I have cisco cluster version 8.0 intgrated with nortel PBX here is the call flow .
Telco E1 -------cisco router H323--------callmanager-----router MGCP (PRI)--------nortel---- set
the caller ID from the PSTN is not showing in nortel sets.
Please advise.
Regrads,
Ali Nasser
is it showing in the CM side ?
can you debug the MGCP router and see if you sending the Caller ID
if all the above are yes then check the Nortel Pri side if dose accept it and dose not block it
1- when a call is comming from PSTN and going to Cisco extension then the calling number is showing.
2- when a call is comming from PSTN and goinmg to Nortel extension then the calling number is not showing
3- when a call is comming from PSTN and going to Cisco extension after that the user transfer the call to Nortel extension then the calling number is showing correctly
note that in the three tests the PRI links on the VG is MGCP. we did debugs on the MGCP gateway (debug isdn q931 and debug mgcp inout). from the output it is showing that the calling number is sent through the PRI link but the debug from Nortel side does not show that it is received. the debug output is attached (calling number is 90555767324 and called Nortel set is 3038)
the serial interface for the PRI link is configured as below:
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn supp-service name calling
isdn bind-l3 ccm-manager
no cdp enable
For testing we converted the gateway (PRI links) in H323 and test a call direct from PSTN to Nortel set and the calling number was showing correctly. We have to use MGCP instead of H323 for some other limitation.
please advice if we can modify any parameter to enable the calling number in MGCP
regards,
Ali Nasser
hi Ali
in the isdn setup we are sending caller id with i = 0x7A83
when you decode the i value via q931 rfc : http://www.itu.int/rec/T-REC-Q.931-199805-I/en
Ext type of number Numbering Plan Identification ext Presentation-indicator Spare Screening
0 111 1010 1 00 (Presentation allowed) 000 11
we are sending the number with the needed i value for nortel to display .
thanks
Haitham
Hi Haitham,
thanks for the reply. Do you mean that the issue is from Nortel side? if yes why the calling number is displayed if the gateway is H323 and not displaying if it is MGCP?
note that the calling number is also displayed if the call is transfered from cisco to nortel phone (in MGCP case)
regards,
Ali Nasser
it looks like somthing mismathing between both sides
canmake sure in the callmanager side under the MGCP GW setting the show calling number/ID set to allowed not to default then save and reset
and try it
H323 and MGCP wont differ in this case (it will if you connect to Nortel through fxs/fxo as the caller id won’t work on MGCP as its not supported ) .
Just to double check , Can you send me the isdn q931 debugs for both MGCP and h323 ?
Haitham
When you call the Nortel internally - does the number appear?
Check the CLS of the Nortel TNB`s -
CNDA Call Party Name Display Allowed
CNID Call Number Information Denied
DDGA DN Display on other set Allowed
DNDA Dialed Name Display Allowed
