08-22-2011 09:14 AM - edited 03-16-2019 06:36 AM
Hi there,
I'm trying to get calls forwarded to voice mail ISM0/0 and calls are dropped.
Normally this ip phones receive calls with g729a from H.323 signaling, i configured a forward no answer to voice mail. When the call is not answered it tries to forward to voice mail with SIP signaling, but the call fails (i believe that transcoding is not coming up with the interworking). I have interworking configured and transcoding - i will post the config.
If i put an incoming dial-peer (dial-peer 7 voip) with g711ulaw to that E.164 phone number (to get calls forwarded to voice mail but with the codec g711ulaw from the PSTN) calls enter voice mail with sucess. But if i take out that dial-peer that call fails, as i previously described.
P.S. - i configured two type of transcoding for testing and both do normal transcoding.. as you can see below
#sh sccp connections
sess_id conn_id stype mode codec sport rport ripaddr
7 8 xcode sendrecv g729 32636 2000 134.134.134.88
7 7 xcode sendrecv g711u 16386 2000 134.134.134.88
Total number of active session(s) 1, and connection(s) 2
Thanks everybody!
voice call carriercapacity active
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sccp local Loopback0
sccp ccm 134.134.134.88 identifier 2 version 7.0
sccp ip precedence 4
sccp
sccp ccm group 2
bind interface Loopback0
associate ccm 2 priority 1
associate profile 23 register CCME_TRX2
associate profile 21 register CCME_TRX
associate profile 22 register CCME_CFB
keepalive retries 2
switchover method immediate
switchback method graceful
switchback interval 5
signaling dscp af41
dspfarm profile 21 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 3
associate application SCCP
shutdown
dspfarm profile 23 transcode universal
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 1
dspfarm profile 22 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
shutdown
dial-peer voice 1 voip
description Outgoing Public Gateway
translation-profile outgoing to_pstn
destination-pattern 0T
session target ras
voice-class codec 1
dtmf-relay h245-signal h245-alphanumeric
ip qos dscp af41 signaling
no vad
dial-peer voice 2 voip
description TO_CCME_PHONES
translation-profile incoming inbound
incoming called-number 21004282.
voice-class codec 1
no vad
dial-peer voice 5 voip
destination-pattern 1...
session protocol sipv2
session target ipv4:134.134.134.85
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 6 voip
description SIP dial peer to Cisco Unity Express
destination-pattern 21004282.
codec g711ulaw
no vad
dial-peer voice 7 voip
description VOICE MAIL INCOMING
shutdown
no modem passthrough
incoming called-number 210042822
codec g711ulaw
no vad
telephony-service
sdspfarm conference mute-on 123 mute-off 321
sdspfarm units 3
sdspfarm transcode sessions 4
sdspfarm tag 1 CCME_CFB
sdspfarm tag 2 CCME_TRX
sdspfarm tag 3 CCME_TRX2
conference hardware
max-ephones 10
max-dn 100
ip source-address 134.134.134.88 port 2000 strict-match
calling-number local
timeouts interdigit 4
system message CCME 7.1 IOS 15.0
url services [http://134.134.134.85/voiceview/common/login.do | http://134.134.134.85/voiceview/common/login.do]
url authentication [http://134.134.134.88/CCMCIP/authenticate.asp | http://134.134.134.88/CCMCIP/authenticate.asp]
cnf-file location flash:
cnf-file perphone
user-locale PT
network-locale PT
load 7921 CP7921G-1.2.1.LOADS
load 7941 SCCP41.8-4-2S
time-format 24
date-format dd-mm-yy
voicemail 1020
max-conferences 4 gain -6
call-forward pattern 0.........
call-forward pattern ....
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 0.........
transfer-pattern ....
secondary-dialtone 0
create cnf-files version-stamp Jan 01 2002 00:00:00
08-22-2011 09:43 AM
From your config I can see:-
telephony-service
voicemail 1020
That means you should have a SIP dial peer pointing to the VMAIL
dial-peer voice 1020 voip
destination-pattern 1020
voice-class codec 1
session target ipv4:YOUR VMAIL IP ADD
no vad
Alex
08-22-2011 10:02 AM
Actually, he has that covered using dial-peer voice 5 voip.
Dial-peer 6 though sure has me scratching my head. Not sure what that one is for.
Try this:
Get rid of this DSPFarm profile all together:
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 3
shutdown
Modify this one as follows:
codec g711ulaw
codec g711alaw
codec g729r8 <= all other codecs removed
maximum sessions 4
I will say that normally you don't need to do this. I'm not sure why you are needing to. You should be able to get this to work without having any transcode resources configured PROVIDED all the calls are coming in from the PSTN, and not coming in as G729 over the WAN.
Cliff
Please rate helpful posts
08-22-2011 11:14 AM
Hi there,
The calls are coming from PSTN with g729 codec and failing. Only when i activate dial-peer 7 the calls are successful because all legs are g711ulaw and no transcoding is needed.
Dino
08-22-2011 11:29 AM
Have you done a debug on the dial-peers to determine which dial-peers are getting engaged during setup? I'm wondering if you're hitting the default dial peer, which will NOT negotiate codec.
08-23-2011 03:31 AM
Hi there, the call is coming in through dial-peer 2,
Calling Number=300504602,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Called Number=210042822(TON=National, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=2, Progress Indication=NULL(0), Calling IE Present=TRUE,
Dino
08-31-2011 07:30 AM
Hi there,
Anyone has any ideas?
Dino
