03-20-2018 11:03 PM - edited 03-17-2019 12:27 PM
Got a query more on CUCM, appreciate if anyone can suggest.
Call flow
IP PHONE(SIP 7841) - CUCM - SIP trunk - CMS server - Conference Number (8899)
Caller with Cisco IP phone dials 8899 to connect to the conference hosted on CMS server , and see display connected to 8899 on the phone screen.
User requirement is to see the called connected in +e164 format (+6565XXX899) reflected on the IP phone screen.
Is there any way to achieve it ? It more of a cosmetic requirement and changes on the CUCM.
03-20-2018 11:23 PM
This is more on your dial plan.
Check the calling party transformation mask and called party transformation mask in CUCM.
Login to CUCM and navigate to Call Routing > Transformation > Transformation Pattern.
03-20-2018 11:43 PM
Thanks for the reply.
Our currently dialing is +E164 now. But the destination number is set as 8899 on CMS server.
If we do called number transforming , it will change the called number and the call will fail.
User wants the display to be shown as +e164. However the destination number remains 8899 for successfully connecting to the CMS conference.
03-20-2018 11:23 PM
03-20-2018 11:44 PM
03-21-2018 01:22 AM
03-21-2018 01:54 AM - edited 03-21-2018 01:55 AM
CMS side wont recognize '+' while creating conference number.
So just want a change on CUCM to meet this cosmetic requirement.
So that even IP phone connects to 8899 , the phone display shows connected to an +E164 number.
Is there anything other changes which can be done in CUCM ?
