called party number incomplete
ivan aguilar
When I place a call to PSTM throught a BRI port, in a CME 8 the telephone try to place that call sending only 4 digits, when I am introducing the digits, in the 4º digits stop and try to send the call.
Progress Ind i = 0x8183 - Origination address is non-ISDN
       Calling Party Number i = 0x0080, '4110'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '630'
        Sending Complete
Jul 18 13:20:52.155: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xC4
        Channel ID i = 0x89
                Exclusive, B1
Jul 18 13:20:52.175: ISDN BR0/0/0 Q931: RX <- PROGRESS pd = 8  callref = 0xC4
        Cause i = 0x829F - Normal, unspecified
        Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
        Progress Ind i = 0x8A88 - In-band info or appropriate now available
Jul 18 13:20:56.139: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x44
I have checked interdigits timeout, and it is set to 5, dial-peer are correctly configurated
RouterVallecas#sh dialplan number 0630112233
Macro Exp.: 0630112233
VoiceEncapPeer210
        peer type = voice, system default peer = FALSE, information type = voice,
        description = `Moviles',
        tag = 210, destination-pattern = `06........',
        voice reg type = 0, corresponding tag = 0,
        allow watch = FALSE
        answer-address = `', preference=1,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        rtp-ssrc mux = system
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 210, Admin state is up, Operation state is up,
        Outbound state is up,
        incoming called-number = `', connections/maximum = 0/unlimited,
        DTMF Relay = disabled,
        URI classes:
            Destination =
        huntstop = disabled,
        in bound application associated: 'DEFAULT'
dial-peer voice 210 pots
description Moviles
preference 1
destination-pattern 06........
port 0/0/0
forward-digits 9
If I try to place a call to other number always is the same result, 091....... only place 4 digits, and so on.
Any idea where could be the problem?
Thanks!!
paolo bevilacqua
Already replied in another thread, please do not post duplicates.
sorry, was my internet connection who duplicate the post.
regards.
