Showing results forĀ
Search instead forĀ
Did you mean:Ā
CallForwardAll offnet-to-offnet calls failure
Aaziz AMHAOUCH
Hi all,
I have a problem on ForwardAll of offnet to offnet call : if an end user make a ForwardAll on his IP Phone to his cell phone, and when he received an external call the forward can't be made but when he received an  internal call the forward works. The Block offnet to offnet Transfer Service parameter is set to false.
We have a CUCM 7.5, and 2911 gateway with PRI link to isdn.
Any help!
Best regards
6 Replies 6
nikshah
if you can send the traces for a bad call, along with calling and called party information and the forward call information.
Ayodeji Okanlawon
Have you checked the CSS on the cfwdall. It need access to the partiton for the RP to dial out
Please rate useful posts
"I am complete in God, God completes me"
Please rate all useful posts
Thanks for your replies;
the CSS on  cfwdall have access to route pattern partition as I said when end user received an internal call the forward works. I'll send the traces asap.
here is debug isdn q931 of a call forward failure
PHONEA: A cell phone who make a call
3038: the ipphone who make a CallForwardAll to a cellphone number PHONEB
PHONEB: the cell phone of end user
*Jun  6 11:01:52.525: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref =        0x0C36
*Jun  6 11:01:53.545: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x218A
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Calling Party Number i = 0x0180, 'PHONEA'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '3038'
*Jun  6 11:01:53.545: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0xA18A cal        lID = 0x46EE switch = primary-net5 interface = User
*Jun  6 11:01:53.549: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x        A18A
*Jun  6 11:01:53.561: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 i        s 0x0 0x1, Calling num PHONEA
*Jun  6 11:01:53.561: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0C38 call        ID = 0x8B3B switch = primary-net5 interface = User
*Jun  6 11:01:53.561: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0C38
                Standard = CCITT
        Channel ID i = 0xA9839C
                Exclusive, Channel 28
        Calling Party Number i = 0x0181, 'PHONEA'
        Called Party Number i = 0x80, 'PHONEB'
                Plan:Unknown, Type:Unknown
*Jun  6 11:01:53.597: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x        8C38
*Jun  6 11:01:53.645: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x        8C38
*Jun  6 11:01:53.677: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0        x8C38
        Cause i = 0x82B9 - Bearer capability not presently authorized
*Jun  6 11:01:53.677: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0C        38
*Jun  6 11:01:53.693: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref =        0x8C38
if you see you are receiving a disconnect from the telco with the foll cause i
http://www.cisco.com/en/US/partner/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
you might want to engage and talk to the telco as to why are they rejecting the call
Please add the ff:
voice-port 0/0/0:15
bearer-cap speech
NB: Dont think this will make a difference because you are already doing speech to the telco. Just a long shot.
You can send a debug for a succesful internal call transfer and we can compare the difference..
