calling name and alerting name with sip gateway
xiaoliangyue
topology:
[cucm] -- sip -- [2821 router] -- Q.Sig on T1 PRI -- [Nortel PBX]
Q: Can CUCM/[IP phones] get calling name or alerting name from SIP gateway (2821 router)? The router used to be configured as MGCP gateway, both names were sent to CUCM.
Any comment is appreciated!
Jonathan
Ok, do you have "isdn supp-service name calling"
and "voice service voip
qsig decode" ?
Then take "debug ccsip message".
6 Replies 6
paolo bevilacqua
Yes.
thanks Paolo. I set up the sip gateway, when i make outbound call from IP Phone, the other party with Nortel phone sees my name, but i don't see hers(alerting name), do you have this experience?
Start checking "debug isdn q931".
PBX does send facility IE over:
Oct 25 15:20:23.662 PST: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x80F4
        Channel ID i = 0xA98397
                Exclusive, Channel 23
Oct 25 15:20:23.790 PST: ISDN Se0/1/0:23 Q931: RX <- ALERTING pd = 8  callref = 0x80F4
SI2821-2#
Oct 25 15:20:26.558 PST: ISDN Se0/1/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x80F4
        Facility i = 0x9FAA068001008201008B0100A11602020100020102800D4D61726965204D63496E6E6573
i think it's SIP that doesn't transform alerting name and send it to cucm.
qsig decode" ?
i put "isdn supp-service name calling" on at beginning, that made calling name work.
for alerting name display, "qsig decode" under "voice service voip" does the trick.
by the way, i originally converted the router to H.323 gateway, the name display issue occured. then I tried SIP gateway, same issue happens. After it's resolved on SIP gateway, i go back to H.323 gateway, with same solution, name display works as well.
thanks for the help!
