callmanager 6 and callmanger 4 cluster
rahil khan
Beginner
Beginner
Dear All,
Is it possible to configure callmanger 4 as subscriber and callmanager 6 as publisher in the cluster? If it is then how we can do this?
regards,
RAHIL
1 ACCEPTED SOLUTION
acampbell
Advocate
Advocate
Rahil,
NO - definitely NOT
All servers in the cluster must be on the EXACT same versions
You can howver connect between different versions of clusters by using INTER-CLUSTER TRUNKS.
Alex
Regards, Alex. Please rate useful posts.
4 REPLIES 4
acampbell
Advocate
Advocate
Rahil,
NO - definitely NOT
Alex
Thnx campbell. I was in confusion at that moment and was trying to integrate both cucm6 and 4 in cluster but logs were showing that cucm 4 which was to be made as subscriber was able to resolve the ip but wasn't able to \\cucm6\c$.
regards,
RAHIL
one thing more, can we have more than one publisher in the cluster of ifferent versions
One CLuster can only have one Pub.
Tapan
