854
Highlighted
Beginner
Caller ID issue
Hi all,
I have query whether we can able to change incoming number as Display name.
For Example:
My name is Naveen, My Contacts like Mobile and Work Number are integrated with my LDAP in our CUCM
So, Whenever users searching my contact in Jabber / Corporate Directory, it will displays like Work : 461281 and Mobile : +1(10-digit Mobile Number)
Issue is : I calling to one of the user to his Work PSTN Number like 001(10-digit number) and in user's cisco ip phone it will shows like 91(my mobile number).
is it possible to show my name instead of displaying my mobile number because My mobile number is configured with my LDAP
is it possible to change incoming calling number as +1(my mobile number) instead of 91(mobile number)
1 ACCEPTED SOLUTION
Highlighted
Hi Naveen,you need the 3rd
Hi Naveen,
you need the 3rd party directory app, this is one of available supporting Cisco Jabber - http://aurus5.com/phoneup/directory/ (check "Cisco Jabber Interface" section).
6 REPLIES 6
Highlighted
Hall of Fame Cisco Employee
No, this has been asked
No, this has been asked PLENTY of times before, CUCM does not provide that feature.
Please search CSC for answers before posting.
java
if this helps, please rate
Highlighted
Beginner
Hi Jamie,Thanks for the reply
Hi Jamie,
I jus tried to search this kind of thing but there is no discussion.
that's why I started this discussion.
One query:
Highlighted
I meant matching an ANI to a
I meant matching an ANI to a name as a mobile does. And that, I can assure you, has been discussed plenty of times at CSC.
Yes, you can use calling party transformation masks to do what you're asking.
java
Highlighted
Hi Naveen,
Highlighted
Beginner
Hi Alexander, Thanks for the
Hi Alexander,
Thanks for the reply.
How it will works. we need integrate with CUCM or we need install app in local machine ??
Highlighted
You'll need to install the
You'll need to install the product on windows server (virtual machine is ok) and integrate it with CUCM. Please leave the request on our website and we'll provide the software, docs and tech assistance.
