524
Michael Horton
Beginner
Caller ID on VG310 ports
I have an MGCP-configured VG310 that I enabled caller-id on all of the voice ports. However, once registered with CallManager, the caller-id command is removed from the voice port config. Is there a command in CM that removes that setting, something that didn't affect VG224s?  The VGs are on the latest firmware release (157-3M) and our CallManager is running 11.5.2.  Thanks for any help you can give me with this.
1 ACCEPTED SOLUTION
BradEast1
Participant
Not seeing anything that can be done at the CUCM level. Only suggestions I can make is to remove the "ccm-manager config" command...
1 REPLY 1
BradEast1
Participant
Create
Recognize Your Peers
Content for Community-Ad
