04-08-2011 07:03 AM - edited 03-16-2019 04:25 AM
Somebody can say me why the Called# column is blank when I'm using the IOS command "show voice call status" ?
For exemple :
#sh voice call status
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x29C6 267B 0x191C6364 0/1/0:15.8 0/1:4 * g711ulaw 0/0
0x29C8 267C 0x02311588 0/0/0:15.29 0/1:5 * g711ulaw 0/0
0x2A58 26C4 0x191C6364 0/1/0:15.11 0/1:7 * g711ulaw 0/0
0x2A5A 26C5 0x02311588 0/0/0:15.28 0/1:15 * g711ulaw 0/0
0x2B0C 271B 0x02311588 0/0/0:15.31 0/1:1 * g711ulaw 0/0
0x2B0E 271C 0x191C6364 0/1/0:15.24 0/1:2 * g711ulaw 0/0
0x2B10 271D 0x02311588 0/0/0:15.30 0/1:3 * g711ulaw 0/0
0x2B12 271E 0x02311588 0/0/0:15.27 0/1:6 * g711ulaw 0/0
8 active calls found
It's not realy blank but just a star and not the called number.
Best Regards
Solved! Go to Solution.
04-08-2011 09:56 AM
Alexandre,
The show voice commands are written for use when the gateway controls the call via SIP/H.323 and don't get much information when CUCM controls the call via MGCP. What you are seeing is what the voice subsystem in the router knows about a call from a L1 / L2 perspective. CLID is Layer 3.
If you want to see if a particular call is going out correctly you can watch the output of debug isdn q931.
-Steven
04-08-2011 10:42 AM
MGCP and SCCP don't provider called/calling party information to the router since the dialplan/call routing is handled on the CA. Hence that output won't contain the information, since the router is unaware of the calling/called numbers.
You need to use SIP or H323 if you want those fields to populate.
04-08-2011 09:11 AM
Alexandre,
Is this an MGCP gateway?
04-08-2011 09:25 AM
Yes this is an MGCP gateway
04-08-2011 09:56 AM
Alexandre,
-Steven
06-04-2015 11:02 AM
Steven,
I'm curious about this answer. You see I am seeing the configuration of the same router (MGCP gateway) from Version 15.0(1)M4 where I can see the Called # there and then from Version 15.3(3)M3 where I can see the Called # as *.
So is your answer conditional to certain versions of the IOS?
-Leo
04-08-2011 10:42 AM
04-08-2011 10:53 AM
Thanks a lot, I didn't know this point
