280,y=720,q=0.50]
a=rtpmap:126 H264/90000
a=fmtp:126 profile-level-id=428016;packetization-mode=1;level-asymmetry-allowed=1;max-mbps=108000;max-fs=3600;max-rcmd-nalu-size=256000
a=rtpmap:97 H264/90000
a=fmtp:97 profile-level-id=428016;packetization-mode=0;level-asymmetry-allowed=1;max-mbps=108000;max-fs=3600;max-rcmd-nalu-size=256000
a=rtcp-fb:* nack pli
a=rtcp-fb:* ccm fir
a=rtcp-fb:* ccm tmmbr
a=recvonly
Nov 21 12:02:56.927: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:02:56.928: //120754/B098088B94BC/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Nov 21 12:02:56.929: //120754/B098088B94BC/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:7FC70E21C770
Nov 21 12:02:56.929: //120754/B098088B94BC/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
SIP: (120754) Attribute mid, level 1 instance 1 not found.
SIP: (120754) Attribute mid, level 2 instance 1 not found.
SIP: (120754) setup attribute, level 1 instance 1 not found.
SIP: (120754) connection attribute, level 1 instance 1 not found.
SIP: (120754) Attribute label, level 1 instance 1 not found.
SIP: (120754) a=framerate attribute, level 1 instance 1 not found.
SIP: (120754) Attribute ptime, level 1 instance 1 not found.
SIP: (120754) setup attribute, level 2 instance 1 not found.
SIP: (120754) connection attribute, level 2 instance 1 not found.
SIP: (120754) Attribute label, level 2 instance 1 not found.
SIP: (120754) a=framerate attribute, level 2 instance 1 not found.
SIP: (120754) Attribute ptime, level 2 instance 1 not found.
Nov 21 12:02:56.931: //120754/B098088B94BC/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 21 12:02:56.931: //120754/B098088B94BC/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:7FC70E2222D8
Nov 21 12:02:56.934: //120754/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 21 Nov 2019 12:02:56 GMT
CSeq: 101 INVITE
Session-ID: 00000000000000000000000000000000;remote=3eea99d300105000a000cc70ed34188c
Content-Length: 0
Nov 21 12:02:56.934: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_spi_subscribe_client: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE
Nov 21 12:02:56.935: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 12:02:56.936: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 12:02:56.936: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 12:02:56.949: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 12:02:56.956: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:65515276@192.168.20.254:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.5:5060;branch=z9hG4bK2a20230b
To: <sip:65515276@192.168.20.254>;tag=4A73D63F-A5E
From: <sip:802@192.168.20.5>;tag=cc70ed34188c0dd7694bf63d-59873bde
Call-ID: B0991A1D-B8D11EA-94C1908E-D4685DC2@192.168.20.254
CSeq: 1000 NOTIFY
Event: kpml
Subscription-State: active; expires=7200
Max-Forwards: 70
Content-Length: 0
Nov 21 12:02:56.957: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Nov 21 12:03:06.947: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_spi_subscribe_client: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE
Nov 21 12:03:06.947: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 12:03:06.948: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
Nov 21 12:03:06.949: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
Nov 21 12:03:06.950: //120756/B098088B94BC/SIP/Error/sipSPICreateOutboundStreams:
Failed to get source addres for IPv4 stream
Nov 21 12:03:06.950: //120756/B098088B94BC/SIP/Error/sipSPIUpdateSrcSdpFixedPart:
main stream, No DNS involved
resolve_sig_ip_address_to_bind failed
Nov 21 12:03:06.950: //-1/xxxxxxxxxxxx/SIP/Error/voipCodec_to_rtpAvpCodec:
Unexpected VoIPCodec Type :No Codec
SIP: (120756) Group (a= group line) attribute, level 65535 instance 1 not found.
Nov 21 12:03:06.950: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Nov 21 12:03:06.951: //120756/B098088B94BC/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Nov 21 12:03:06.951: //120756/B098088B94BC/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:7FC70E2230A8
Nov 21 12:03:06.951: //120756/B098088B94BC/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
Nov 21 12:03:06.953: //120756/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:65515276@10.203.5.137:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.254:5060;branch=z9hG4bK20271B0
From: "+22521598453" <sip:+22521598453@obusiness.ci>;tag=4A73FD61-AC0
To: <sip:65515276@10.203.5.137>
Date: Thu, 21 Nov 2019 12:03:06 GMT
Call-ID: B6919313-B8D11EA-94C3908E-D4685DC2@192.168.1.254
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 2962753675-0193794538-2495385742-3563609538
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1574337786
Contact: <sip:+22521598453@192.168.1.254:5060>
Call-Info: <sip:192.168.1.254:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 360
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 264
v=0
o=CiscoSystemsSIP-GW-UserAgent 1179 2644 IN IP4 192.168.1.254
s=SIP Call
c=IN IP4 192.168.1.254
t=0 0
m=audio 9650 RTP/AVP 8 0 18
a=fmtp:18 annexb=no
a=ptime:20
Nov 21 12:03:06.959: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.5:5060;branch=z9hG4bK0033b9b0
Date: Thu, 21 Nov 2019 12:02:58 GMT
CSeq: 1001 NOTIFY
Event: kpml
Subscription-State: terminated; reason=timeout
Max-Forwards: 70
Content-Length: 218
Content-Type: application/kpml-response+xml
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="487" text="Subscription Exp" suppressed="false" forced_flush="false" digits="" tag="Backspace OK"/>
Nov 21 12:03:06.959: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Nov 21 12:03:06.959: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 12:03:06.962: //120756/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.1.254:60538;branch=z9hG4bK20271B0
From: "+22521598453"<sip:+22521598453@obusiness.ci>;tag=4A73FD61-AC0
CSeq: 101 INVITE
Content-Length: 0
Nov 21 12:03:14.752: //120756/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:65515276@10.203.5.137>;tag=sbc0407ia8vjaii-CC-6
CSeq: 101 INVITE
Contact: <sip:10.203.5.137:5060>
Require: 100rel
RSeq: 1
P-Early-Media: sendonly
Content-Length: 137
v=0
o=- 3471312 3471312 IN IP4 10.203.3.137
s=SBC call
c=IN IP4 10.203.3.137
t=0 0
m=audio 24790 RTP/AVP 8
a=ptime:20
a=sendrecv
SIP: Attribute mid, level 1 instance 1 not found.
SIP: setup attribute, level 1 instance 1 not found.
SIP: connection attribute, level 1 instance 1 not found.
SIP: Attribute label, level 1 instance 1 not found.
SIP: a=framerate attribute, level 1 instance 1 not found.
Nov 21 12:03:14.753: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
Nov 21 12:03:14.753: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for +22521598453
No entry found in reg Number Table for 65515276
Nov 21 12:03:14.753: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
ReqLine IP addr does not match with host IP addr
Nov 21 12:03:14.754: //120754/B098088B94BC/SIP/Error/sipSPIDestroyRtpSession:
Nov 21 12:03:14.754: //120754/B098088B94BC/SIP/Error/sipSPIDeleteStream:
Nov 21 12:03:14.755: //120756/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:10.203.5.137:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.254:5060;branch=z9hG4bK202721373
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Session-ID: 3eea99d300105000a000cc70ed34188c;remote=4f47700aa46c52c68b3da4ed224a6f6f
Content-Length: 0
Nov 21 12:03:14.756: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_reg_number_table:
No entry found in reg Number Table for 802
Nov 21 12:03:14.756: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr:
Nov 21 12:03:14.756: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
Nov 21 12:03:14.757: //120754/B098088B94BC/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 21 12:03:14.757: //120754/B098088B94BC/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:183, container:7FC70E222D00
Nov 21 12:03:14.758: //120754/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <sip:65515276@192.168.20.254>;tag=4A741BDE-9D0
CSeq: 101 INVITE
Contact: <sip:65515276@192.168.20.254:5060>
Session-ID: 4f47700aa46c52c68b3da4ed224a6f6f;remote=3eea99d300105000a000cc70ed34188c
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 1117 2990 IN IP4 192.168.20.254
s=SIP Call
c=IN IP4 192.168.20.254
t=0 0
m=audio 9646 RTP/AVP 8
a=ptime:20
m=video 0 RTP/AVP 100
Nov 21 12:03:14.841: //120756/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.254:60538;branch=z9hG4bK202721373
CSeq: 102 PRACK
Content-Length: 0
Nov 21 12:03:16.093: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK2a0133b4
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e0f7a7f567863-26b1ef55
To: <sip:805@192.168.20.254>;tag=4A3F613A-1B40
Call-ID: 34f8e76c-fa5e0670-2b238adf-6842720c@192.168.20.14
Date: Thu, 21 Nov 2019 12:03:15 GMT
Event: presence
Expires: 2147483647
Max-Forwards: 70
Content-Length: 0
Nov 21 12:03:16.094: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 12:03:16.095: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 12:03:16.096: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 12:03:16.100: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 12:03:16.246: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.12:5060;branch=z9hG4bK2e7110ed
From: <sip:809@192.168.20.254>;tag=cc70ed342a760042265975ca-6137df46
To: <sip:809@192.168.20.254>
Call-ID: cc70ed34-2a760002-78c02401-31466e56@192.168.20.12
Max-Forwards: 70
Session-ID: 36cdf9bd00105000a000cc70ed342a76;remote=00000000000000000000000000000000
Date: Thu, 21 Nov 2019 12:03:16 GMT
CSeq: 125 REGISTER
Contact: <sip:2682C-1ED4@192.168.20.12:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-cc70ed342a76>";+u.sip!devicename.ccm.cisco.com="SEPCC70ED342A76";+u.sip!model.ccm.cisco.com="36224";video
Content-Length: 0
Expires: 3600
Nov 21 12:03:16.247: //120757/BC1C09B494C4/SIP/Event/sact_idle_new_message_register:
Nov 21 12:03:16.247: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
Nov 21 12:03:16.248: //120757/BC1C09B494C4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:809@192.168.20.254>;tag=4A7421B0-168D
CSeq: 125 REGISTER
Contact: <sip:809@192.168.20.12:5060>;expires=600
Expires: 600
Content-Length: 0
Nov 21 12:03:16.963: //120756/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow: INVITE,ACK,BYE,CANCEL,UPDATE,INFO,PRACK,NOTIFY,REFER,SUBSCRIBE,OPTIONS,MESSAGE
Require: timer
Session-Expires: 24000;refresher=uac
P-Asserted-Identity: <tel:65515276;phone-context=+225>
Content-Length: 0
Nov 21 12:03:16.963: //120756/B098088B94BC/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 21 12:03:16.963: //120756/B098088B94BC/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:7FC70E2198B8
Nov 21 12:03:16.963: //120756/B098088B94BC/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:24000, SE Refresher:uac, Min-SE Value:1800, flags:800 Attribute mid, level 1 instance 1 not found.
Nov 21 12:03:16.965: //120756/B098088B94BC/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7FC70664E0B8
State of The Call : STATE_ACTIVE
Calling Number : +22521598453
Called Number : 65515276
Nov 21 12:03:16.965: //120756/B098088B94BC/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Source IP Port (Media): 9650
Destn IP Port (Media): 24790
Nov 21 12:03:16.965: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
Nov 21 12:03:16.966: //120754/B098088B94BC/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 21 12:03:16.966: //120754/B098088B94BC/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:7FC70E224630
Nov 21 12:03:16.966: //120754/B098088B94BC/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:24000, SE Refresher:uac, Min-SE Value:1800, flags:800
Nov 21 12:03:16.967: //120756/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.254:5060;branch=z9hG4bK2027479A
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Nov 21 12:03:16.967: //120754/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: timer
Content-Length: 244
v=0
s=SIP Call
t=0 0
a=ptime:20
Nov 21 12:03:16.977: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:65515276@192.168.20.254:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.5:5060;branch=z9hG4bK05f09eaa
Max-Forwards: 70
Date: Thu, 21 Nov 2019 12:03:08 GMT
CSeq: 101 ACK
Content-Length: 0
Nov 21 12:03:16.978: //120754/B098088B94BC/SIP/Call/sipSPICallInfo:
Calling Number : 802
Destn SIP Req Addr:Port : 192.168.20.5:5060
Destn SIP Resp Addr:Port : 192.168.20.5:5060
Destination Name : 192.168.20.5
Nov 21 12:03:16.978: //120754/B098088B94BC/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 9646
Destn IP Address (Media): 192.168.20.5
Destn IP Port (Media): 17868
Media Stream : 2
Source IP Port (Media): 0
Nov 21 12:03:18.430: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:03:18.430: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:03:18.437: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:03:20.000: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:03:20.000: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:03:20.005: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:03:20.050: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:03:20.760: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:03:20.760: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:03:20.765: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:03:21.690: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:03:21.690: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:03:21.695: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:03:39.060: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
hello
Nov 21 12:03:39.060: //-1/xxxxxxxxxxxx/SIP/Error/HandleUdpIPv4SocketReads:
SIP Message incomplete, trashed
Nov 21 12:03:48.249: //120757/BC1C09B494C4/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 12:04:34.240: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:04:34.240: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:04:34.246: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:04:34.439: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.203.5.137:5060;branch=z9hG4bKerdy0vdg3oo1l13eykddy0xk3T17196
Call-ID: asbcj8g33x3zx283plgv1z28vhv01v382g2r@19500.0.ATS.cocats01.ims.orange.ci.6
From: <sip:+22521598450@obusiness.ci>;tag=sbc0407p0xajlai-CC-6
CSeq: 1 NOTIFY
Max-Forwards: 69
Event: ua-profile
Content-Length: 758
</ss:simservs>
Nov 21 12:04:34.442: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Nov 21 12:04:34.442: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 12:04:43.183: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:04:44.801: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:04:44.801: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:04:44.807: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:04:44.851: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:04:44.900: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:04:49.582: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 12:04:49.583: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 12:04:49.588: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 12:04:49.588: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 21 12:04:49.589: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.4:5060;branch=z9hG4bK3b3a0efe
From: <sip:803@192.168.20.4>;tag=7001b577e7720d3549f25443-6eccfbca
Call-ID: 7001b577-e77204bd-1efc7865-125e5a9f@192.168.20.4
Date: Thu, 21 Nov 2019 12:04:55 GMT
Event: presence
Expires: 2147483647
Max-Forwards: 70
Contact: <sip:2680F-63@192.168.20.4:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP7001B577E772"
Content-Length: 0
Nov 21 12:04:49.591: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 21 12:04:49.592: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 12:04:49.592: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 12:04:49.597: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
There are no outstanding NOTIFY's
Nov 21 12:05:16.210: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:65515276@192.168.20.254:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.5:5060;branch=z9hG4bK385cc05a
Max-Forwards: 70
Date: Thu, 21 Nov 2019 12:05:07 GMT
CSeq: 102 BYE
User-Agent: Cisco-CP8845/12.1.1
Content-Length: 0
Nov 21 12:05:16.212: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Nov 21 12:05:16.214: //120754/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 21 Nov 2019 12:05:16 GMT
CSeq: 102 BYE
Content-Length: 0
Nov 21 12:05:16.214: //120756/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:10.203.5.137:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.254:5060;branch=z9hG4bK20282C73
Max-Forwards: 70
Timestamp: 1574337916
CSeq: 103 BYE
Content-Length: 0
Nov 21 12:05:16.215: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_VOIPRTP_FPI_EVENT
Nov 21 12:05:16.215: //120754/B098088B94BC/SIP/Error/sipSPIDestroyRtpSession:
Nov 21 12:05:16.215: //120754/B098088B94BC/SIP/Call/sipSPICallInfo:
Nov 21 12:05:16.215: //120754/B098088B94BC/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Media Stream : 2
Nov 21 12:05:16.216: //120754/B098088B94BC/SIP/Call/sipSPICallInfo:
Nov 21 12:05:16.216: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 21 12:05:16.217: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetDialogParamStr:
Invalid parameters
Nov 21 12:05:16.222: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_decrement_outstanding_notify_count:
Nov 21 12:05:16.311: //120756/B098088B94BC/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.254:60538;branch=z9hG4bK20282C73
CSeq: 103 BYE
Content-Length: 0
Nov 21 12:05:16.311: //120756/B098088B94BC/SIP/Error/sipSPIDestroyRtpSession:
Nov 21 12:05:16.311: //120756/B098088B94BC/SIP/Call/sipSPICallInfo:
Nov 21 12:05:16.312: //120756/B098088B94BC/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Nov 21 12:05:16.312: //120756/B098088B94BC/SIP/Call/sipSPICallInfo:
Nov 21 12:05:16.312: //120756/B098088B94BC/SIP/Error/sipSPIFlushDeferredQueue:
Nov 21 12:05:18.520: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:05:18.521: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:05:18.527: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:05:20.094: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:05:20.094: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:05:20.099: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:05:20.122: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:05:20.851: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:05:20.851: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:05:20.856: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Nov 21 12:05:21.790: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 21 12:05:21.791: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 21 12:05:21.796: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Hi Gregory
Can you check and help me?
Your debug only catches a final "Bye", nothing before that refers to that phone number.
Can you make sure you catch the whole call from the first Invite to the final failure.
Hi this is the call debug
Received:
INVITE tel:+22521598450 SIP/2.0
Via: SIP/2.0/UDP 10.203.5.137:5060;branch=z9hG4bK6vaf6v9l7v2v2o4p0a4o089a8T09146
Call-ID: asbcgxil01jhvlravhvhgap3ai1hzv1z28gg@ATS.cocats01.ims.orange.ci.6
From: "08305302"<tel:08305302;phone-context=+225>;tag=sbc0509apaphh1j-CC-6
To: <sip:+22521598450@10.203.5.137:5060;transport=udp;user=phone>
CSeq: 1 INVITE
Alert-Info: <http://www.huawei.com/ring/>;info=pattern1
Contact: <sip:08305302@10.203.5.137:5060;user=phone>
Max-Forwards: 101
Min-SE: 600
P-Called-Party-ID: <tel:+22521598450>
Content-Length: 198
v=0
o=- 3549846 3549846 IN IP4 10.203.4.137
s=SBC call
c=IN IP4 10.203.4.137
t=0 0
m=audio 34158 RTP/AVP 8 0 18 101
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
Nov 28 16:29:56.051: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Nov 28 16:29:56.051: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:7FDC9722D600
Nov 28 16:29:56.051: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:24000, SE Refresher:none, Min-SE Value:1800, flags:2001
Nov 28 16:29:56.052: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 28 16:29:56.052: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:7FDC9722DAE0
Nov 28 16:29:56.054: //8234/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 28 Nov 2019 16:29:56 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-16.11.1a
Session-ID: 00000000000000000000000000000000;remote=7687499a8cac5a76a31bdb6fb2b76b29
Content-Length: 0
Nov 28 16:29:56.055: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
Nov 28 16:29:56.056: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
Nov 28 16:29:56.056: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Nov 28 16:29:56.057: //8235/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Nov 28 16:29:56.057: //8235/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:7FDC9722AE30
Nov 28 16:29:56.057: //8235/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:24000, SE Refresher:none, Min-SE Value:1800, flags:2001
Nov 28 16:29:56.059: //8235/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:800@192.168.20.14:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.254:5060;branch=z9hG4bK239821B
From: "08305302" <sip:08305302@obusiness.ci>;tag=4F33400-26CC
Call-ID: 25A18C1E-113311EA-8696E6C6-4CE539A4@192.168.20.254
Min-SE: 1800
Cisco-Guid: 0631274124-0288559594-2257643206-1290090916
CSeq: 101 INVITE
Timestamp: 1574958596
Contact: <sip:08305302@192.168.20.254:5060>
Expires: 360
Max-Forwards: 100
Session-ID: 7687499a8cac5a76a31bdb6fb2b76b29;remote=00000000000000000000000000000000
Content-Length: 291
v=0
o=CiscoSystemsSIP-GW-UserAgent 1888 3947 IN IP4 192.168.20.254
s=SIP Call
t=0 0
m=audio 8150 RTP/AVP 8 0 18 19
a=fmtp:18 annexb=no
a=rtpmap:19 CN/8000
a=ptime:20
Nov 28 16:29:56.060: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:29:56.064: //8235/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Session-ID: 6299054500105000a00034f8e76cfa5e;remote=7687499a8cac5a76a31bdb6fb2b76b29
Date: Thu, 28 Nov 2019 16:29:54 GMT
CSeq: 101 INVITE
Contact: <sip:26622-E69@192.168.20.14:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEP34F8E76CFA5E";video
Content-Length: 0
Nov 28 16:29:56.116: //8235/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:800@192.168.20.14>;tag=34f8e76cfa5e010d4b48f061-769a8acb
CSeq: 101 INVITE
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "DIANE DOUAYE" <sip:800@192.168.20.254>;party=called;id-type=subscriber;privacy=off;screen=yes
Allow-Events: kpml,dialog
Content-Length: 0
Nov 28 16:29:56.117: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
Nov 28 16:29:56.117: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 28 16:29:56.117: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:7FDC97229228
Nov 28 16:29:56.118: //8234/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:+22521598450@10.203.5.137:5060;transport=udp;user=phone>;tag=4F3343B-1BE0
CSeq: 1 INVITE
Require: 100rel
RSeq: 2094
Contact: <sip:+22521598450@192.168.1.254:5060>
Content-Length: 0
Nov 28 16:29:56.217: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:+22521598450@160.120.165.64:58546 SIP/2.0
Via: SIP/2.0/UDP 10.203.5.137:5060;branch=z9hG4bKv2kao2p8mv2kf864lla07kkk0T09149
CSeq: 2 PRACK
Max-Forwards: 101
RAck: 2094 1 INVITE
Content-Length: 0
Nov 28 16:29:56.218: //8234/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 2 PRACK
Content-Length: 0
Nov 28 16:30:02.307: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 28 16:30:02.307: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 28 16:30:03.290: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Nov 28 16:30:11.296: //8235/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Thu, 28 Nov 2019 16:30:10 GMT
CSeq: 101 INVITE
Content-Length: 165
v=0
o=Cisco-SIPUA 11806 0 IN IP4 192.168.20.14
s=SIP Call
t=0 0
m=audio 28966 RTP/AVP 8
c=IN IP4 192.168.20.14
b=TIAS:64000
a=sendrecv
Nov 28 16:30:11.296: //8235/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 28 16:30:11.296: //8235/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:7FDC97231A40
Nov 28 16:30:11.297: //8235/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:140
Nov 28 16:30:11.297: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
Nov 28 16:30:11.298: //8235/25A07A8C8690/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x7FDC8EE88598
TCP Sockets Used : NO
Called Number : 800
Source IP Address (Sig ): 192.168.20.254
Destn SIP Req Addr:Port : 192.168.20.14:5060
Destn SIP Resp Addr:Port : 192.168.20.14:5060
Destination Name : 192.168.20.14
Nov 28 16:30:11.298: //8235/25A07A8C8690/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Negotiated Codec : g711alaw
Negotiated Codec Bytes : 160
Nego. Codec payload : 8 (tx), 8 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.20.254
Source IP Port (Media): 8150
Destn IP Address (Media): 192.168.20.14
Destn IP Port (Media): 28966
Orig Destn IP Address:Port (Media): [ - ]:0
Nov 28 16:30:11.299: //8235/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:26622-E69@192.168.20.14:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.20.254:5060;branch=z9hG4bK239BD55
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 7687499a8cac5a76a31bdb6fb2b76b29;remote=6299054500105000a00034f8e76cfa5e
Content-Length: 0
Nov 28 16:30:11.300: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_HA_CHKPNT_NOTIFY
Nov 28 16:30:11.301: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
Nov 28 16:30:11.301: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 28 16:30:11.302: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:7FDC9722B8C0
Nov 28 16:30:11.302: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:140
Nov 28 16:30:11.303: //8234/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 193
v=0
o=CiscoSystemsSIP-GW-UserAgent 6568 7768 IN IP4 192.168.1.254
s=SIP Call
t=0 0
m=audio 8148 RTP/AVP 8
a=ptime:20
Nov 28 16:30:11.404: //8234/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 193
v=0
s=SIP Call
t=0 0
a=ptime:20
Nov 28 16:30:11.427: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.203.5.137:5060;branch=z9hG4bK20fo8lpptp0024tl088tf90alT09398
CSeq: 1 ACK
Max-Forwards: 101
Content-Length: 0
Nov 28 16:30:11.427: //8234/25A07A8C8690/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7FDC8EE4D2D8
Nov 28 16:30:11.427: //8234/25A07A8C8690/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 8148
Destn IP Address (Media): 10.203.4.137
Destn IP Port (Media): 34158
Nov 28 16:30:20.134: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:08305302@192.168.20.254:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK2905925e
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e010d4b48f061-769a8acb
To: "08305302" <sip:08305302@obusiness.ci>;tag=4F33400-26CC
Max-Forwards: 70
Date: Thu, 28 Nov 2019 16:30:18 GMT
CSeq: 101 INVITE
Call-Info: <urn:x-cisco-remotecc:hold>; reason= transfer; protect= true; noholdreversion
Content-Length: 1165
v=0
o=Cisco-SIPUA 11806 1 IN IP4 192.168.20.14
s=SIP Call
t=0 0
m=audio 28966 RTP/AVP 8 0 116 18 101
b=TIAS:64000
a=fmtp:116 mode=20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendonly
m=video 32308 RTP/AVP 100 126 97
b=TIAS:4000000
a=rtcp-fb:* ccm fir
a=inactive
Nov 28 16:30:20.135: //8235/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Nov 28 16:30:20.135: //8235/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:7FDC9722DF58
Nov 28 16:30:20.136: //8235/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2140
Nov 28 16:30:20.137: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
Nov 28 16:30:20.138: //8235/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 28 16:30:20.138: //8235/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:7FDC97228660
Nov 28 16:30:20.139: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
Nov 28 16:30:20.139: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Nov 28 16:30:20.140: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:7FDC97230E78
Nov 28 16:30:20.140: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2140
Nov 28 16:30:20.142: //8235/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 28 Nov 2019 16:30:20 GMT
CSeq: 101 INVITE
Content-Length: 0
Nov 28 16:30:20.142: //8234/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:08305302@10.203.5.137:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.1.254:5060;branch=z9hG4bK239C2466
From: <sip:+22521598450@10.203.5.137:5060;transport=udp;user=phone>;tag=4F3343B-1BE0
To: "08305302"<tel:08305302;phone-context=+225>;tag=sbc0509apaphh1j-CC-6
Min-SE: 1800
User-Agent: Cisco-SIPGateway/IOS-16.11.1a
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1574958620
Expires: 360
Content-Length: 710
v=0
o=CiscoSystemsSIP-GW-UserAgent 6568 7769 IN IP4 192.168.1.254
s=SIP Call
t=0 0
m=audio 8148 RTP/AVP 8 0 18 19
a=fmtp:18 annexb=no
a=rtpmap:19 CN/8000
a=ptime:20
a=sendonly
m=video 8154 RTP/AVP 99 99 101
b=TIAS:4000000
a=rtpmap:99 H264/90000
a=fmtp:99 profile-level-id=640C16;packetization-mode=1;max-mbps=108000;max-fs=3600
a=fmtp:99 profile-level-id=428016;packetization-mode=1;max-mbps=108000;max-fs=3600
a=rtpmap:101 H264/90000
a=fmtp:101 profile-level-id=428016;packetization-mode=0;max-mbps=108000;max-fs=3600
a=inactive
Nov 28 16:30:20.159: //8234/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.1.254:5060;branch=z9hG4bK239C2466;received=160.120.165.64
CSeq: 101 INVITE
Content-Length: 0
Nov 28 16:30:20.436: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:08305302@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK6fbf11a9
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e010f12f234ac-179cba40
To: <sip:08305302@192.168.20.254>
Call-ID: 34f8e76c-fa5e006d-52ddee47-52e95226@192.168.20.14
Session-ID: f73353df00105000a00034f8e76cfa5e;remote=00000000000000000000000000000000
Date: Thu, 28 Nov 2019 16:30:19 GMT
CSeq: 1000 SUBSCRIBE
Event: presence
Accept: application/cpim-pidf+xml
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:20.439: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:20.440: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:20202350@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK674d3f3e
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e011013ccaf49-4bd44d76
To: <sip:20202350@192.168.20.254>
Call-ID: 34f8e76c-fa5e006e-60116dc0-7edcee0d@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:20.442: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:20.443: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:08493643@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK05f60cc0
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e011107baad60-7e085db4
To: <sip:08493643@192.168.20.254>
Call-ID: 34f8e76c-fa5e006f-2dd43d30-0c4c2ace@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:20.444: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:20.445: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:65346734@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK11e10f3b
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e01124c235964-195f5a94
To: <sip:65346734@192.168.20.254>
Call-ID: 34f8e76c-fa5e0070-75ab2701-579baf61@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:20.447: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:20.448: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:20.449: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:20.452: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:07537812@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK5e492a73
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e01135e398645-3a34b4a6
To: <sip:07537812@192.168.20.254>
Call-ID: 34f8e76c-fa5e0071-5d29ff9c-54d41110@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:20.454: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:20.454: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:87721498@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK0b9fd4d3
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e0114062f91fb-4a5db890
To: <sip:87721498@192.168.20.254>
Call-ID: 34f8e76c-fa5e0072-29865e55-41da0578@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:20.456: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:20.457: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:07573557@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK27b58c4b
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e011517f0de8e-54cc3a25
To: <sip:07573557@192.168.20.254>
Call-ID: 34f8e76c-fa5e0073-233c8f13-6aceccd6@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:20.458: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:20.458: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:20262919@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK7d786a2c
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e011612fba0bd-7e9b7c1f
To: <sip:20262919@192.168.20.254>
Call-ID: 34f8e76c-fa5e0074-7389d9c1-730d0e7d@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:20.460: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:20.461: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:20.462: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:20.463: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:20.467: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:20.469: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:20.470: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:20.477: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:20.486: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:20.490: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:20.491: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:20.493: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:21.166: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:8@192.168.20.254;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK7ac7bbdd
From: "DIANE DOUAYE" <sip:800@192.168.20.254>;tag=34f8e76cfa5e010e41421c43-6e6a8039
To: <sip:8@192.168.20.254>
Call-ID: 34f8e76c-fa5e0009-4b3d33e2-3baa737d@192.168.20.14
Max-Forwards: 70
Session-ID: 7589a78000105000a00034f8e76cfa5e;remote=00000000000000000000000000000000
CSeq: 101 INVITE
Expires: 180
Remote-Party-ID: "DIANE DOUAYE" <sip:800@192.168.20.254>;party=calling;id-type=subscriber;privacy=off;screen=yes
Content-Length: 1175
v=0
o=Cisco-SIPUA 2987 0 IN IP4 192.168.20.14
s=SIP Call
b=AS:4064
t=0 0
m=audio 31588 RTP/AVP 8 0 116 18 101
b=TIAS:64000
a=fmtp:116 mode=20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
m=video 30778 RTP/AVP 100 126 97
b=TIAS:4000000
a=rtcp-fb:* ccm fir
a=recvonly
Nov 28 16:30:21.168: //8242/3499074B869A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Nov 28 16:30:21.168: //8242/3499074B869A/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:7FDC96FC6298
Nov 28 16:30:21.168: //8242/3499074B869A/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
Nov 28 16:30:21.170: //8242/3499074B869A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 28 16:30:21.170: //8242/3499074B869A/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:7FDC96FCDD48
Nov 28 16:30:21.171: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_spi_subscribe_client: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE
Nov 28 16:30:21.172: //8242/3499074B869A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 28 Nov 2019 16:30:21 GMT
CSeq: 101 INVITE
Session-ID: 00000000000000000000000000000000;remote=7589a78000105000a00034f8e76cfa5e
Content-Length: 0
Nov 28 16:30:21.173: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:21.188: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:8@192.168.20.254:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK0713e6ab
To: <sip:8@192.168.20.254>;tag=4F39619-743
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e01177b80c7e0-08ab5630
Call-ID: 3499A373-113311EA-869FE6C6-4CE539A4@192.168.20.254
CSeq: 1000 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:21.189: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Nov 28 16:30:21.478: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:804@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK2c6a5ef5
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e01180176d4a0-54ceaf94
Call-ID: 34f8e76c-fa5e0075-2073413f-7721fba1@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:21.480: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:21.481: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:805@192.168.20.254 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK2a2f92f7
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e01193254507a-555b81e6
Call-ID: 34f8e76c-fa5e0076-669f139b-0f7e5016@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:21.482: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:21.483: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:21.586: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK44e83e0f
CSeq: 1001 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
<?xml version="1.0" encoding="UTF-8"?>
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="0" tag="Backspace OK"/>
Nov 28 16:30:21.587: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Nov 28 16:30:22.081: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK15ade211
CSeq: 1002 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 205
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" version="1.0" code="200" text="OK" suppressed="false" forced_flush="false" digits="4" tag="Backspace OK"/>
Nov 28 16:30:22.082: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Nov 28 16:30:22.083: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_spi_subscribe_client: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE
Nov 28 16:30:22.084: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
Nov 28 16:30:22.085: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
Nov 28 16:30:22.086: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Nov 28 16:30:22.087: //8244/3499074B869A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Nov 28 16:30:22.087: //8244/3499074B869A/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:7FDC96FCBF38
Nov 28 16:30:22.087: //8244/3499074B869A/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
Nov 28 16:30:22.089: //8244/3499074B869A/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:804@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.254:5060;branch=z9hG4bK23AA24E1
From: "21598450" <sip:800@obusiness.ci>;tag=4F399AD-40D
To: <sip:804@192.168.20.1>
Date: Thu, 28 Nov 2019 16:30:22 GMT
Call-ID: 352568E2-113311EA-86A1E6C6-4CE539A4@192.168.20.254
Min-SE: 1800
Cisco-Guid: 0882444107-0288559594-2258298566-1290090916
CSeq: 101 INVITE
Timestamp: 1574958622
Contact: <sip:800@192.168.20.254:5060>
Expires: 360
Max-Forwards: 69
Content-Length: 698
v=0
o=CiscoSystemsSIP-GW-UserAgent 1576 567 IN IP4 192.168.20.254
s=SIP Call
t=0 0
m=audio 8160 RTP/AVP 8 0 18 19
a=fmtp:18 annexb=no
a=rtpmap:19 CN/8000
a=ptime:20
m=video 8162 RTP/AVP 98 98 99
b=TIAS:4000000
a=rtpmap:98 H264/90000
a=fmtp:98 profile-level-id=640C16;packetization-mode=1;max-mbps=108000;max-fs=3600
a=fmtp:98 profile-level-id=428016;packetization-mode=1;max-mbps=108000;max-fs=3600
a=fmtp:99 profile-level-id=428016;packetization-mode=0;max-mbps=108000;max-fs=3600
a=recvonly
Nov 28 16:30:22.091: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:22.096: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK748d4b87
CSeq: 1003 NOTIFY
Event: kpml
Max-Forwards: 70
Content-Length: 218
Nov 28 16:30:22.097: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Nov 28 16:30:22.097: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:22.102: //8244/3499074B869A/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Session-ID: 6ab8e02400105000a000a093510fc10b;remote=7589a78000105000a00034f8e76cfa5e
CSeq: 101 INVITE
Server: Cisco-CP8845/12.0.1
Contact: <sip:26638-2@192.168.20.1:5060;transport=udp>;+u.sip!devicename.ccm.cisco.com="SEPA093510FC10B";video
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Content-Length: 0
Nov 28 16:30:22.235: //8244/3499074B869A/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:804@192.168.20.1>;tag=a093510fc10b00f45908d977-0b6432b6
CSeq: 101 INVITE
Remote-Party-ID: "MOULAYE MOHAMEIDOU" <sip:804@192.168.20.254>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
Nov 28 16:30:22.236: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
Nov 28 16:30:22.236: //8242/3499074B869A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 28 16:30:22.236: //8242/3499074B869A/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:7FDC96FC5AE0
Nov 28 16:30:22.237: //8242/3499074B869A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:8@192.168.20.254>;tag=4F39A42-1F14
CSeq: 101 INVITE
Contact: <sip:26638-2@192.168.20.254:5060>
Content-Length: 0
Nov 28 16:30:22.263: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK6e6e9c64
To: <sip:805@192.168.20.254>;tag=4F3974F-1203
CSeq: 1001 SUBSCRIBE
Event: presence
Expires: 0
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:22.264: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:22.265: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK5787e78a
To: <sip:804@192.168.20.254>;tag=4F3974D-1263
Event: presence
Expires: 0
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:22.266: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:22.267: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:22.278: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:22.283: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:31.858: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:8@192.168.20.254;user=phone SIP/2.0
Max-Forwards: 70
Session-ID: 7589a78000105000a00034f8e76cfa5e;remote=6ab8e02400105000a000a093510fc10b
Date: Thu, 28 Nov 2019 16:30:30 GMT
CSeq: 101 CANCEL
Content-Length: 0
Nov 28 16:30:31.859: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Nov 28 16:30:31.860: //8242/3499074B869A/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Nov 28 16:30:31.860: //8242/3499074B869A/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:487, container:7FDC96FCEB18
Nov 28 16:30:31.861: //8242/3499074B869A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 28 Nov 2019 16:30:31 GMT
CSeq: 101 CANCEL
Content-Length: 0
Nov 28 16:30:31.861: //8244/3499074B869A/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:804@192.168.20.1:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1574958631
Reason: Q.850;cause=16
Content-Length: 0
Nov 28 16:30:31.862: //8242/3499074B869A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
Content-Length: 0
Nov 28 16:30:31.865: //8244/3499074B869A/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
Nov 28 16:30:31.866: //8244/3499074B869A/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
Nov 28 16:30:31.867: //8244/3499074B869A/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7FDC8EE8FBF0
State of The Call : STATE_DEAD
Calling Number : 800
Called Number : 804
Destn SIP Req Addr:Port : 192.168.20.1:5060
Destn SIP Resp Addr:Port : 192.168.20.1:5060
Nov 28 16:30:31.868: //8244/3499074B869A/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 2
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Source IP Port (Media): 8160
Destn IP Address (Media): -
Destn IP Port (Media): 0
Media Stream : 2
Source IP Port (Media): 8162
Nov 28 16:30:31.868: //8244/3499074B869A/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 487
Nov 28 16:30:31.868: //8244/3499074B869A/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:804@192.168.20.1:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Nov 28 16:30:31.869: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:8@192.168.20.254;user=phone SIP/2.0
Session-ID: f73353df00105000a00034f8e76cfa5e;remote=7589a78000105000a00034f8e76cfa5e
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Nov 28 16:30:31.870: //8242/3499074B869A/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x7FDC8EE28320
Called Number : 804
Nov 28 16:30:31.870: //8242/3499074B869A/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 8156
Destn IP Port (Media): 31588
Media Stream : 2
Negotiated Codec : h264
Nego. Codec payload : 100 (tx), 97 (rx)
Source IP Port (Media): 8158
Destn IP Port (Media): 30778
Nov 28 16:30:31.872: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:48.886: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:08305302@192.168.20.254:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK6a39ca96
Max-Forwards: 70
Date: Thu, 28 Nov 2019 16:30:47 GMT
CSeq: 102 BYE
Content-Length: 0
Nov 28 16:30:48.887: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Nov 28 16:30:48.888: //8234/25A07A8C8690/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Nov 28 16:30:48.890: //8234/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:08305302@10.203.5.137:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.1.254:5060;branch=z9hG4bK23AF44A
Max-Forwards: 70
Route: <sip:10.203.5.137:5060;transport=udp;lr>
Timestamp: 1574958648
CSeq: 102 BYE
Content-Length: 0
Nov 28 16:30:48.890: //8235/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 28 Nov 2019 16:30:48 GMT
CSeq: 102 BYE
Content-Length: 0
Nov 28 16:30:48.890: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_VOIPRTP_FPI_EVENT
Nov 28 16:30:48.891: //8235/25A07A8C8690/SIP/Call/sipSPICallInfo:
Calling Number : 08305302
Called Number : 800
Nov 28 16:30:48.891: //8235/25A07A8C8690/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Media Stream : 2
Source IP Port (Media): 8152
Destn IP Port (Media): 32308
Disconnect Cause (SIP) : 200
Nov 28 16:30:48.892: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:49.007: //8234/25A07A8C8690/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.254:58546;branch=z9hG4bK23AF44A
CSeq: 102 BYE
Content-Length: 0
Nov 28 16:30:49.007: //8234/25A07A8C8690/SIP/Call/sipSPICallInfo:
Called Number : +22521598450
Source IP Address (Sig ): 192.168.1.254
Destn SIP Req Addr:Port : 10.203.5.137:5060
Destn SIP Resp Addr:Port : 10.203.5.137:5060
Destination Name : 10.203.5.137
Nov 28 16:30:49.007: //8234/25A07A8C8690/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Address (Media): 192.168.1.254
Media Stream : 2
Source IP Port (Media): 8154
Nov 28 16:30:49.266: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK57d6571f
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e011b36b7481e-12ee1910
Call-ID: 34f8e76c-fa5e0077-0d93e300-60e6db15@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:49.267: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:49.268: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK55a146f7
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e011c2341c511-5574269c
Call-ID: 34f8e76c-fa5e0078-4644f383-7ac9ac9b@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:49.270: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:49.271: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK7b277c45
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e011d4ca46e76-271dce4a
Call-ID: 34f8e76c-fa5e0079-790af666-3dd2b63f@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:49.272: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:49.273: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:49.274: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:49.276: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK1adea83d
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e011e2f704691-2d9c7a28
Call-ID: 34f8e76c-fa5e007a-42bb0401-58e2a53a@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:49.278: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:49.279: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK286ac0f0
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e011f6525a4bc-7d1cbfbf
Call-ID: 34f8e76c-fa5e007b-03a19e32-103b9ba8@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:49.280: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:49.281: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK3c6f479c
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e01206ddb68c8-10204227
Call-ID: 34f8e76c-fa5e007c-742c035f-4f372f00@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:49.283: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:49.284: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:49.285: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:49.292: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK66d55233
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e012172419649-05ee771e
Call-ID: 34f8e76c-fa5e007d-4f5d60ac-7fd57949@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:49.293: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:49.294: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:49.296: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK1de0eaf6
From: <sip:800@192.168.20.14>;tag=34f8e76cfa5e01222733b7cb-23173e5a
Call-ID: 34f8e76c-fa5e007e-3c4978cf-6d78ab4e@192.168.20.14
Event: presence
Expires: 3600
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:49.297: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:49.298: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:49.312: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:49.315: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:49.329: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:49.339: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:49.349: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:49.353: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:49.357: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:30:52.824: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.14:5060;branch=z9hG4bK11eabfc7
To: <sip:804@192.168.20.254>;tag=4F403D8-18BA
Date: Thu, 28 Nov 2019 16:30:51 GMT
Event: presence
Expires: 0
Max-Forwards: 70
Content-Length: 0
Nov 28 16:30:52.825: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Nov 28 16:30:52.826: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Nov 28 16:30:52.836: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Nov 28 16:31:36.394: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:+22521598450@obusiness.ci SIP/2.0
Via: SIP/2.0/UDP 10.203.5.137:5060;branch=z9hG4bK7av4op824t07lat88v0kaoavlT00731
Record-Route: <sip:10.203.5.137:5060;transport=udp;lr>
Call-ID: asbczlh3p81hgppxjhll3vj8gvpp1j3jgvpl@19500.0.ATS.cocats01.ims.orange.ci.6
From: <sip:+22521598450@obusiness.ci>;tag=sbc0511xlv0812g-CC-6
To: <sip:+22521598450@obusiness.ci>
CSeq: 1 NOTIFY
Contact: <sip:+22521598450@10.203.5.137:5060>
Max-Forwards: 69
Event: ua-profile
Subscription-State: active
P-Called-Party-ID: <sip:+22521598450@obusiness.ci>
Content-Length: 758
Content-Type: application/simservs+xml
<ss:simservs xmlns:ss="http://uri.etsi.org/ngn/params/xml/simservs/xcap" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<ss:dial-tone-management>
<ss:dial-tone-pattern>standard-dial-tone</ss:dial-tone-pattern>
<ss:mcid-service>mcid-service-withdrawn</ss:mcid-service>
<ss:no-dialling-behaviour>rejectCall</ss:no-dialling-behaviour>
<ss:hold-service>hold-service-withdrawn</ss:hold-service>
<ss:toggle-service>toggle-service-withdrawn</ss:toggle-service>
<ss:three-pty-service>three-pty-service-provisioned</ss:three-pty-service>
<ss:cw-service>cw-service-withdrawn</ss:cw-service>
<ss:tp-service>tp-service-withdrawn</ss:tp-service>
</ss:dial-tone-management>
</ss:simservs>
Nov 28 16:32:36.900: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_response: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY_RESP
Nov 28 16:32:36.900: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
For this call example can you confirm the calling number, the internal number that originally answered the call, and the internal number that you tried to transfer the call to?
Quick glance there seem to be two calls in the trace, external call answered by x800 and then put on hold, and a second call from x800 to x804 which rang but was not answered and ended by x800 hanging up.  After that the external call was cleared.
Thx for your reply
We are going to do an other test.
Thx
