08-03-2016 12:48 PM - edited 03-17-2019 07:43 AM
Good Day!!
One question, It's possible configurated in the dial-peer voice X voip in router 2911 the next parameter ??
"Calling Party Transfor Mask"
I try with carrier ID, transformations but don´t work!!
Thank You!!
Solved! Go to Solution.
08-03-2016 01:04 PM
If I am reading your question correctly. You want to know how to do a translation on the calling number on an outbound dial-peer. If I am correct the sample below should help you out.
voice translation-rule 1
rule 1 /.*/ /13160850/
voice translation-profile Outbound
translate calling 1
dial-peer voice 25 voip
translation-profile outgoing Outbound
08-03-2016 01:04 PM
translate calling 1
