AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
627
Highlighted
Beginner
Callmanager cluster backup question ?
Hi all
I have installed two callmanager on vmware , all phone register to subscrber ,publisher is standby . then i create new cipc callmanger group device pool date/time group  and make a testing for callmanager backup, restart subscriber  but the phone can not register to publisher and i haven't sow cm2 is standby in device configuration on cipc. what question or incorrect  config in callmanager ?
The callmanager release 7.1.5  and using demo license
cluster is ok between callmanager
device pool is configred applied on phones
date/time group configred
location and phsical localtion is ok
any one encountered similar problems ?
thx
harvey
4 REPLIES 4
Verify that:
1) You have activated the CallManager service in 'Service Activation' on the publisher and the subscriber.
2) You have configured a CallManager Group that contains the subscriber, then the publisher. Assign this CallManager group to the device pool you are using.
3) If you are using names for the servers (in System/Servers in CCMAdmin), then ensure that the names are resolvable via DNS by the phones. Better yet, change the names (in System/Servers) to IP addresses and reset all the phones.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Beginner
Re: Callmanager cluster backup question ?
Hi Thanks and I resolved question.
No Dns server on network for cucm and I changed hostname to ip address .
Yun Zhang
Network Engineer
Logicalis Shanghai Ltd
7x24 800 819 7779
t +86 21 6163 9051*616
f +86 21 6163 9080
m +86 1376 1440 399
<> www.ap.logicalis.com
A Logicalis Group Company
Technology and business working together as one.
Hall of Fame Cisco Employee
Do you see the 2 servers under the device config in the CIPC???
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Beginner
Yes
Yun Zhang
Network Engineer
7x24 800 819 7779
f +86 21 6163 9080
m +86 1376 1440 399
Content for Community-Ad
August's Community Spotlight Awards
