10-07-2012 06:38 AM - edited 03-16-2019 01:33 PM
Hello Friend,
I have a problem on CallerID of PSTN lines on my CME. I,ve enabled the caller ID under the voice-ports but the phones doesn't show the caller ID. I tested caller ID with nomal phones. It seems that the CO sends the caller ID before the first ring. I added caller id ring alert 1|2 command under the voice-port but the problem still exist. As I checked the command refrence, there is other caller ID related commands but those commands are not shown in router's CLI. Can you please to solve this issue?
Thank you
10-07-2012 07:04 AM
Which verion of IOS you using? Its working before,have you done any changes ?Can you provide me with the configuration
10-07-2012 07:17 AM
10-07-2012 07:42 AM
10-07-2012 12:48 PM
As I mentioned some commands seems to be not supported under the voice port configuration.
CME-2811(config-voiceport)#caller-id alerting ?
ring during ring
As you see dsp-pre-alloc is not in CLI output.
