02-14-2014 10:43 PM - edited 03-16-2019 09:45 PM
I have a SIP trunk from call centric that goes into my lab gear - they appear to be a good sip service due to cost but I'm having some trouble getting calls to route correctly. The call flow is Callcentric.com ITSP (SIP) --> 2811 (acting as cube) -->SIP Trunk --> CUCM 8.6. Phones are registered to CUCM.
I have the sip trunk registered and calls come in to the router (I see them in ccsip message/call debugs) The 2811 running 15.1(4)M7). Callcentric sends the username of the customer in the sip Invite instead of the called number, the called number is in the TO field. I have several DID’s from Callcentric (18452055544, 18452055545, 18452055546) for my lab. There are a few configs on here for CME where the customer number (17772253754) is simply translated to their phone DN - which is fine if you only have 1 DN with callcentric but more than 1 and thats not feasible since every inbound did will be matched to that 17772253754 translation/phone dn.
I’m using the a guide from http://tblog.cisco.be/2011/02/17/cube-conditional-sip-profiles/ using the Copy function as described http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-software-release-15-1-3-t/product_bulletin_c25-635704.html
I haven’t been able to find anything where they actually explain all the header fields so Its mostly trial and error.. so far mostly error. I think I’m close.. but who knows. Any assistance would be greatly appreciated
voice class sip-profiles 1
request INVITE peer-header sip TO copy ".sip:(.*)@." u01
request INVITE sip-header SIP-Req-URI modify ".*@(.*)" "INVITE sip:\u01@\1"
CUCM (single/pub)- 192.168.1.200
2811 acting as cube - 192.168.1.203
Calling Number - 18165297500
Called Number - 18452055544
vrtr1#show sip register status
Line peer expires(sec) registered P-Associ-URI
17772253754 -1 20 yes
vrtr1#
The Call Setup Information is:
Call Control Block (CCB) : 0x49646C28
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 18165297500
Called Number : 17772253754 (my customer number not called number)
Source IP Address (Sig ): 192.168.1.203 (my 2811 router)
Destn SIP Req Addr:Port : 204.11.192.159:5080
Destn SIP Resp Addr:Port : 204.11.192.159:5080
Destination Name : 204.11.192.159
Feb 14 11:20:53.303: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:17772253754@192.168.1.203:5060 SIP/2.0
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-805ff2443b18502ff96181045b62dd74
f: <sip:18165297500@66.193.176.35>;tag=3601387252-874282
t: <sip:18452055544@ss.callcentric.com>
i: 2917398-3601387252-874253@msw2.telengy.net
CSeq: 1 INVITE
Max-Forwards: 8
m: <sip:ca7fe50c9cebe12327fe0d63c5962a3e@204.11.192.159:5080;transport=udp>
Supported: timer
c: application/sdp
l: 350
v=0
o=NexTone-MSW 2147483647 2147483647 IN IP4 204.11.192.159
s=sip call
c=IN IP4 204.11.192.159
t=0 0
m=audio 61094 RTP/AVP 18 0 8 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=rtpmap:101 telephone-event/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=ptime:20
a=sendrecv
a=silenceSupp:off - - - -
a=setup:actpass
Feb 14 11:20:53.327: //936/310B294680AD/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-805ff2443b18502ff96181045b62dd74
From: <sip:18165297500@66.193.176.35>;tag=3601387252-874282
To: <sip:18452055544@ss.callcentric.com>
Date: Fri, 14 Feb 2014 17:20:53 GMT
Call-ID: 2917398-3601387252-874253@msw2.telengy.net
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
SIP/2.0 404 Not Found
To: <sip:18452055544@ss.callcentric.com>;tag=35399D8-63
CSeq: 1 INVITE
Reason: Q.850;cause=1
Content-Length: 0
Feb 14 11:20:53.419: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:17772253754@192.168.1.203:5060 SIP/2.0
t: <sip:18452055544@ss.callcentric.com>;tag=35399D8-63
CSeq: 1 ACK
Max-Forwards: 10
l: 0
u all
Feb 14 11:20:57.067: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:18452055544;cic=0288;rn=6465471001;npdi@alpha14.callcentric.com:5070 SIP/2.0
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-6bceae47efe9f53b4234698a32ac8beb
CSeq: 1 ACK
Max-Forwards: 8
l: 0
************************** Running Config **************************
sh run
vrtr1#sh running-config
Building configuration...
Current configuration : 4189 bytes
! Last configuration change at 00:34:03 CST Fri Feb 14 2014
! NVRAM config last updated at 20:26:58 CST Thu Feb 13 2014
version 15.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname vrtr1
boot-start-marker
boot system flash:
boot system flash flash:c2800nm-ipvoicek9-mz.151-4.M7.bin
boot-end-marker
card type t1 0 0
logging buffered 4096 notifications
enable password cisco
no aaa new-model
memory-size iomem 5
clock timezone CST -6 0
clock summer-time CST recurring
no network-clock-participate wic 0
dot11 syslog
ip source-route
ip cef
ip name-server 192.168.1.9
no ipv6 cef
voice service voip
ip address trusted list
ipv4 192.168.1.0 255.255.255.0
ipv4 204.11.192.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
registrar server expires max 1800 min 1800
localhost dns:callcentric.com
outbound-proxy dns:callcentric.com
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice-card 0
license udi pid CISCO2811 sn FTX1133A4QR
controller T1 0/0/0
cablelength long 0db
description ** LAN **
ip address 192.168.1.203 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.1.203
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
snmp mib persist circuit
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.1.200
ccm-manager config
mgcp
mgcp call-agent 192.168.1.200 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
dial-peer voice 999100 pots
service mgcpapp
port 0/1/0
dial-peer voice 999101 pots
service mgcpapp
port 0/1/1
dial-peer voice 999102 pots
service mgcpapp
port 0/1/2
dial-peer voice 999103 pots
service mgcpapp
port 0/1/3
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 6 voip
description ## INBOUND DID to CUCM ##
session protocol sipv2
session target ipv4:192.168.1.200
incoming called-number 17772253754
voice-class sip profiles 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 7 voip
incoming called-number 1845205554[4-5]
no vad
sip-ua
credentials username 17772253754 password 7 106C1B49111F17194D realm callcentric.com
authentication username 17772253754 password 7 08035E1E1D11000553 realm callcentric.com
no remote-party-id
retry invite 2
retry register 10
timers connect 100
mwi-server dns:callcentric.com expires 3600 port 5060 transport udp
registrar dns:callcentric.com expires 3600
sip-server dns:callcentric.com
host-registrar
line con 0
line aux 0
line vty 0 4
password cisco
login
transport input all
scheduler allocate 20000 1000
ntp server 199.102.46.72
ntp server 23.227.162.123 prefer
end
exit
Solved! Go to Solution.
02-20-2014 03:53 PM
Andrew,
Good stuff..Glad we could help. You might want to mark the thread as answered..It help others to know what the resolution is
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
02-20-2014 04:13 PM
Hi all.
Deji, great great and again great job!!!!
Just for this case you should receive the VIP designation for at least next 10 years my friend :)
Andrew, you have been so lucky to have been follwed by that man, because you can be sure that your issue is solved if he puts his hands on.
Again Congrats!!!
Now, just out of curiosity, which was the solution? :)
Cheers
Carlo
02-20-2014 04:26 PM
Carlo, thank you my friend for the kind words..
There were three major issues...
1. sip outbound-proxy issue where all calls orginating from the CUBE was sent back to the provider even though the sip headers looked like they were sent to CUCM..You can read the analysis of that on the thread with this time stamp
16-Feb-2014 15:02 (in response to whatuusay1)
2. The ITSP didnt specify session timer, hence CUBE was sending a Require header in the 200 OK and they didnt like it. So I removed the Require header in the 200 Ok response:
response 200 sip-header Require remove
3. The third issue was routing calls based on the To header. The ITSP was sending the called number in the To header and the authentication DDI in the RURI..This was rather complicated due to the voice translation rules messing up the sip profiles.. You can see the solution on this time stamp..
20-Feb-2014 21:06 (in response to Ayodeji oladipo Okanlawon)
The following sip profiles were used..
request INVITE peer-header sip TO copy "sip:(.*)@" u01
voice class sip-copylist 1
sip-header TO
