11-09-2012 06:05 AM - edited 03-16-2019 02:06 PM
Line/Device approach has the significant advantage that only a single site-specific, unrestricted calling search
space is required for each site (that is, one per branch). Because the dialing privileges are implemented
through the use of blocked route patterns (which are not site-dependent), the same set of blocking calling
search spaces can be used in all branches.
How this approach is supported for Cisco IP Communicator/Jabber.
11-09-2012 06:21 AM
The approach is device independent. It doesnt matter if you are using a CIPC or a sip device like jabber client.
You configure the device css and assign it to the device and you then configure your class of restrictions on the line...
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
11-09-2012 07:20 AM
In addition to Deji's point (+5), the SRND explains it pretty well with nice examples.
HTH,
Chris
