calling sip line from outside
edwincharles
dears,
any one can help, i have these config in my translation rules
incoming calls are working when i dial 2837555 from outside , but some are saying that when they call from certain numbers the number 2837555 it will be busy.
voice translation-rule 1
rule 1 /2837599/ /599/
rule 2 /2837595/ /595/
rule 3 /2837597/ /597/
rule 4 /2837598/ /598/
rule 5 /2837400/ /100/
rule 6 /2837596/ /596/
rule 7 /.*2837555/ /123/
rule 8 /^1\(.......$\)/ /9\1/
rule 9 /\(^5........$\)/ /90\1/
rule 10 /^9\(.*\)/ /\1/
rule 11 /^.*\(123\)/ /\1/
voice translation-rule 191
rule 1 /^599/ /2837599/
rule 2 /^596/ /2837596/
rule 3 /^595/ /2837595/
rule 4 /^597/ /2837597/
rule 5 /^598/ /2837598/
rule 6 /^3....\*\(.\)/ /\1/
rule 7 /^9\(.*\)/ /\1/
rule 8 /.../ /2837555/
voice translation-profile SIP-IN
translate calling 1
translate called 1
voice translation-profile TP_OUT_SIP
translate calling 191
translate called 191
24 Replies 24
Ayodeji Okanlawon
can you send a debug ccsip messages and debug voip ccapi inout
Please rate useful posts
Please rate all useful posts
hi,
tthanks for your support, please find logs as requested , called from 2835625 to 2837555 but call not going to AA
Hi, here is an analysis of your trace..
+++Your sip provider sends an invite without SDP+++So you are doing delay offer
Received:
INVITE sip:2837555@10.196.106.122:5060;
user=phone SIP/2.0 Via: SIP/2.0/UDP 10.200.7.157:5060;
branch=z9hG4bKj8nb8liui7vhlohlv7bnvkhkc
Call-ID: SBCk2aedpp2u2otuptbbfes2okad7aehaec@SoftX3000
To: <2837555>
+++After a couple of trying and invite to CUE, you send a 200 ok to provider with SDP++++.
Sent:
SIP/2.0 200 OK Via: SIP/2.0/UDP 10.200.7.157:5060;
To: <2837555>;tag=2E4C4AD0-263D Date: Sat, 02 Jun 2012 08:49:51 GMT
CSeq: 1 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events:
telephone-event Remote-Party-ID: <123>;party=called;screen=no;privacy=off
Contact: <2837555> Supported: replaces Call-Info: <10.196.106.122:5060>;method="NOTIFY;Event=telephone-event;Duration=2000" Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x Supported: timer Content-Type: application/sdp
Content-Disposition: session;handling=required Content-Length: 251
v=0
o=CiscoSystemsSIP-GW-UserAgent 336 981
IN IP4 10.196.106.122
s=SIP Call
c=IN IP4 10.196.106.122
t=0 0
m=audio 17614 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15 a=ptime:20
++++++++Now your provider sends an ACK without sdp+++++++++++ (for it to work they need to send an ACK with SDP)
Received:
ACK sip:2837555@10.196.106.122:5060 SIP/2.0 Via: SIP/2.0/UDP 10.200.7.157:5060;
branch=z9hG4bKeljk7bluenjvkjibkvniyujjx
To: <2837555>;tag=2E4C4AD0-263D CSeq: 1
ACK Max-Forwards: 70 Content-Length: 0
+++Then your provider sends a bye+++++++++++
Received:
BYE sip:2837555@10.196.106.122:5060 SIP/2.0
Via: SIP/2.0/UDP 10.200.7.157:5060;branch=z9hG4bKxnknekbionkvbvoxbnkliiexc
CSeq: 2 BYE Max-Forwards: 70
Reason: Q.850;cause=41;text="temporary failure"
Content-Length: 0
+++The ccapi cause code helps us more++++
001281: Jun  2 08:49:51.877: //127822/C058B05B8462/CCAPI/cc_api_call_disconnected:
   Cause Value=96, Interface=0x8738CB14, Call Id=127822
Cause 96 means that a mandatory information element is missing..Now the question is what is the mandatory information your provider is expecting in the 200 answer that you didnt provide..and I think its this sip session attribute
a=sendrecv or a=sendonly
Now according to RFC 3264  An Offer/Answer Model Session Description Protocol , it stipulates that
If the offerer wishes to both send and   receive media with its peer, it MAY include an "a=sendrecv"
   attribute, or it MAY omit it, since sendrecv is the default
However I think Huwaei your sip provider still want to see a session attribute in your offer. Hence the reason for disconnecting the call.
My suggestion is to use early offer from the provider. That way they can send you their attributes and ccme can just ack that.
It is my experience with this provider that they always send a session atrribute even if its  (a=sendrecv) which is the default.
hi,
i am not sur that i get you
can you specify what to do to solve this issue.
hi
you mean i have to configure early-offer as below
Configuring Delayed-Offer to Early-Offer for SIP Audio Calls at the Global Level
To configure Delayed-Offer to Early-Offer for SIP Audio Calls at the global level, perform the steps in this section.
SUMMARY STEPS
1. enable
2. configure terminal
3. voice service voip
4. allow-connections sip
5. early-offer forced
6. exit
Yes try that and test again...send the debugs again after you have configured this.
hi, i tried to add the commands but it doesnt support
Try to create voice class sip-profile. Add the missing header in your 200 OK response and test.
voice class sip-profile 1
Response 200 sdp-header attribute add "sendrecv"
Then assign this profile to your matched dialpeer.
Baqari
Hi Baqari,
i tried adding the profile, but the call is not going to autoattend, but it keeps on ringing, if i remove the command from the dial peer, the specific number is not working but other nos are going to the auto attend.
Please share the debig after adding the command
                 hi
debug as requested
Can you please add this..
Response 200 sdp-header attribute add "a=sendrecv"
NB: That the previuos config didnt have a=sendrecv, so you provider was ignoring your 200 ok.
Ensure to apply the profile to the dial-peer going to your sip provider as you did before. Please test again and send debug ccsip messages
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Hi Edwin,
In fact its typo mistake I forgot to put "a=" while posting the SIP-Profile. Apologize for this. I can see the SDP header is added as "sendrecv" in your debugs without "a=".
I am pasting the new SIP-Profile with the correction.
response 200 sdp-header attribute add "a=sendrecv".
Try now and paste the result.
Thanks to aokanlawon for picking it up
  hi,
still the same, it keeps on ringing without going to the AA
