05-04-2008 08:05 PM - edited 03-15-2019 10:26 AM
Hi, i have a very weird issue. I am using FreeFTPd to backup a cisco callmanager 5.1(3) the system builds the archive succesfully but when it want to copy the archive to the repository the following error appear: ERROR: SFTP transfer failure, not enough disk space, Backup Completed...
I have a lot space on my machine to copy the archive so i don't know why this error appear, any ideas.
Thanks in advanced,
Pepe
Solved! Go to Solution.
02-03-2012 02:41 PM
There are lots of potential problems, here, but in general:
1) Set up your SFTP server
2) Test it with a SFTP client, such as WinSCP,.from local machine and then another machine. If you can't connect with that, investigate - firewalls, routing, FreeFTPD logs etc.
3) Once working do it from CUCM. If it fails, check the FreeFTPD server logs again.
If in doubt, post up your server logs and a screen grab of your SFTP config. If there's no data in the logs, check routing and any security measures...
Aaron
02-03-2012 03:38 PM
Please find the SFTP logs and config. I tried to connect the sftp server via cmd prompt and I can able to login. and I tried with CUCM its throwing the same error.
There is no firewall between CUCM and SFTP both are in same rack and same switch. I even turned off the windows firewall.
Karthik
02-03-2012 03:43 PM
I have attached the CM config also.
- Karthik
02-03-2012 03:56 PM
Hi Karthik,
Only 1 \ is needed.
