11-19-2017 09:13 AM - edited 03-17-2019 11:37 AM
I have 200 dids,and 250 phone I want to assign 50 non did numbers and assign a caller id 2430XXXX for outgoing (external) call .
And another non did xxxx I want to assign caller id internaly(yyyy)and externaly 2430YYYY
How can i do that?
Solved! Go to Solution.
11-19-2017 10:10 AM
11-19-2017 10:10 AM
11-19-2017 10:54 AM
I used External Phone Number Mask under line settings .I Could see it on the display panel (2430yyyy).
But when I dialed it was showing xxxx not 2430yyyy
11-19-2017 09:59 PM
Is there a way to mask the internal also
xxxx from to yyyy
