10-24-2011 11:42 PM - edited 03-16-2019 07:41 AM
topology:
[cucm] -- sip -- [2821 router] -- Q.Sig on T1 PRI -- [Nortel PBX]
Q: Can CUCM/[IP phones] get calling name or alerting name from SIP gateway (2821 router)? The router used to be configured as MGCP gateway, both names were sent to CUCM.
Any comment is appreciated!
Jonathan
Solved! Go to Solution.
10-26-2011 03:26 AM
Ok, do you have "isdn supp-service name calling"
and "voice service voip
qsig decode" ?
Then take "debug ccsip message".
10-25-2011 04:24 AM
Yes.
10-25-2011 03:26 PM
thanks Paolo. I set up the sip gateway, when i make outbound call from IP Phone, the other party with Nortel phone sees my name, but i don't see hers(alerting name), do you have this experience?
10-25-2011 04:13 PM
Start checking "debug isdn q931".
10-25-2011 04:16 PM
PBX does send facility IE over:
Oct 25 15:20:23.662 PST: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x80F4
Channel ID i = 0xA98397
Exclusive, Channel 23
Oct 25 15:20:23.790 PST: ISDN Se0/1/0:23 Q931: RX <- ALERTING pd = 8 callref = 0x80F4
SI2821-2#
Oct 25 15:20:26.558 PST: ISDN Se0/1/0:23 Q931: RX <- CONNECT pd = 8 callref = 0x80F4
Facility i = 0x9FAA068001008201008B0100A11602020100020102800D4D61726965204D63496E6E6573
i think it's SIP that doesn't transform alerting name and send it to cucm.
10-26-2011 03:26 AM
qsig decode" ?
10-27-2011 04:01 PM
i put "isdn supp-service name calling" on at beginning, that made calling name work.
for alerting name display, "qsig decode" under "voice service voip" does the trick.
by the way, i originally converted the router to H.323 gateway, the name display issue occured. then I tried SIP gateway, same issue happens. After it's resolved on SIP gateway, i go back to H.323 gateway, with same solution, name display works as well.
thanks for the help!
