07-21-2016 02:52 PM - edited 03-18-2019 12:02 PM
I am trying to simulate PSTN in my lab. I have CUCM 9.1 and configured a t1 on a H323 gateway and I get a called party number as '0'. I also haveCME connected to PSTN router and I have the same issue there too..
Any help is much appreciated
PHONE --->CUCM --->H323-GW(T1)---->PSTN<-----CME
HQ_RT#
HQ_RT#
*Jul 21 21:42:39.094: ISDN Se0/1/0:23 Q931: pak_private_number: Invalid type/plan 0x0 0x1 may be overriden; sw-type 2
*Jul 21 21:42:39.094: ISDN Se0/1/0:23 Q931: Applying typeplan for sw-type 0x2 is 0x2 0x1, Calling num 4000
*Jul 21 21:42:39.094: ISDN Se0/1/0:23 Q931: Sending SETUP callref = 0x009A callID = 0x801B switch = primary-4ess interface = User
*Jul 21 21:42:39.094: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x009A
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98390
Exclusive, Channel 16
Calling Party Number i = 0x2181, '4000'
Plan:
HQ_RT#ISDN, Type:National
Called Party Number i = 0xA1, '0'
Plan:ISDN, Type:National
*Jul 21 21:42:39.110: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x809A
*Jul 21 21:42:39.110: ISDN Se0/1/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x809A
Cause i = 0x8281 - Unallocated/unassigned number
*Jul 21 21:42:39.114: ISDN Se0/1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x009A
*Jul 21 21:42:39.118: ISDN Se0/1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x809A
Here is H323-GW config
HQ_RT#SH RUN
Building configuration...
Current configuration : 3982 bytes
! Last configuration change at 20:32:22 UTC Thu Jul 21 2016
version 15.3
hostname HQ_RT
boot-start-marker
boot-end-marker
card type t1 0 1
! card type command needed for slot/vwic-slot 0/2
! card type command needed for slot/vwic-slot 0/3
! card type command needed for slot/vwic-slot 1/1
no aaa new-model
memory-size iomem 20
network-clock-participate slot 1
network-clock-participate wic 1
ip cef
ip dhcp pool data
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
ip dhcp pool voice
network 192.168.4.0 255.255.255.0
default-router 192.168.4.1
option 150 ip 192.168.3.20
no ipv6 cef
isdn switch-type primary-4ess
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
call preserve
license udi pid C3900-SPE150/K9 sn FOC17283QBC
hw-module pvdm 0/0
hw-module sm 1
redundancy
controller T1 0/1/0
cablelength long 0db
pri-group timeslots 1-3,16,24
controller T1 0/1/1
interface Loopback0
ip address 10.10.10.1 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.10.1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 172.10.10.20 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.2
description Connection to 2nd ESXi
encapsulation dot1Q 2
ip address 172.27.0.1 255.255.255.0
interface GigabitEthernet0/1.30
description DATA int
encapsulation dot1Q 30
ip address 192.168.3.1 255.255.255.0
interface GigabitEthernet0/1.40
description VOICE int
encapsulation dot1Q 40
ip address 192.168.4.1 255.255.255.0
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/1/0:23
description "port to PSTN"
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/1.40
sccp ccm 192.168.3.20 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register HQXCODE
associate profile 1 register HQCONF
dspfarm profile 2 transcode
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
associate application SCCP
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g722-64
maximum sessions 4
dial-peer voice 1 voip
destination-pattern 400[0-9]
session target ipv4:192.168.3.20
dtmf-relay h245-alphanumeric
dial-peer voice 2 pots
destination-pattern 300[0-9]
direct-inward-dial
port 0/1/0:23
dial-peer voice 3 pots
incoming called-number .%
gatekeeper
shutdown
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
line con 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
logging synchronous
login
transport input all
scheduler allocate 20000 1000
end
07-21-2016 04:00 PM
I got my issue fixed after adding forward-digits all on the dial-peers.. Thanks
