08-04-2011 04:48 AM - edited 03-16-2019 06:18 AM
If a user’s SAM-Account-Name is changed in Active Directory Users and Computers (System-Id-Guid would not change) will CallManager LDAP Sync pick this up and change their userid in End Users?
The user changed from c985jra to c156jra and I think in AD they just renamed him (not sure), however in CallManager End Users he shows Active with the old c985jra. He was changed in AD 2 months ago and logs into his PC with the new user id.
08-04-2011 04:50 AM
I think it will not , i have the same problem , maybe someone else figured it out , i had to remove the user from the AD then re-create the user after 3 days , i know that there is a way to force the inactive users to be removed from end users.
Amer
08-04-2011 06:33 AM
Wow, I think that is a bug! I just re-created on my CUCM. In Unity Connection I am integrated with Active Directory and the User ID updates in Unity Connection when it is change in AD. But in CUCM 8.0(3), with the exact same LDAP integration setup, the user ID is not updating. That is not good.
08-04-2011 08:20 AM
I have this working properly on both 7.1.5.33900-10 and 8.0.3.20000-2 for me. If I update the proper feild on my AD server for sAMAccountName, then do an LDAP directory sync, the userID which is mapped to sAMAccountName in CallManager does update. The user does not become inactive and an extra user is not created, the existing user that was updated in AD is updated to reflect the new UserID which is their new sAMAccountName.
08-04-2011 09:41 AM
OK, I just did a manual sync on my cluster and now the userid changed. For some reason the periodic sync (which show completed in the syslogs) were not updating that field.
