02-24-2021 04:48 AM - edited 02-24-2021 04:51 AM
Hi All
We have a requirement to display our caller ID when dialling outbound, at the moment we have multiple ranges going over 3 ISDN 30 lines, BT have just enabled type 5 option for us which allows us to show the original DDI even though the range may not be part of that ISDN when dialling out.
I have checked on our gateways and done a debug, I can see the original number going out, but this does not show up on my mobile, it seems to still hide behind the main number of the line.
The settings we have are below,
Any ideas guys?
interface Serial0/0/0:15
description IMTT209593
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn outgoing display-ie
isdn outgoing ie redirecting-number
no cdp enable
interface Serial0/0/1:15
description IMTT209592
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/0/0:15
translation-profile incoming PSTN-IN-1-0
translation-profile outgoing PSTN-OUT-1-0
echo-cancel coverage 48
no vad
cptone GB
bearer-cap Speech
voice-port 0/0/1:15
no vad
cptone GB
bearer-cap Speech
dial-peer voice 9 pots
tone ringback alert-no-PI
description *** ALL OUT PEER ***
destination-pattern 9T
progress_ind alert enable 8
port 0/0/0:15
dial-peer voice 29 pots
preference 2
clid restrict
port 0/0/1:15
Debug from Gateway attached
Solved! Go to Solution.
03-05-2021 07:53 AM
Hi Roger
I could do with your help again if possible?
I have had another call that has defaulted to the main number of the ISDN line today, I really need to sort this as they are calling back the most senior person in the company.
Basically I put the catch all rule in as you suggested rule 10 /.*/ /18815012345/ type unknown national
We have had a call transferred from our switchboard to a mobile, and it has defaulted to the main number, the "calling number was 049363310847120 (some digits changed for security), would our gateway be able to handle this in the catch all? it appears it didnt work
cheers
03-05-2021 07:59 AM
Looking at the length of the number, could that be an international caller? If so, and the number type was "international" then it won't have matched your rule 10 which matches absolutely any length of contents of the number, but only if the type is "unknown".
That's why I recommended ..
rule 10 /.*/ /1988123456/ type any national
03-05-2021 08:12 AM
As Tony suggested change the match for type of number to any instead of unknown. See my breakdown of the rules for additional information on this. With the rule you have it has to match both the number part, and it will always do this, and it has to match the type part. If the type of number comes in as anything other than Unknown it will not match.
06-01-2021 01:29 AM
Hi Roger
I hope you are well,
For some reason, we still get the odd call going out to BT which they are defaulting the number to the main ISDN number instead of our translation below
rule 10 /.*/ /1899596779/ type any national
Is there any reason why the above is not working for some calls? is there anything I can do ?
Cheers
06-01-2021 02:21 AM
For these rogue calls, do you have an example of the calling number that would have been passed to your gateway? If so then you can have a quick check of your translation rule using this number to make sure it is being matched. For example using the rules you showed earlier I can test for a calling number of 1234567890 and let's say type International while we're at it ...
sh run | s translation-rule voice translation-rule 101 rule 1 /^4\(...\)$/ /1871594\1/ type unknown national rule 2 /^3\(...\)$/ /1871593\1/ type unknown national rule 3 /^6\(...\)$/ /1871506\1/ type unknown national rule 10 /.*/ /1988123456/ type any national R1-HUB1#test voice translation-rule 101 1234567890 type international Matched with rule 10 Original number: 1234567890 Translated number: 1988123456 Original number type: international Translated number type: national Original number plan: none Translated number plan: none
If you don't have any examples, it's going to be a matter of monitoring the debugs to see what you're putting out to the service. It may well be a BT issue.
