Highlighted
Beginner
Caller ID problem on Device profiles
Hi everybody,
I have a user 'X' complaining that when he makes a call, his caller ID displayed on the called device isn't 'X', the caller ID displayed is 'Y' which is the name of the user that used to have this number.
So I checked the user's dn parameters, and I've found out that the alerting name and the display fields are correctly configured to 'X'.
Can you, guys, give me some tips how to solve this problem?
Thanks in advance.
6 REPLIES 6
Rising star
Does the Caller ID show up
Does the Caller ID show up incorrectly for internall calls or external? Or both?
Beginner
They're incorrectly shown up
They're incorrectly shown up on both calls: internal and external
Rising star
Are the directory numbers
Are the directory numbers assigned straight to the phones themselves or are you using extension mobility?
Can you screenshot where you are setting the Caller ID under this directory number and post this?
Beginner
Directory numbers are
Directory numbers are assigned to a device profile and they are accessed using extension mobility.
These are the fields that are configured:
- Alerting Name
- ASCII Alerting Name
- Display (Internal Caller ID)
Rising star
If you change the Caller ID
If you change the Caller ID to something random, like 'John Smith' and test, what happens?
Is this happening on any other phone?
I would try a factory reset on the phone and get the user to login again.
Beginner
Actually after investigation,
Actually after investigation, it is most likely a database replication problem within the CUCM cluster.
Thank you your help, Advocate.
Content for Community-Ad
August's Community Spotlight Awards
