04-28-2019 06:13 AM
Usually I use calling party transform mask on route pattern , Is there a way to use on sip trunk instead of calling party tansform mask on route pattern
04-28-2019 10:47 AM
hi,
you can make the calling called party transformation and add them to the partition.
now on the trunk there is an option for calling/called transformation css, add the css that has the transformation partition.
regards.
Log in to Community
