Caller from outside cannot hear
Tazio4436
We got some complaints that when someone is calling from outside he cannot hear us but we can hear them.
If we call from inside to inside there is no problem.
If we call from inside to outside there is no problem , both party can hear.
We are using couple of PRI lines (all the lines having same problem) with cisco call manager and unity.
Any help will be much appreciated.
No change has been done
Tazio
2 Accepted Solutions
Thank you very much. It helped a lot and everything working now
Tazio
@Tazio4436 If all works as expected and your query is answered please mark the post as solved and give the appropriate appreciation to the answers you got.
Response Signature
5 Replies 5
Check the Controller if  there is any errors. use command show controller E1/T1..
If you find any errors Check if you configured network clock commands
I will also recommend you to open a ticket with your ISP. One way   Audio problems  are also seen with ISP issues.
Try to ping the phone subnet from the gateway interface.(Use the interface binded for media)
Response Signature
Tazio
Response Signature
Thanks a lot everyone
Tazio
Even if it's is nice of you to mark me as the one providing the solution to your question I would think that @Nithin Eluvathingal would be more applicable.
Response Signature
