02-14-2014 10:43 PM - edited 03-16-2019 09:45 PM
I have a SIP trunk from call centric that goes into my lab gear - they appear to be a good sip service due to cost but I'm having some trouble getting calls to route correctly. The call flow is Callcentric.com ITSP (SIP) --> 2811 (acting as cube) -->SIP Trunk --> CUCM 8.6. Phones are registered to CUCM.
I have the sip trunk registered and calls come in to the router (I see them in ccsip message/call debugs) The 2811 running 15.1(4)M7). Callcentric sends the username of the customer in the sip Invite instead of the called number, the called number is in the TO field. I have several DID’s from Callcentric (18452055544, 18452055545, 18452055546) for my lab. There are a few configs on here for CME where the customer number (17772253754) is simply translated to their phone DN - which is fine if you only have 1 DN with callcentric but more than 1 and thats not feasible since every inbound did will be matched to that 17772253754 translation/phone dn.
I’m using the a guide from http://tblog.cisco.be/2011/02/17/cube-conditional-sip-profiles/ using the Copy function as described http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-software-release-15-1-3-t/product_bulletin_c25-635704.html
I haven’t been able to find anything where they actually explain all the header fields so Its mostly trial and error.. so far mostly error. I think I’m close.. but who knows. Any assistance would be greatly appreciated
voice class sip-profiles 1
request INVITE peer-header sip TO copy ".sip:(.*)@." u01
request INVITE sip-header SIP-Req-URI modify ".*@(.*)" "INVITE sip:\u01@\1"
CUCM (single/pub)- 192.168.1.200
2811 acting as cube - 192.168.1.203
Calling Number - 18165297500
Called Number - 18452055544
vrtr1#show sip register status
Line peer expires(sec) registered P-Associ-URI
17772253754 -1 20 yes
vrtr1#
The Call Setup Information is:
Call Control Block (CCB) : 0x49646C28
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 18165297500
Called Number : 17772253754 (my customer number not called number)
Source IP Address (Sig ): 192.168.1.203 (my 2811 router)
Destn SIP Req Addr:Port : 204.11.192.159:5080
Destn SIP Resp Addr:Port : 204.11.192.159:5080
Destination Name : 204.11.192.159
Feb 14 11:20:53.303: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:17772253754@192.168.1.203:5060 SIP/2.0
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-805ff2443b18502ff96181045b62dd74
f: <sip:18165297500@66.193.176.35>;tag=3601387252-874282
t: <sip:18452055544@ss.callcentric.com>
i: 2917398-3601387252-874253@msw2.telengy.net
CSeq: 1 INVITE
Max-Forwards: 8
m: <sip:ca7fe50c9cebe12327fe0d63c5962a3e@204.11.192.159:5080;transport=udp>
Supported: timer
c: application/sdp
l: 350
v=0
o=NexTone-MSW 2147483647 2147483647 IN IP4 204.11.192.159
s=sip call
c=IN IP4 204.11.192.159
t=0 0
m=audio 61094 RTP/AVP 18 0 8 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=rtpmap:101 telephone-event/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=ptime:20
a=sendrecv
a=silenceSupp:off - - - -
a=setup:actpass
Feb 14 11:20:53.327: //936/310B294680AD/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-805ff2443b18502ff96181045b62dd74
From: <sip:18165297500@66.193.176.35>;tag=3601387252-874282
To: <sip:18452055544@ss.callcentric.com>
Date: Fri, 14 Feb 2014 17:20:53 GMT
Call-ID: 2917398-3601387252-874253@msw2.telengy.net
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
SIP/2.0 404 Not Found
To: <sip:18452055544@ss.callcentric.com>;tag=35399D8-63
CSeq: 1 INVITE
Reason: Q.850;cause=1
Content-Length: 0
Feb 14 11:20:53.419: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:17772253754@192.168.1.203:5060 SIP/2.0
t: <sip:18452055544@ss.callcentric.com>;tag=35399D8-63
CSeq: 1 ACK
Max-Forwards: 10
l: 0
u all
Feb 14 11:20:57.067: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:18452055544;cic=0288;rn=6465471001;npdi@alpha14.callcentric.com:5070 SIP/2.0
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-6bceae47efe9f53b4234698a32ac8beb
CSeq: 1 ACK
Max-Forwards: 8
l: 0
************************** Running Config **************************
sh run
vrtr1#sh running-config
Building configuration...
Current configuration : 4189 bytes
! Last configuration change at 00:34:03 CST Fri Feb 14 2014
! NVRAM config last updated at 20:26:58 CST Thu Feb 13 2014
version 15.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname vrtr1
boot-start-marker
boot system flash:
boot system flash flash:c2800nm-ipvoicek9-mz.151-4.M7.bin
boot-end-marker
card type t1 0 0
logging buffered 4096 notifications
enable password cisco
no aaa new-model
memory-size iomem 5
clock timezone CST -6 0
clock summer-time CST recurring
no network-clock-participate wic 0
dot11 syslog
ip source-route
ip cef
ip name-server 192.168.1.9
no ipv6 cef
voice service voip
ip address trusted list
ipv4 192.168.1.0 255.255.255.0
ipv4 204.11.192.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
registrar server expires max 1800 min 1800
localhost dns:callcentric.com
outbound-proxy dns:callcentric.com
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice-card 0
license udi pid CISCO2811 sn FTX1133A4QR
controller T1 0/0/0
cablelength long 0db
description ** LAN **
ip address 192.168.1.203 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.1.203
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
snmp mib persist circuit
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.1.200
ccm-manager config
mgcp
mgcp call-agent 192.168.1.200 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
dial-peer voice 999100 pots
service mgcpapp
port 0/1/0
dial-peer voice 999101 pots
service mgcpapp
port 0/1/1
dial-peer voice 999102 pots
service mgcpapp
port 0/1/2
dial-peer voice 999103 pots
service mgcpapp
port 0/1/3
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 6 voip
description ## INBOUND DID to CUCM ##
session protocol sipv2
session target ipv4:192.168.1.200
incoming called-number 17772253754
voice-class sip profiles 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 7 voip
incoming called-number 1845205554[4-5]
no vad
sip-ua
credentials username 17772253754 password 7 106C1B49111F17194D realm callcentric.com
authentication username 17772253754 password 7 08035E1E1D11000553 realm callcentric.com
no remote-party-id
retry invite 2
retry register 10
timers connect 100
mwi-server dns:callcentric.com expires 3600 port 5060 transport udp
registrar dns:callcentric.com expires 3600
sip-server dns:callcentric.com
host-registrar
line con 0
line aux 0
line vty 0 4
password cisco
login
transport input all
scheduler allocate 20000 1000
ntp server 199.102.46.72
ntp server 23.227.162.123 prefer
end
exit
Solved! Go to Solution.
02-18-2014 08:49 PM
Aok - Not having any luck with inbound routing. I tried specifying the Sip Header as well as Peer-header To field regardless both seem to be grabbing the 17772253754 (username) and no the dialed number 18452055545. I havent played with outbound yet - I assume that part should be fairly easy (ha..ha..).
I've attached ccsip all debugs when using the recommended profile options for an inbound call.
voice service voip
voice class sip-profiles 5
response 200 sip-header Require remove
request INVITE sip-header TO copy "<>" u01>
request INVITE sip-header SIP-Req-URI modify “.*@(.*)” “INVITE sip:\u01@192.168.1.200:5060 SIP/2.0"
012348: Feb 18 22:40:27.103: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_sip_copy_pattern: sed_match succeeded
012349: Feb 18 22:40:27.103: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_prefix_slash_in_copy_var_val: ret_dst: 17772253754
012350: Feb 18 22:40:27.103: //3655/C9B844B581F3/SIP/Info/sip_profiles_application_sip_copy_pattern: SIP Profiles COPY variable: u1 val: 17772253754
012351: Feb 18 22:40:27.103: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_req_uri: Req URI before modification : INVITE sip:17772253754@192.168.1.200:5060 SIP/2.0
012352: Feb 18 22:40:27.103: //3655/C9B844B581F3/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: Node found: COPY variable: u1 val: 17772253754
012353: Feb 18 22:40:27.103: //3655/C9B844B581F3/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: substituted_replace_pattern : INVITE sip:17772253754
012354: Feb 18 22:40:27.103: //3655/C9B844B581F3/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: configured_replace_pattern : @192.168.1.200:5060 SIP/2.0
012355: Feb 18 22:40:27.103: //3655/C9B844B581F3/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: Final substituted_replace_pattern : INVITE sip:17772253754@192.168.1.200:5060 SIP/2.0
012356: Feb 18 22:40:27.103: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_req_uri: Passing substituted replace pattern
012357: Feb 18 22:40:27.107: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_req_uri: Req URI after modification : INVITE sip:17772253754@192.168.1.200:5060 SIP/2.0
012358: Feb 18 22:40:27.107: //3655/C9B844B581F3/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
012359: Feb 18 22:40:27.107: //3655/C9B844B581F3/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
012360: Feb 18 22:40:27.107: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.1.200, rport:5060 with laddr:192.168.1.203012348: Feb 18 22:40:27.103: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_sip_copy_pattern: sed_match succeeded
02-19-2014 05:43 AM
v: SIP/2.0/UDP 204.11.192.169:5080;branch=z9hG4bK-716633dc62c1fef90469b53084713f17
f: <18165297500>;tag=3601772862-35489518165297500>
t: <>>18452055545@ss.callcentric.com>
request INVITE peer-header t copy "<>" u01>
If it doesnt work..please send only the ff debugs
debug ccsip info
debug ccsip messages
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
02-19-2014 07:17 AM
Aok - I added the following sip profile. The context is a bit different (It didnt accept what you provided).
request INVITE peer-header sip t copy "<>" u01>
request INVITE sip-header SIP-Req-URI modify ".*@(.*)" "INVITE sip:\u01@192.168.1.200:5060 SIP/2.0"
02-19-2014 07:26 AM
Ok..That doesnt look good..
Can you try this..
no request INVITE peer-header sip t copy "<>" u01--delete this one..>
request INVITE peer-header sip To copy "<>" u01---add this one..>
02-19-2014 01:17 PM
Aok - I adjusted the profile statement as sugested, here's the current sip profile, and the debug (same error on inbound).
request INVITE peer-header sip To copy "<>" u01>
016005: Feb 19 15:12:55.210: //4668/6F2900C6823E/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:@192.168.1.200:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK12E1198A
From: <>>18165297500@callcentric.com>;tag=101C3448-EB1
To: <17772253754>17772253754>
Date: Wed, 19 Feb 2014 21:12:55 GMT
Call-ID:
6F33FD5F-98E111E3-8244E4C3-DC5CB4B2@192.168.1.203
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1864958150-2564887011-2185159875-3697063090
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1392844375
Contact: <18165297500>18165297500>
Expires: 180
02-19-2014 07:22 PM
Okay,
I have spent hours tyring to figure this out and I have just finished testing this in my environmet...
First of all, please remove all the previous sip profiles for the To header copy and add only this one..
request INVITE sip-header To copy "<>" u01>
request INVITE sip-header SIP-Req-URI modify ".*@(.*)" "\u01@\1"
Okay thats the correct syntax...However we have a slight issue...
The To header that this profile acts on is the the one sent to CUCM. And that To header is this...
Sent:
Via: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK8EF06
From: <>>18165297500@callcentric.com>;tag=3E2A54-19B0
You can then this is the reason CUBE is storing the value of the variable u01 as 17772253754.
The To value from the original INVITE is lost completely on the INVITE sent to CUCM..That means we are stick!!
To form the To field sent out, CUBE copies the Request URI from the orginal INVITE and just appends its IP address..
This is tough...I have been on this since 12am and its 3.30am UK time now and I cant find a way around this other you opening a TAC case or ask your provider to send the called number in the Request-URI
02-19-2014 07:31 PM
Lets try this..
voice class sip-copylist 1
sip-header To
Then add the voice class copy list tot he inbound dial-peer from ITSP..
Then test with the sip profile above...
Send me debug ccsip info and debug ccsip messages
02-20-2014 11:32 AM
Aok - I followed this example - which is exactly what I'm trying to do, and where I beleive you were going with your last post. Re-write the Invite with information from the To field using the sip-copy list.
Copied everything verbatim - and it doesnt work. I can't explain any of it. No matter what I do it will not match the inbound dial-peer coming from Callcentric (which is required to perform the re-write of the header).
I'm about to give up and go be a farmer - seriously this can't be that hard. I've memorized the stupid dial-peer matching guide.
The router selects an inbound dial peer by matching the information elements in the setup message with the dial peer attributes. The router attempts to match these items in the following order:
1.
Called number with incoming called-number
2.
Calling number with answer-address
3.
Calling number with destination-pattern
4.
Incoming voice port with configured voice port
So this should work right? Since its matching on the Incoming Called Number.. the first in order for inbound dial-peer matching right? Nope..
dial-peer voice 99 voip
description incoming SIP Trunk
translation-profile incoming Incoming
session target sip-server
voice-class codec 1
dtmf-relay rtp-nte
no vad
Or maybe the dial-peer isnt 'active' right? Nope - its up and active.
apsc-vrtr1#show dial-peer voice summary
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE
99910- pots up up 0 down 0/1/0 0
99910- pots up up 0 down 0/1/1 1
99910- pots up up 0 down 0/1/2 2
99910- pots up up 0 down 0/1/3 3
99901- pots up up 0 down 0/1/0 0
99 voip up up 0 syst sip-server
1 voip up up 18452055545 0 syst ipv4:192.168.1.200
Maybe the translations aren't right? Nope - those work to.
apsc-vrtr1#test voice translation-rule 9 17772253754
Matched with rule 1
Original number: 17772253754 Translated number: 18452055545
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
So then it should match my outdoing dial peer to CUCM right?
dial-peer voice 1 voip
description to/from cucm publisher
destination-pattern 18452055545
voice-class codec 1
dtmf-relay rtp-nte
no vad
Nope.. doesnt work .. any of it.
I 'love' parsing through the debug where it saying "Match not found on Incoming called number: 17772253754" even those thats exactly on the inbound dial-peer.
02-20-2014 12:29 PM
Dont give up yet..I opened a TAC case today because of this issue!! As we speak I am trying to simulate this and use the work around provided by TAC.not too different from what we have done so far..
I will come back to you shortly..Are you available to work on this right now?? Do you have webex?
02-20-2014 12:33 PM
I'm happy to give you the login info for my callcentric account - its just my lab account - you are free to build the entire thing in your lab to replicate the issue if you'd like (send me an email to andrew [at] kcexec.com outside the forum here and I'll provide the login detail).
Yes - I have a webex/teamviewer access if you want to hop on and look at the issue that way.
Andrew
02-20-2014 12:48 PM
First of all remove the translation profile uder this dial-peer..
no translation-profile incoming Incoming
2..change the destination-pattern on this dial-peer to17772253754
destination-pattern 17772253754
voice-class codec 1
dtmf-relay rtp-nte
no vad
Make only this changes and send me the ff:
debug ccsip info
debug ccsip mess
debug voip ccapi inout
I am waiting!
02-20-2014 01:03 PM
Here's the debugs with the requested changes.
voice-class codec 1
voice-class sip copy-list 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
02-20-2014 01:09 PM
....................... SO HAPPY... cant explain any of it... debug says no match yet it still matches and adjusts the header translation and sends the call out to CUCM with the correct modified header. I'll be interested to see what you think.
019021: Feb 20 15:01:11.729: //6176/F644081C837B/SIP/Info/sipSPISendInvite: Associated container=0x49A93EA4 to Invite
019022: Feb 20 15:01:11.733: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_req_uri: Req URI before modification : INVITE sip:17772253754@192.168.1.200:5060 SIP/2.0
019023: Feb 20 15:01:11.733: //6176/F644081C837B/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: Node found: COPY variable: u1 val: 18452055545
019024: Feb 20 15:01:11.733: //6176/F644081C837B/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: substituted_replace_pattern : INVITE sip:18452055545
019025: Feb 20 15:01:11.733: //6176/F644081C837B/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: configured_replace_pattern : @\1
019026: Feb 20 15:01:11.733: //6176/F644081C837B/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: substituted_replace_pattern : INVITE sip:18452055545@\
019027: Feb 20 15:01:11.733: //6176/F644081C837B/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: configured_replace_pattern : 1
019028: Feb 20 15:01:11.733: //6176/F644081C837B/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: Final substituted_replace_pattern : INVITE sip:18452055545@\1
019029: Feb 20 15:01:11.733: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_req_uri: Passing substituted replace pattern
019030: Feb 20 15:01:11.733: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_req_uri: Req URI after modification : INVITE sip:18452055545@192.168.1.200:5060 SIP/2.0
019031: Feb 20 15:01:11.733: //6176/F644081C837B/SIP/Info/sipSPIUpdateCallEntry:
Call 6176 set InfoType to SPEECH
019032: Feb 20 15:01:11.737: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 56
019033: Feb 20 15:01:11.737: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 61
019034: Feb 20 15:01:11.737: //6176/F644081C837B/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
019035: Feb 20 15:01:11.737: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
019036: Feb 20 15:01:11.737: //6176/F644081C837B/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
019037: Feb 20 15:01:11.737: //6176/F644081C837B/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
019038: Feb 20 15:01:11.737: //6176/F644081C837B/SIP/Info/sipSPICreateRtpSession: sess: 486A33A4 do_rtcp:0
019039: Feb 20 15:01:11.737: //6175/F644081C837B/SIP/Info/ccsip_update_peer_caps: Stream is NULL
019040: Feb 20 15:01:11.737: //6175/F644081C837B/SIP/Info/ccsip_update_peer_caps: gccb/stream is NULL, not updating now !!
019041: Feb 20 15:01:11.737: //6176/F644081C837B/SIP/Info/sipSPIUpdateGccb: Failure from the peer leg so no updations now!!
019042: Feb 20 15:01:11.741: //6176/F644081C837B/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK18D411B7
From: <>>18165297500@callcentric.com>;tag=1537CB50-19F9
To: <17772253754>
Date: Thu, 20 Feb 2014 21:01:11 GMT
Call-ID: F6503D05-99A811E3-8381E4C3-DC5CB4B2@192.168.1.203
Min-SE: 1800
Cisco-Guid: 4131653660-2577928675-2205934787-3697063090
CSeq: 101 INVITE
Timestamp: 1392930071
Expires: 180
Max-Forwards: 7
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 30918165297500>17772253754>
v=0
o=CiscoSystemsSIP-GW-UserAgent 6875 1675 IN IP4 192.168.1.203
s=SIP Call
c=IN IP4 192.168.1.203
t=0 0
m=audio 18466 RTP/AVP 18 0 8 101
a=fmtp:18 annexb=no
a=fmtp:101 0-16
02-20-2014 01:15 PM
can you send me a webex invite..just post the link here..
02-20-2014 02:24 PM
Wrap up... OK so its works now
I've attached the final running config - NOTE this doesnt have outbound working (that will require some more work) but inbound with DID routing works
The attached logs
'final-debug.log' is the ccsip debug messages & info showing calling on 2 did's.
'debug voip ccapi inout' shows the dial-peer matching.
'final-running-config.log' is the running config with did matching - note that outbound with caller id isnt setup yet.
HUGE Thanks for Aok and everyone on the forum for the help.
- Andrew
