When i making outbound call through Cisco IP phone using SIP to any outside auto attendant i can list the welcome message but when i press extension the call gets fail.any idea ??
IP phone---- CUCM----VG----SIP--- SERVICEPROVIDER---DESTINATION(AUTOATTENDANT)
BR,
shib
Solved! Go to Solution.
I know why you are getting that error:
Do the ff:
rtp payload-type cisco-codec-fax-ack 98
then do this again and test
rtp payload-type nte 97
You need to configure dtmf-relay on the CUBE router.
will you please provide me the sample configuration ,,so will configue it ..
Thankyou in advance
Appreciate if someone provide me dtmf configuration ..
Start by finding out what sort of DTMF-relay your SIP provider supports
RF2833 is the most common dtmf method on sip trunks..Here is how to configure it
dial-peer voice xxx voip
dtmf-relay rtp-nte
Configure the dtmf on both your outbound dial-peer to your sip provide and also on your inboudn dial-peer to your CUBE and CUCM
I already done this configuration but still not wokring at all..
dial-peer voice 100 voip
description ** Outgoing Calls over SIP Trunk >> **
translation-profile outgoing test
destination-pattern .T
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target ipv4:10.205.20.50:5060
dtmf-relay rtp-nte digit-drop
codec g711ulaw
no vad
Can you send me the full config on your Gateway. Also what do you have set as your "DTMF Signaling Method" field on your sip trunk. You should set it to "No preference".
Can you do a test call and send a
debug ccsip messages
debug voip rtp session named-event
kindly find the debugs
ACCDMM-VGW01#
May 14 16:16:41.568: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.196.183.74:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKbxyi8xn7cy8ixxohu7ujhycun
Call-ID: lbykjcunnu77evibkihhneijjcx8o8v8@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 010.196.183.74>
May 14 16:16:41.572: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25764980-15BD
Date: Mon, 14 May 2012 16:16:41 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1
ACCDMM-VGW01#OPTIONS
Supported: 100rel,resource-priority,replaces
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Accept: application/sdp
Content-Type: application/sdp
Content-Length: 17010.196.183.74>
v=0
o=CiscoSystemsSIP-GW-UserAgent 4667 4394 IN IP4 10.196.183.74
s=SIP Call
c=IN IP4 10.196.183.74
t=0 0
m=audio 0 RTP/AVP 18 0 8 4 2 15 3
ACCDMM-VGW01#
May 14 16:16:51.568: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKolklc7uoyuh7uhjcych7xkjll
Call-ID: njynjey8hbijhyve7kluhhubjbu7ck8x@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:16:51.572: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25767090-13EF
Date: Mon, 14 May 2012 16:16:51 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 1352 2370 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:17:01.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKijoilhyiv7biyb7yoeouyhhcy
Call-ID: ibh8inoxuv8eeo77lybixvncolihl87u@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:17:01.572: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=257697A0-2207
Date: Mon, 14 May 2012 16:17:01 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 3883 3574 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:17:03.668: s=VoIP d=DSP payload 0x61 ssrc 0x2D243621 sequence 0x4979 timestamp 0xE830A758
May 14 16:17:03.668: <<
May 14 16:17:03.668: s=DSP d=VoIP payload 0x61 ssrc 0x2D243621 sequence 0x4979 timestamp 0xE830A758
May 14 16:17:03.668: Pt:97 Evt:2 Pkt:0C 00 A0
May 14 16:17:03.688: s=VoIP d=DSP payload 0x61 ssrc 0x2D243621 sequence 0x497A timestamp 0xE830A758
May 14 16:17:03.688: <<
May 14 16:17:03.688: s=DSP d=VoIP payload 0x61 ssrc 0x2D243621 sequence 0x497A timestamp 0xE830A758
May 14 16:17:03.688: Pt:97 Evt:2 Pkt:0C 01 40
May 14 16:17:03.708: s=VoIP d=DSP payload 0x61 ssrc 0x2D243621 sequence 0x497C timestamp 0xE830A758
May 14 16:17:03.708: <<
May 14 16:17:03.708: s=DSP d=VoIP payload 0x61 ssrc 0x2D243621 sequence 0x497C timestamp 0xE830A758
May 14 16:17:03.708: Pt:97 Evt:2 Pkt:8C 01 48
May 14 16:17:03.708: s=VoIP d=DSP payload 0x61 ssrc 0x2D243621 sequence 0x497B timestamp 0xE830A758
ACCDMM-VGW01#
May 14 16:17:03.708: s=DSP d=VoIP payload 0x61 ssrc 0x2D243621 sequence 0x497B timestamp 0xE830A758
May 14 16:17:03.708: s=VoIP d=DSP payload 0x61 ssrc 0x2D243621 sequence 0x497D timestamp 0xE830A758
May 14 16:17:03.708: s=DSP d=VoIP payload 0x61 ssrc 0x2D243621 sequence 0x497D timestamp 0xE830A758
ACCDMM-VGW01#
May 14 16:17:11.568: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bK8nknjhh8ub8cyikbclx8injou
Call-ID: uenvx8xlonjjnkulk7ueijcvncnionjj@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:17:11.572: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=2576BEB0-1387
Date: Mon, 14 May 2012 16:17:11 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 4469 6202 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:17:21.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKynjblj7jhoiyevijceh8lohbb
Call-ID: bc77uecuhhllockljjjuevoevenv7eec@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:17:21.572: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=2576E5C0-838
Date: Mon, 14 May 2012 16:17:21 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 9412 9334 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:17:31.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKncveybvnhclvvll7yv8jh7b8h
Call-ID: ncooeve7n87y8jkucovei7uxvlx7ynhk@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:17:31.572: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25770CD0-24E3
Date: Mon, 14 May 2012 16:17:31 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 3963 3930 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:17:41.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKnixo8byo7becuhjbblxcy8bxi
Call-ID: heccxx8k8j7yo8vjk8n8bhxvbiicujlu@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:17:41.572: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=257733E0-160E
Date: Mon, 14 May 2012 16:17:41 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 7941 9487 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:17:51.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKccejkcoyxcunhuexvjy7ehxyy
Call-ID: bec77eojeyk7lynbhynujlvhuilyxvh7@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:17:51.572: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25775AEC-1C0D
Date: Mon, 14 May 2012 16:17:51 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 5808 8683 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:18:01.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKvoeubjj7ihlycjueeyve8y7bj
Call-ID: 77hcn8v7kyjkn8ceklbivkl8yx8oe8yv@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:18:01.572: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=257781FC-993
Date: Mon, 14 May 2012 16:18:01 GMT
ACCDMM-VGW01#x
CSeq: 1 OPTIONS
v=0
o=CiscoSystemsSIP-GW-UserAgent 5892 5733 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:18:11.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKbiihynyxyc87xbl8uhbxeuvn8
Call-ID: kj8xbxuckvjv7jk8jxb7ococvxcvuhh8@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:18:11.568: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=2577A90C-765
Date: Mon, 14 May 2012 16:18:11 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 7763 5627 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:18:21.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKooonueic8k8iyylxoch7bhihk
Call-ID: oxoulboychchycxokhncjvve8ekun8y8@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:18:21.568: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=2577D01C-2357
Date: Mon, 14 May 2012 16:18:21 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 8010 6322 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:18:31.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKkj78nijvj87onovxiickvlxx8
Call-ID: ejj7bxou8xnlljh8voenkh7nvcveinyl@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:18:31.568: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=2577F72C-7E0
Date: Mon, 14 May 2012 16:18:31 GMT
ACCDMM-VGW01#x
CSeq: 1 OPTIONS
v=0
o=CiscoSystemsSIP-GW-UserAgent 8797 7593 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:18:41.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bK7onvoebil77jh8ncololnixun
Call-ID: ilbekcuuocchvjuooe7bh7yno7uylluc@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:18:41.568: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25781E3C-18A7
Date: Mon, 14 May 2012 16:18:41 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 1241 8586 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:18:51.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bK7blyniolueyeuj8nkxkihvbxi
Call-ID: c8vhle77bv7eikoccylnlyjbcibxix8o@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:18:51.568: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=2578454C-7B
Date: Mon, 14 May 2012 16:18:51 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 1658 1495 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:19:01.564: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bK7xixoic7oju7k8y7ceuykubko
Call-ID: nynhvk8uloxvh8iccykhhkuxolokkje8@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:19:01.568: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25786C5C-24E0
Date: Mon, 14 May 2012 16:19:01 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 1177 4857 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#u all
All possible debugging has been turned off
ACCDMM-VGW01#exit
Ok, So your problem is pretty obvious..
You are sending DTMF with PT 97, that is payload type 97. However in your SDP extensions, there are no attribiutes for this Payload type.
Under your m-line, you should have m=audio 0 RTP/AVP 18 0 8 4 2 15 3 97
and
you should atleast have
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
I also observe that your trace is imcomplete. I do not see the start of your trace. I do not see the full call flow in your trace. I need to see what is been offered in the SDP attributes to know if CUCM is sending PT=97
If you want help, then please co-orperate. a full trace of your test call with debug
HERE is the configuration...
Current configuration : 9320 bytes
! Last configuration change at 15:49:12 UTC Mon May 14 2012
version 12.4
boot-start-marker
boot system falsh:c2800nm-entservicesk9-mz.151-2.T2.bin
boot system flash c2800nm-entservicesk9-mz.151-2.T2.bin
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
clock calendar-valid
ip cef
no ip domain lookup
ip domain name yourdomain.com
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service h225-notify cid-update
redirect ip2ip
h323
sip
bind control source-interface FastEthernet0/1
bind media source-interface FastEthernet0/1
registrar server expires max 3600 min 3500
transport switch udp tcp
redirect contact order best-match
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
codec preference 4 g711alaw
voice translation-rule 1
rule 1 /^35\(..\)/ /86975\1/
rule 2 /3[012346789]../ /8697500/
voice translation-rule 2
rule 1 /^8697\(5..\)/ /3\1/
rule 2 /^038697\(5..\)/ /3\1/
voice translation-profile incomingpstn
translate called 2
voice translation-profile test
translate calling 1
crypto pki trustpoint TP-self-signed-3592495692
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3592495692
revocation-check none
rsakeypair TP-self-signed-3592495692
crypto pki certificate chain TP-self-signed-3592495692
certificate self-signed 01
30820253 308201BC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33353932 34393536 3932301E 170D3131 30353231 31303538
33365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 35393234
39353639 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C8CE A8FA7717 CF02B6E0 90E5DC11 43811C70 886FE25F 145F854F EEA60A8F
919A2CC3 21D3F618 FF2C5B50 02B4AC5F 89ACF87D 3580E077 452B4F96 A19A7B99
FA2C8705 C28BB05A 29E6046C EFB82088 209A57F8 277C5B66 676AB5B0 C63A4BC3
CA9597B4 2B3A6E22 32657F20 BA2BF84E A97A13D4 4487D658 010A5A79 3C8C534D
C07F0203 010001A3 7B307930 0F060355 1D130101 FF040530 030101FF 30260603
551D1104 1F301D82 1B414343 444D4D2D 56475730 312E796F 7572646F 6D61696E
2E636F6D 301F0603 551D2304 18301680 1419BA01 17EED387 B07E777E B9044A59
1FA60FA8 6C301D06 03551D0E 04160414 19BA0117 EED387B0 7E777EB9 044A591F
A60FA86C 300D0609 2A864886 F70D0101 04050003 81810066 5063985F AC1BAA74
178B77FE CF571BBC 8C61BFAA 029ED18C 679CEE01 233049D1 DE7D21FA FB11F2B5
E30AAD5B 28B65487 70AE6191 02F55F9A 875EB660 A42EC386 A310BC98 2DA0EA2D
EBC7BE93 B801C328 6F1F960B 5FB930D2 7F15B250 A95F88DB 2CA99C9C B7B4847C
8BA649AB 1AA3136C BC425ADE F0DD512F C2684682 72EDD1
quit
interface Tunnel0
ip address 10.X.X.X 255.255.255.252
tunnel source X.X.X.X
tunnel destination X.X.X.X
interface Loopback0
no ip address
interface FastEthernet0/0
description Internet
ip address 82.X.X.X 255.255.255.248
duplex auto
speed auto
description SIP Trunk To STC
ip address 10.196.X.X 255.255.255.252
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.X6.XX.X
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip route 10.X.X.0 255.255.255.0 Tunnel0
ip route 10.X.3X.0 255.255.255.0 Tunnel0
ip route 10.X5.X.X 255.255.255.0 10.X.X.X
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static 10.X.X.X interface FastEthernet0/1
access-list 1 permit 0.0.0.0 255.255.255.0
access-list 23 permit 10.X.X.0 0.0.0.X
control-plane
voice-port 0/0/0
supervisory disconnect dualtone mid-call
input gain 3
cptone SA
timeouts initial 0
timeouts interdigit 5
timeouts call-disconnect 1
timeouts ringing 5
timeouts wait-release 1
connection plar opx 4500
caller-id alerting dsp-pre-allocate
voice-port 0/0/1
input gain 3
cptone SA
timeouts initial 0
timeouts ringing 5
voice-port 0/1/0
voice-port 0/1/1
sccp local FastEthernet0/1
sccp ccm 10.10.30.241 identifier 1 version 5.0.1
sccp ccm 10.10.30.240 identifier 2 version 5.0.1
sccp
sccp ccm group 10
bind interface FastEthernet0/1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register XCD789
associate profile 2 register MTP456
associate profile 3 register CFB123
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 18
associate application SCCP
dspfarm profile 2 mtp
codec g711ulaw
maximum sessions hardware 12
maximum sessions software 500
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 200 voip
description ** Incoming DP to CUCM-Sub **
translation-profile incoming incomingpstn
answer-address 3[5][0-9][0-9]
destination-pattern 3[5][0-9][0-9]
session target ipv4:10.10.30.241
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
fax rate disable
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 201 voip
tone ringback alert-no-PI
description ** Incoming DP to CUCM-Pub **
preference 5
progress_ind setup enable 3
progress_ind alert enable 2
session target ipv4:10.10.30.240
dtmf-relay rtp-nte h245-signal
codec g711ulaw
fax rate disable
no vad
dial-peer voice 198 voip
description "Subscriber"
destination-pattern 4500
codec g711ulaw
no vad
dial-peer voice 199 voip
description "Publisher"
codec g711ulaw
no vad
dial-peer voice 1 voip
session target sip-server
incoming called-number 35..
codec g711ulaw
no vad
sip-ua
disable-early-media 180
sip-server ipv4:10.205.20.50:5060
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
banner exec ^C
% Password expiration warning.
^C
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
logging synchronous
login local
transport input telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
# exit
Dear... above is the complete configuration.. i will send you again debugs..thankyou
here is the debug with test calls..
ACCDMM-VGW01#debug ccsip messa
ACCDMM-VGW01#debug ccsip messages
SIP Call messages tracing is enabled
ACCDMM-VGW01#debug voi
ACCDMM-VGW01#debug voip rtp ses
ACCDMM-VGW01#debug voip rtp session n
ACCDMM-VGW01#debug voip rtp session na
ACCDMM-VGW01#debug voip rtp session named-event
VOIP RTP Named Events - ALL debugging is on
ACCDMM-VGW01#ter mon
ACCDMM-VGW01#
May 14 16:55:11.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKlvnxiveull88ie8ll7lnbkhuu
Call-ID: kheeuooyn8kh8vnl7nixv8ul7ckoiuxn@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:55:11.492: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
ACCDMM-VGW01#05.20.50:5060;branch=z9hG4bKlvnxiveull88ie8ll7lnbkhuu
To: <10.196.183.74>;tag=259988A0-CAE
Date: Mon, 14 May 2012 16:55:11 GMT
CSeq: 1 OPTIONS
v=0
o=CiscoSystemsSIP-GW-UserAgent 8214 9400 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:55:21.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKlkevxyy7xh88nixokhhvccxhe
Call-ID: vjbkxehle8xy78kixlk8huclcjoocv7u@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:55:21.492: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=2599AFB0-966
Date: Mon, 14 May 2012 16:55:21 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 2659 3897 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:55:31.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKlibyoolubeh88xcy77ooeinkc
Call-ID: ivciyxil8buueboxvyeyinhjjnhbevlh@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:55:31.492: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
ACCDMM-VGW01#05.20.50:5060;branch=z9hG4bKlibyoolubeh88xcy77ooeinkc
To: <10.196.183.74>;tag=2599D6C0-1929
Date: Mon, 14 May 2012 16:55:31 GMT
CSeq: 1 OPTIONS
v=0
o=CiscoSystemsSIP-GW-UserAgent 1333 1188 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:55:41.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKjlxlooy7cvivxckxjhubjjbji
Call-ID: yhjylueku7klcjl8ekyluyhjkevk8ubu@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:55:41.492: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=2599FDD0-18BF
Date: Mon, 14 May 2012 16:55:41 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 3791 2208 IN IP4 10.196.183.74
s=SIP Call
t=0 0
May 14 16:55:41.844: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKnblnx8ioohibkbnl7okvuyobk
Call-ID: SBCfh888f2p4skp3ss2ah1pkphak4pka7cp@SoftX3000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 010.196.183.74>10.205.20.50>
May 14 16:55:41.848: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=2599FF34-19D4
CSeq: 1 OPTIONS
Content-Length: 16910.196.183.74>10.205.20.50>
v=0
o=CiscoSystemsSIP-GW-UserAgent 254 4975 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:55:51.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKcibnnn8xohxk7kibhncen7n8i
Call-ID: bjehiohkjxiecelnxvelij8bvoulh87o@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:55:51.492: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259A24E0-1F2F
Date: Mon, 14 May 2012 16:55:51 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 5045 8193 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:56:01.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKncu7ocibb7jjvelhycny8ojkc
Call-ID: vhuvunexveenbyxbboxj7k7oixnyhk7o@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:56:01.492: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259A4BF0-1E2D
Date: Mon, 14 May 2012 16:56:01 GMT
CSeq: 1 O
ACCDMM-VGW01#PTIONS
v=0
o=CiscoSystemsSIP-GW-UserAgent 3429 4879 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:56:11.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKicc8ehjihbnbic8by7y87h7jb
Call-ID: xlbcylyvknkhbb8lokjyluloce7uvhio@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:56:11.492: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259A7300-BBC
Date: Mon, 14 May 2012 16:56:11 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 6804 5237 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:56:21.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKxukjjn7e8kxhcyi7iobu7v7hy
Call-ID: jioyoh7ync7ij7jbhkey8yynlouo8kui@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:56:21.492: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259A9A0C-1B92
Date: Mon, 14 May 2012 16:56:21 GMT
CSeq: 1
v=0
o=CiscoSystemsSIP-GW-UserAgent 9014 5005 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:56:31.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKooc8okh8xkvbehbiljjkjljo8
Call-ID: enlbkl8x7b8uvyibxlujykovxucbkbhb@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:56:31.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259AC11C-1E40
Date: Mon, 14 May 2012 16:56:31 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 660 5546 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:56:41.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKynxkhvlol8ceeijl87uijkeuy
Call-ID: njbecivnyluo87on7yujkeej7yueuoe8@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:56:41.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259AE82C-1B1A
Date: Mon, 14 May 2012 16:56:41 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 7394 2016 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:56:51.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKxylyv8uxeullbe8xcyuukejlj
Call-ID: olejueiixjck8leibkxhbhb8bn8nubny@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:56:51.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259B0F3C-B2E
Date: Mon, 14 May 2012 16:56:51 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 5317 1236 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:57:01.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKhkn7ehbuoncvuunbblnohchnj
Call-ID: o8v7lbnvccouby7nihhkluj78lhbyvj8@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:57:01.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259B364C-175A
Date: Mon, 14 May 2012 16:57:01 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 3193 7889 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:57:11.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKyj7ii8ujeonyyxcejujel87iu
Call-ID: uu8yiekjeoiyinkcbxhcxljlevb8okx8@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:57:11.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259B5D5C-105D
Date: Mon, 14 May 2012 16:57:11 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 2305 8881 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:57:21.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKcviexchiecl7yuue8vy7onxuo
Call-ID: vlnvoxhon7juvuunyyuvekiu7evylnnu@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:57:21.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259B846C-1BEC
Date: Mon, 14 May 2012 16:57:21 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 2511 5215 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:57:31.480: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bK77ukbxjvhcouxhncjlxochbh7
Call-ID: jvcloooun7n8nchloc88yvcbyx7vn8eo@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:57:31.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259BAB7C-1163
Date: Mon, 14 May 2012 16:57:31 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 9765 3360 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:57:41.480: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKxnj8hyyyuekbycbninh8y8enb
Call-ID: nvo87i8xnuknuovjiexycyc8knnhyov8@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:57:41.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259BD28C-1FE2
Date: Mon, 14 May 2012 16:57:41 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 3654 4335 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:57:51.480: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKev7lykjluc7ixkhhbl7oxxieb
Call-ID: o7ynuinljeyjcyuknnnkolveuyjkvc87@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:57:51.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259BF99C-2FC
Date: Mon, 14 May 2012 16:57:51 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 9764 4715 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:58:01.480: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKklx8ivujncijcobbij8nk7hyu
Call-ID: lkkvuiy7yyncoeivjjxlvyybonujyyul@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:58:01.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259C20AC-1347
Date: Mon, 14 May 2012 16:58:01 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 4277 9817 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:58:11.480: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKk88ykukkukxoeylooe8hu7chy
Call-ID: 7bj7uy8kj7euxknvobv7euxooek8uhxx@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:58:11.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259C47BC-10CD
Date: Mon, 14 May 2012 16:58:11 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 6664 2464 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 16:58:21.480: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKjui8bvclnhilvnuuloxhch8ce
Call-ID: obnechk8ivxujo8yokxhcjnjn7iclohn@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 16:58:21.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=259C6EC8-D32
Date: Mon, 14 May 2012 16:58:21 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 1781 8771 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#u all
ACCDMM-VGW01#deb
May 14 17:05:01.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKxuvvvnuuyuvuyhjn7bucvubku
Call-ID: vcjyhuhblxnouvelueincuueolkccucx@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:05:01.472: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A2893C-234C
Date: Mon, 14 May 2012 17:05:01 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#debugt
v=0
o=CiscoSystemsSIP-GW-UserAgent 6771 434 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#debugvoip
May 14 17:05:11.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKybncljvvx8ibyoc8vulo7voln
Call-ID: 7l77vhji7eeiycxxljecuek7cvj8cn7n@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:05:11.472: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP
ACCDMM-VGW01#debugvoip rtp 10.205.20.50:5060;branch=z9hG4bKybncljvvx8ibyoc8vulo7voln
To: <10.196.183.74>;tag=25A2B04C-10D6
Date: Mon, 14 May 2012 17:05:11 GMT
CSeq: 1 OPTIONS
v=0
o=CiscoSystemsSIP-GW-UserAgent 7242 1430 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#debugvoip rtp sess
ACCDMM-VGW01#debugvoip rtp session
May 14 17:05:21.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKbjjcieychvykchco7nlbikkoy
Call-ID: u8noyhjkcxokjckv8v8nol8cen7hx8kb@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:05:21.472: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A2D75C-14FA
Date: Mon, 14 May 2012 17:05:21 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#debugvoip rtp session t
v=0
o=CiscoSystemsSIP-GW-UserAgent 1486 2741 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#debugvoip rtp session na
May 14 17:05:31.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKlkxnyv7li8ojxy8occejlolkb
Call-ID: 7jh7e8ek8jiv8eyhulkn8bo888cxeeiy@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:05:31.472: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A2FE6C-17C6
Date: Mon, 14 May 2012 17:05:31 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#debugvoip rtp session namet
v=0
o=CiscoSystemsSIP-GW-UserAgent 9858 6385 IN IP4 10.196.183.74
s=SIP Call
t=0 0
% Invalid input detected at '^' marker.
ACCDMM-VGW01#debug
May 14 17:05:41.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKlejbjejy8u88e7ojjulluucvb
Call-ID: oj7kbyjvlnx8oyo7ocveec8ix7o7iny7@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:05:41.472: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
ACCDMM-VGW01#debug 05.20.50:5060;branch=z9hG4bKlejbjejy8u88e7ojjulluucvb
To: <10.196.183.74>;tag=25A3257C-CCE
Date: Mon, 14 May 2012 17:05:41 GMT
CSeq: 1 OPTIONS
v=0
o=CiscoSystemsSIP-GW-UserAgent 8163 8989 IN IP4 10.196.183.74
s=SIP Call
t=0 0
May 14 17:05:41.944: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKjel87clnihiiueceyxb88u8c8
Call-ID: SBC66fpac348f1k4367k76wa86372pw27ww@SoftX3000
ACCDMM-VGW01#debug tag=f7hh8w35
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:05:41.948: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A32758-6F2
CSeq: 1 OPTIONS
Content-Length: 17010.196.183.74>10.205.20.50>
v=0
o=CiscoSystemsSIP-GW-UserAgent 3285 7311 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#debug
May 14 17:05:51.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bK7byoi8hje7juybobnbujvixeh
Call-ID: xlckiuxxukbhkoukolvyjnkxncxvkoko@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:05:51.472: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A34C88-1B80
Date: Mon, 14 May 2012 17:05:51 GMT
CSeq: 1 OPTIONS
v=0
o=CiscoSystemsSIP-GW-UserAgent 8586 6956 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#debug vi
May 14 17:05:58.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:014791313@10.205.20.50:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK80DFA1
To: <014791313>;tag=c2w6pp7h-CC-46
Date: Mon, 14 May 2012 17:04:15 GMT
Call-ID: A866740D-9D1D11E1-BCAEA11B-C55BF1BE@10.196.183.74
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1337015158
CSeq: 103 BYE
Reason: Q.850;cause=16
Con
ACCDMM-VGW01#debug voiptent-Length: 0014791313>8697580>
May 14 17:05:58.540: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK80DFA1;rport=52620
CSeq: 103 BYE
Content-Length: 0014791313>8697580>
May 14 17:06:01.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKclhnevunhjnvubinuiheelhuy
Call-ID: evyeix8xecjo7eohkijihhochelye7kk@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:06:01.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A37398-1B3A
Date: Mon, 14 May 2012 17:06:01 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#debug voip rtt
v=0
o=CiscoSystemsSIP-GW-UserAgent 5857 4971 IN IP4 10.196.183.74
s=SIP Call
t=0 0
May 14 17:06:03.964: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8969199@10.205.20.50:5060 SIP/2.0
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK80ED20
Remote-Party-ID: <8697580>;party=calling;screen=yes;privacy=off
To: <8969199>
Date: Mon, 14 May 2012 17:06:03 GMT
Call-ID: EC2A7874-9D1D11E1-BCBEA11B-C55BF1BE@10.196.183.74
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-G
ACCDMM-VGW01#debug voip rtp session uid: 3427451-1899303419-1510037762-168435758
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1337015163
Contact: <8697580>
Expires: 180
Content-Length: 08697580>8969199>8697580>8697580>
May 14 17:06:03.988: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK80ED20;rport=52620
To: <8969199>
CSeq: 101 INVITE
Content-Length: 08969199>8697580>
May 14 17:06:04.840: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <8969199>;tag=k
ACCDMM-VGW01#debug voip rtp session nw73k533-CC-47
CSeq: 101 INVITE
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Require: 100rel
RSeq: 1
Contact: <8969199>
Content-Length: 381
Content-Type: application/sdp8969199>8969199>8697580>
v=0
o=HuaweiSoftX3000 877205 877205 IN IP4 10.205.20.50
s=Sip Call
c=IN IP4 10.205.20.50
t=0 0
m=audio 30954 RTP/AVP 8 0 18 4 2 98 99 97
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:4 G723/8000
a=rtpmap:2 G726-32/8000
a=rtpmap:98 G726-40/8000
a=rtpmap:99 G726-32/8000
a=fmtp:97 0-15
a=fmtp:18 annexb=yes
May 14 17:06:04.844: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:8969199@10.205.20.50:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK80F162F
To: <8969199>;tag=kw73k533-CC-47
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
May 14 17:06:04.888: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK80F162F;rport=52620
CSeq: 102 PRACK
May 14 17:06:05.108: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Contact: <8969199>
Content-Length: 381
v=0
o=HuaweiSoftX3000 877205 877206 IN IP4 10.205.20.50
s=Sip Call
t=0 0
a=fmtp:97 0-15
May 14 17:06:05.280: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK8101EC0
Max-Forwards: 70
CSeq: 101 ACK
Content-Disposition: session;handling=required
Content-Length: 2388969199>8697580>
v=0
o=CiscoSystemsSIP-GW-UserAgent 6336 5497 IN IP4 10.196.183.74
s=SIP Call
t=0 0
m=audio 19298 RTP/AVP 0 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
May 14 17:06:05.356: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:8697580@10.196.183.74:5060 SIP/2.0
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKlijuuycejyx77bch7uxhi8lkl
To: <8697580>;tag=25A37D5C-10BA
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:06:05.360: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 14 May 2012 17:06:05 GMT
CSeq: 1 OPTIONS
Content-Length: 2388697580>8969199>
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
ACCDMM-VGW01#ter mo
May 14 17:06:11.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKcekxvkbyelevclc7xnuyojlku
Call-ID: novh7eveh77n7vkeyjijihyu8on7jbnk@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:06:11.472: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A39AA8-377
Date: Mon, 14 May 2012 17:06:11 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 686 5402 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 17:06:16.820: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6998 timestamp 0x9C35CA5D
May 14 17:06:16.820: Pt:101 Evt:1 Pkt:04 00 00
May 14 17:06:16.820: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6999 timestamp 0x9C35CA5D
May 14 17:06:16.820: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x699A timestamp 0x9C35CA5D
May 14 17:06:16.820: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x699B timestamp 0x9C35CA5D
ACCDMM-VGW01#
May 14 17:06:16.820: Pt:101 Evt:1 Pkt:04 01 90
May 14 17:06:16.824: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x699C timestamp 0x9C35CA5D
May 14 17:06:16.824: Pt:101 Evt:1 Pkt:84 03 20
May 14 17:06:16.824: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x699D timestamp 0x9C35CA5D
May 14 17:06:16.824: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x699E timestamp 0x9C35CA5D
May 14 17:06:17.064: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69A4 timestamp 0x9C35D1DD
May 14 17:06:17.064: Pt:101 Evt:1 Pkt:04 00 00
May 14 17:06:17.064: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69A5 timestamp 0x9C35D1DD
May 14 17:06:17.064: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69A6 timestamp 0x9C35D1DD
May 14 17:06:17.064: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69A7 timestamp 0x9C35D1DD
May 14 17:06:17.064: Pt:101 Evt:1 Pkt:04 01 90
May 14 17:06:17.064: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69A8 timestamp 0x9C35D1DD
May 14 17:06:17.064: Pt:101 Evt:1 Pkt:84 03 20
May 14 17:06:17.064: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69A9 timestamp 0x9C35D1DD
May 14 17:06:17.068: Pt:101 Evt:1 Pkt:84 03 20
May 14 17:06:17.068: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69AA timestamp 0x9C35D1DD
May 14 17:06:17.436: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69B7 timestamp 0x9C35DDBD
May 14 17:06:17.436: Pt:101 Evt:9 Pkt:04 00 00
May 14 17:06:17.436: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69B8 timestamp 0x9C35DDBD
May 14 17:06:17.436: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69B9 timestamp 0x9C35DDBD
May 14 17:06:17.436: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69BA timestamp 0x9C35DDBD
ACCDMM-VGW01#
May 14 17:06:17.436: Pt:101 Evt:9 Pkt:04 01 90
May 14 17:06:17.436: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69BB timestamp 0x9C35DDBD
May 14 17:06:17.436: Pt:101 Evt:9 Pkt:84 03 20
May 14 17:06:17.436: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69BC timestamp 0x9C35DDBD
May 14 17:06:17.436: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x69BD timestamp 0x9C35DDBD
ACCDMM-VGW01#
May 14 17:06:21.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKn7eychbevvvbe7ilneeu7ulnv
Call-ID: ijiyyhinihlhe7k8heex8h8ye87nkkek@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:06:21.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A3C1B8-10D0
Date: Mon, 14 May 2012 17:06:21 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 5606 812 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 17:06:25.124: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B37 timestamp 0x9C36CDBD
May 14 17:06:25.124: Pt:101 Evt:1 Pkt:04 00 00
May 14 17:06:25.124: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B38 timestamp 0x9C36CDBD
May 14 17:06:25.124: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B39 timestamp 0x9C36CDBD
May 14 17:06:25.124: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B3A timestamp 0x9C36CDBD
May 14 17:06:25.124: Pt:101 Evt:1 Pkt:04 01 90
May 14 17:06:25.128: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B3B timestamp 0
ACCDMM-VGW01#x9C36CDBD
May 14 17:06:25.128: Pt:101 Evt:1 Pkt:84 03 20
May 14 17:06:25.128: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B3C timestamp 0x9C36CDBD
May 14 17:06:25.128: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B3D timestamp 0x9C36CDBD
May 14 17:06:25.292: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B40 timestamp 0x9C36D3FD
May 14 17:06:25.296: Pt:101 Evt:1 Pkt:04 00 00
May 14 17:06:25.296: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B41 timestamp 0x9C36D3FD
May 14 17:06:25.296: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B42 timestamp 0x9C36D3FD
May 14 17:06:25.296: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B43 timestamp 0x9C36D3FD
May 14 17:06:25.296: Pt:101 Evt:1 Pkt:04 01 90
May 14 17:06:25.296: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B44 timestamp 0x9C36D3FD
May 14 17:06:25.296: Pt:101 Evt:1 Pkt:84 03 20
May 14 17:06:25.296: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B45 timestamp 0x9C36D3FD
ACCDMM-VGW01# payload 0x65 ssrc 0x57C3DEFB sequence 0x6B46 timestamp 0x9C36D3FD
May 14 17:06:25.620: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B50 timestamp 0x9C36DD5D
May 14 17:06:25.620: Pt:101 Evt:9 Pkt:04 00 00
May 14 17:06:25.620: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B51 timestamp 0x9C36DD5D
May 14 17:06:25.620: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B52 timestamp 0x9C36DD5D
May 14 17:06:25.620: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B53 timestamp 0x9C36DD5D
May 14 17:06:25.620: Pt:101 Evt:9 Pkt:04 01 90
May 14 17:06:25.620: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B54 timestamp 0x9C36DD5D
May 14 17:06:25.620: Pt:101 Evt:9 Pkt:84 03 20
May 14 17:06:25.620: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B55 timestamp 0x9C36DD5D
May 14 17:06:25.620: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6B56 timestamp 0x9C36DD5D
ACCDMM-VGW01#
May 14 17:06:30.656: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C4C timestamp 0x9C377ADD
May 14 17:06:30.656: Pt:101 Evt:1 Pkt:04 00 00
May 14 17:06:30.656: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C4D timestamp 0x9C377ADD
May 14 17:06:30.656: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C4E timestamp 0x9C377ADD
May 14 17:06:30.656: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C4F timestamp 0x9C377ADD
ACCDMM-VGW01#
May 14 17:06:30.656: Pt:101 Evt:1 Pkt:04 01 90
May 14 17:06:30.656: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C50 timestamp 0x9C377ADD
May 14 17:06:30.656: Pt:101 Evt:1 Pkt:84 03 20
May 14 17:06:30.656: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C51 timestamp 0x9C377ADD
May 14 17:06:30.656: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C52 timestamp 0x9C377ADD
May 14 17:06:30.876: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C57 timestamp 0x9C3781BD
May 14 17:06:30.876: Pt:101 Evt:1 Pkt:04 00 00
May 14 17:06:30.876: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C58 timestamp 0x9C3781BD
May 14 17:06:30.876: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C59 timestamp 0x9C3781BD
May 14 17:06:30.876: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C5A timestamp 0x9C3781BD
May 14 17:06:30.876: Pt:101 Evt:1 Pkt:04 01 90
May 14 17:06:30.876: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C5B timestamp 0x9C3781BD
May 14 17:06:30.876: Pt:101 Evt:1 Pkt:84 03 20
May 14 17:06:30.876: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C5C timestamp 0x9C3781BD
May 14 17:06:30.876: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C5D timestamp 0x9C3781BD
May 14 17:06:31.208: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C68 timestamp 0x9C378C5D
May 14 17:06:31.212: Pt:101 Evt:9 Pkt:04 00 00
May 14 17:06:31.212: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C69 timestamp 0x9C378C5D
May 14 17:06:31.212: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C6A timestamp 0x9C378C5D
May 14 17:06:31.212: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C6B timestamp 0x9C378C5D
May 14 17:06:31.212: Pt:101 Evt:9 Pkt:04 01 90
May 14 17:06:31.212: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C6C timestamp 0x9C378C5D
May 14 17:06:31.212: Pt:101 Evt:9 Pkt:84 03 20
May 14 17:06:31.212: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C6D timestamp 0x9C378C5D
May 14 17:06:31.212: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6C6E timestamp 0x9C378C5D
May 14 17:06:31.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKvye77uyhv7h7i7yvvu7yn8yyb
Call-ID: heh8ujin87nyxhyh7u7kcjuco7ohhvhe@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:06:31.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP
ACCDMM-VGW01#10.205.20.50:5060;branch=z9hG4bKvye77uyhv7h7i7yvvu7yn8yyb
To: <10.196.183.74>;tag=25A3E8C8-1B33
Date: Mon, 14 May 2012 17:06:31 GMT
CSeq: 1 OPTIONS
v=0
o=CiscoSystemsSIP-GW-UserAgent 9355 4131 IN IP4 10.196.183.74
s=SIP Call
t=0 0
May 14 17:06:32.524: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CA9 timestamp 0x9C37B4FD
May 14 17:06:32.524: Pt:101 Evt:1 Pkt:04 00 00
May 14 17:06:32.524: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CAA timestamp 0x9C37B4FD
May 14 17:06:32.524: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CAB timestamp 0x9C37B4FD
May 14 17:06:32.528: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CAC timestamp 0x9C37B4FD
May 14 17:06:32.528: Pt:101 Evt:1 Pkt:04 01 90
May 14 17:06:32.528: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CAD timestamp 0x9C37B4FD
May 14 17:06:32.528: Pt:101 Evt:1 Pkt:84 03 20
May 14 17:06:32.528: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CAE timestamp 0x9C37B4FD
May 14 17:06:32.528: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CAF timestamp 0x9C37B4FD
May 14 17:06:32.720: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CB3 timestamp 0x9C37BB3D
May 14 17:06:32.720: Pt:101 Evt:1 Pkt:04 00 00
May 14 17:06:32.720: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CB4 timestamp 0x9C37BB3D
May 14 17:06:32.720: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CB5 timestamp 0x9C37BB3D
May 14 17:06:32.720: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CB6 timestamp 0x9C37BB3D
ACCDMM-VGW01#
May 14 17:06:32.720: Pt:101 Evt:1 Pkt:04 01 90
May 14 17:06:32.720: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CB7 timestamp 0x9C37BB3D
May 14 17:06:32.720: Pt:101 Evt:1 Pkt:84 03 20
May 14 17:06:32.720: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CB8 timestamp 0x9C37BB3D
May 14 17:06:32.720: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CB9 timestamp 0x9C37BB3D
May 14 17:06:33.064: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CC4 timestamp 0x9C37C5DD
May 14 17:06:33.064: Pt:101 Evt:9 Pkt:04 00 00
May 14 17:06:33.064: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CC5 timestamp 0x9C37C5DD
May 14 17:06:33.064: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CC6 timestamp 0x9C37C5DD
May 14 17:06:33.068: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CC7 timestamp 0x9C37C5DD
ACCDMM-VGW01#
May 14 17:06:33.068: Pt:101 Evt:9 Pkt:04 01 90
May 14 17:06:33.068: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CC8 timestamp 0x9C37C5DD
May 14 17:06:33.068: Pt:101 Evt:9 Pkt:84 03 20
May 14 17:06:33.068: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CC9 timestamp 0x9C37C5DD
May 14 17:06:33.068: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6CCA timestamp 0x9C37C5DD
May 14 17:06:34.756: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D19 timestamp 0x9C37FAFD
May 14 17:06:34.756: Pt
ACCDMM-VGW01#:101 Evt:1 Pkt:04 00 00
May 14 17:06:34.756: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D1A timestamp 0x9C37FAFD
May 14 17:06:34.756: Pt:101 Evt:1 Pkt:04 00 00
May 14 17:06:34.756: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D1B timestamp 0x9C37FAFD
May 14 17:06:34.756: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D1C timestamp 0x9C37FAFD
May 14 17:06:34.756: Pt:101 Evt:1 Pkt:04 01 90
May 14 17:06:34.756: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D1D timestamp 0x9C37FAFD
May 14 17:06:34.756: Pt:101 Evt:1 Pkt:84 03 20
May 14 17:06:34.756: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D1E timestamp 0x9C37FAFD
May 14 17:06:34.756: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D1F timestamp 0x9C37FAFD
May 14 17:06:35.032: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D27 timestamp 0x9C3803BD
May 14 17:06:35.032: Pt:101 Evt:1 Pkt:04 00 00
May 14 17:06:35.032: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D28 timestamp 0x9C3803BD
May 14 17:06:35.036: s=DSP d=Vo
ACCDMM-VGW01#IP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D29 timestamp 0x9C3803BD
May 14 17:06:35.036: Pt:101 Evt:1 Pkt:04 00 00
May 14 17:06:35.036: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D2A timestamp 0x9C3803BD
May 14 17:06:35.036: Pt:101 Evt:1 Pkt:04 01 90
May 14 17:06:35.036: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D2B timestamp 0x9C3803BD
May 14 17:06:35.036: Pt:101 Evt:1 Pkt:84 03 20
May 14 17:06:35.036: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D2C timestamp 0x9C3803BD
May 14 17:06:35.036: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D2D timestamp 0x9C3803BD
May 14 17:06:35.400: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D39 timestamp 0x9C380EFD
May 14 17:06:35.400: Pt:101 Evt:9 Pkt:04 00 00
May 14 17:06:35.400: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D3A timestamp 0x9C380EFD
May 14 17:06:35.400: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D3B timestamp 0x9C380EFD
May 14 17:06:35.400: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D3C timestamp 0x9C380EFD
May 14 17:06:35.400: Pt:101 Evt:9 Pkt:04 01 90
May 14 17:06:35.400: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D3D timestamp 0x9C380EFD
May 14 17:06:35.400: Pt:101 Evt:9 Pkt:84 03 20
May 14 17:06:35.400: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D3E timestamp 0x9C380EFD
May 14 17:06:35.400: s=DSP d=VoIP payload 0x65 ssrc 0x57C3DEFB sequence 0x6D3F timestamp 0x9C380EFD
ACCDMM-VGW01#
May 14 17:06:41.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKxeb8vcoybuyoucenky8lchcee
Call-ID: 7ei7n7vnxbeyeoyholnnhhuekbhbln7c@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:06:41.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A40FD8-E5
Date: Mon, 14 May 2012 17:06:41 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 2220 6752 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 17:06:44.916: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:8969199@10.205.20.50:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK8112119
Max-Forwards: 70
Timestamp: 1337015204
CSeq: 103 BYE
ACCDMM-VGW01#
May 14 17:06:44.988: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK8112119;rport=52620
CSeq: 103 BYE
ACCDMM-VGW01#
May 14 17:06:51.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKl7vbny7ubioxokbuchybkenvx
Call-ID: yxyyc8njujhkv78nuobnehivvuk8o7jl@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:06:51.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A436E8-14B
Date: Mon, 14 May 2012 17:06:51 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01# ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Content-Length: 16810.196.183.74>
v=0
o=CiscoSystemsSIP-GW-UserAgent 4391 37 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 17:06:53.472: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0544131232@10.205.20.50:5060 SIP/2.0
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK81239B
To: <0544131232>
Date: Mon, 14 May 2012 17:06:53 GMT
Call-ID: 9AC2F5F-9D1E11E1-BCC6A11B-C55BF1BE@10.196.183.74
Min-SE: 1800
Cisco-Guid: 10033561-2738164219-1526815234-168435758
User-Agent: Cisco
ACCDMM-VGW01#-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1337015213
Contact: <8697580>
Expires: 180
Content-Length: 08697580>0544131232>8697580>8697580>
May 14 17:06:53.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK81239B;rport=52620
To: <0544131232>
CSeq: 101 INVITE
Content-Length: 00544131232>8697580>
May 14 17:06:54.556: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <0544131232>;tag=ws5s4cf4-CC-38
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Contact: <0544131232>
Content-Length: 383
Content-Type: application/sdp0544131232>0544131232>8697580>
v=0
o=HuaweiSoftX3000 1906630 1906630 IN IP4 10.205.20.50
s=Sip Call
t=0 0
m=audio 30976 RTP/AVP 8 0 18 4 2 98 99 97
a=fmtp:97 0-15
May 14 17:06:54.560: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:0544131232@10.205.20.50:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK81325AD
CSeq: 102 PRACK
RAck: 1
ACCDMM-VGW01#101 INVITE
Max-Forwards: 70
May 14 17:06:54.604: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK81325AD;rport=52620
CSeq: 102 PRACK
ACCDMM-VGW01#
May 14 17:07:01.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKnhhh7ylbbkjxlnxhkhiebxoix
Call-ID: enkjuyoioyjyljcoko77nhcnk8vlu7ik@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:07:01.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A45DF8-1BC
Date: Mon, 14 May 2012 17:07:01 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 8951 6971 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 17:07:07.388: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 383
v=0
o=HuaweiSoftX3000 1906630 1906631 IN IP4 10.205.20.50
s=Sip Call
t=0 0
a=fmtp:97 0-15
May 14 17:07:07.556: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.196.183.74:5060;branch=z9hG4bK81419AF
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 2380544131232>8697580>
v=0
o=CiscoSystemsSIP-GW-UserAgent 5979 1970 IN IP4 10.196.183.74
s=SIP Call
t=0 0
m=audio 18744 RTP/AVP 0 101
a=fmtp:101 0-16
May 14 17:07:07.604: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKhh7khvhnhivvlxj87b7lbh7nb
To: <8697580>;tag=25A43EBC-2540
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:07:07.608: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Mon, 14 May 2012 17:07:07 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#one-event
Content-Length: 2388697580>0544131232>
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
ACCDMM-VGW01#
May 14 17:07:11.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKhceb7eyhejvojujllkvycvni8
Call-ID: couoylybi8ojijxkiyvlylijiiujeio8@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:07:11.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A48508-20CB
Date: Mon, 14 May 2012 17:07:11 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 6980 704 IN IP4 10.196.183.74
s=SIP Call
t=0 0
May 14 17:07:11.904: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:8697580@10.196.183.74:5060 SIP/2.0
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKi8x8nb788nnecyhnjvcl8enhe
ACCDMM-VGW01#74
CSeq: 2 INVITE
Max-Forwards: 70
Contact: <10.205.20.50:5060>
Content-Length: 214
Content-Type: application/sdp10.205.20.50:5060>8697580>0544131232>
v=0
o=HuaweiSoftX3000 1906630 1906632 IN IP4 10.205.20.50
s=Sip Call
t=0 0
m=audio 30976 RTP/AVP 8 97
a=fmtp:97 0-15
a=sendonly
May 14 17:07:11.912: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 2 INVITE
May 14 17:07:11.916: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 488
ACCDMM-VGW01# Not Acceptable Media
CSeq: 2 INVITE
May 14 17:07:11.940: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:8697580@10.196.183.74:5060 SIP/2.0
CSeq: 2 ACK
Max-Forwards: 70
May 14 17:07:11.972: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKelhin8yckb7ljke77eeex8ue7
CSeq: 3 OPTIONS
Max-Forwards: 70
May 14 17:07:11.976: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 3 OPTIONS
v=0
s=SIP Call
c=IN IP4 10.1
ACCDMM-VGW01#96.183.74
t=0 0
a=fmtp:101 0-16
Received:
BYE sip:8697580@10.196.183.74:5060 SIP/2.0
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKhybjb7ouy8o7kehi7obechhyb
CSeq: 4 BYE
Max-Forwards: 70
May 14 17:07:11.988: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 4 BYE
ACCDMM-VGW01#
May 14 17:07:21.460: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKeuxyekvycllyliv77xuobelui
Call-ID: njeicejkonoviy7uh8xeenukeyhikcyx@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:07:21.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A4AC18-1926
Date: Mon, 14 May 2012 17:07:21 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#t
v=0
o=CiscoSystemsSIP-GW-UserAgent 3182 1206 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 17:07:31.460: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKvbikkyuciykyjoubuekvjo87b
Call-ID: ixheyeob7ibybehuojl8kbxlol8x8nnx@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:07:31.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A4D328-23F2
Date: Mon, 14 May 2012 17:07:31 GMT
CSeq: 1 O
ACCDMM-VGW01#PTIONS
v=0
o=CiscoSystemsSIP-GW-UserAgent 6180 899 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 17:07:41.460: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bK8nhhn7yynehjxcbjlhkiknyjv
Call-ID: vj7y7vnocejyeei7behuh8hcuck7lxl7@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:07:41.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A4FA38-1A0B
Date: Mon, 14 May 2012 17:07:41 GMT
CSeq: 1 OPTIONS
Allow-Events
ACCDMM-VGW01#: telephone-event
v=0
o=CiscoSystemsSIP-GW-UserAgent 2376 1409 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 17:07:51.460: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.196.183.74:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKxjnkclkibclounie8yvly8y7h
Call-ID: bij7bjhnvuoyohnkconeblhjulb7ko8i@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:07:51.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A52148-FDE
Date: Mon, 14 May 2012 17:07:51 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 5852 2146 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#
May 14 17:08:01.460: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKoeulbluun7xlhvlillx8xhn7x
Call-ID: ubjk7kiy8e7iovciobjnhnoxv8xnkeub@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:08:01.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A54854-9
Date: Mon, 14 May 2012 17:08:01 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 OPTIONS
Supported: 100rel,resource-priority,replaces
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event10.196.183.74>
ACCDMM-VGW01#Accept: application/sdp
Content-Length: 169
v=0
o=CiscoSystemsSIP-GW-UserAgent 3367 920 IN IP4 10.196.183.74
s=SIP Call
c=IN IP4 10.196.183.74
t=0 0
ACCDMM-VGW01#u
May 14 17:08:11.460: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bK8yeo7vhbokkkvluolhy7hkv8c
Call-ID: kkibxkyueheuu8ekbilixjyynhlluvke@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:08:11.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A56F64-196D
Date: Mon, 14 May 2012 17:08:11 GMT
CSeq
ACCDMM-VGW01#u: 1 OPTIONS
v=0
o=CiscoSystemsSIP-GW-UserAgent 3333 6084 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#u all
May 14 17:08:21.460: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKxochoicn7lckh7voyiblxyxli
Call-ID: hvjnhioj7llhceo7hx8ooen7kenjv7jo@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:08:21.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
ACCDMM-VGW01#u all05.20.50:5060;branch=z9hG4bKxochoicn7lckh7voyiblxyxli
To: <10.196.183.74>;tag=25A59674-CE7
Date: Mon, 14 May 2012 17:08:21 GMT
CSeq: 1 OPTIONS
v=0
o=CiscoSystemsSIP-GW-UserAgent 8232 9439 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#u all
May 14 17:08:31.460: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bKn7lec7oecvi78ohkj87yjlchh
Call-ID: ocech8xcoh8yuoouxlkolncvijjxib7i@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:08:31.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A5BD84-4AA
Date: Mon, 14 May 2012 17:08:31 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#u all
v=0
o=CiscoSystemsSIP-GW-UserAgent 8142 8576 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#u all
May 14 17:08:41.460: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.205.20.50:5060;branch=z9hG4bK8xojix8i7e7vjj8x7yvkxk8oy
Call-ID: yce88cklyxxy7yyy8ybvulukxixbjuvy@SE2000
To: <10.196.183.74>
CSeq: 1 OPTIONS
Max-Forwards: 70
May 14 17:08:41.464: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <10.196.183.74>;tag=25A5E494-4CF
Date: Mon, 14 May 2012 17:08:41 GMT
CSeq: 1 OPTIONS
ACCDMM-VGW01#u all
ACCDMM-VGW01#
v=0
o=CiscoSystemsSIP-GW-UserAgent 4373 3507 IN IP4 10.196.183.74
s=SIP Call
t=0 0
ACCDMM-VGW01#u all
Sorry for the delay, I was busy with some work..
Looking at your traces..
A call came in to your CUBE and Media attributes are set as follows:
where 8=g711alaw codec
97= dynamic payload used here for Carrying DTMF tones
Received:
Call-ID:
ACCDMM-VGW01#74
To: <8697580>;tag=25A43EBC-25408697580>
CSeq: 2 INVITE
Max-Forwards: 70
Contact: <10.205.20.50:5060>10.205.20.50:5060>
Content-Length: 214
v=0
s=Sip Call
t=0 0
a=fmtp:97 0-15
a=sendonly
Sent:
SIP/2.0 100 Trying
CSeq: 2 INVITE
Sent:
SIP/2.0 488
CSeq: 2 INVITE
Received:
CSeq: 2 ACK
Max-Forwards: 70
Now Your CUBE then rejects with
SIP/2.0 488 Not Acceptable Media
Now question is why is CUBE complaining about the media setup/attributes...
From your rtp-named session debug, we see this..
So you are sending Payload type 101, and the far end has indicated that it can only do 97. So there is a payload type mismatch ...
You cantry the ff: assuming yourprovider is using rtp-nte, but different payload type
configure the payload type for rtp net to use 97 as follows:
rtp payload-type nte 97
hi i m getting this error
ACCDMM-VGW01(config-dial-peer)#rtp payload-type nte 97
ERROR: value 97 in use!
