Is there a way to assign calling party transformation css to all phones ?
Can we done without assigning to dp-pools?
How can I achieve the same functionality of calling party transformation using a translation pattern
Solved! Go to Solution.
Certainly. There is calling party transformation CSS on the device itself. Just uncheck the default of use device pool css for this.
For translation pattern there is a field that allows to modify the calling party .
This is what i was doing uncheck the default of use device pool css .When it comes around 500 phones it is difficult
How to link the translation pattern for the above purpose
