06-20-2018 01:11 PM - edited 03-17-2019 01:03 PM
Cucm Cuc Imp 11.5 - I want to set up a 7800 phone with a dozen speed dials and I only want the phone to allow dialing to those speed dials. What would I need to consider in trying to set this up ? Can it be done ? Or as an alternative, is there a single line type phone that you can program with numbers and no dial pad, like at the airports for calling transportation ? Thanks,
Solved! Go to Solution.
06-20-2018 02:03 PM
No, anyone can try to dial using the dial pad, whether the call works or not, depends on the CSS configuration.
06-20-2018 01:16 PM
Hi there
You can create Speed dials to these numbers. Are these internal numbers. Then create a new Partition which only the 7800 phone CSS have access to.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
06-20-2018 01:38 PM
But is it possible to have a phone that only allows the Speed Dials to work and not calls from the dial pad ?
06-20-2018 02:03 PM
