Callmanager Express 9.1 - IP Phone 9971 and 7962 with 02 hours early
wilsonsant
Level 6
Level 6
Hi Guys,
My Customer have a CallManager Express 9.1 and in the last weekend in any states about Brazil started the summer time. After this, the IP Phones model 9971 and 7962 is showing the time with 02 hours early. Any have idea to correct this problem?
Wilson
7 Replies 7
Shahzad Ayub
Hi Wilson,
If you are 3 hours behind GMT then run this command in config mode on your router
clock timezone GMT -3 0
or just set the router time with following command in enable mode
clock set hh:mm:ss
Then don't forget to create cnf files under telephony service and create profile under voice register global.
Shahzad
please rate helpful posts
Hi Shahzad,
The configuration already this way:
clock timezone BR -3 0
clock summer-time BRV recurring 3 Sun Oct 0:00 3 Sun Feb 0:00
clock set it´s Ok too.
Wilson
Does your router time matches with ip phone?
Shahzad
Hi Shahzad,
The Customer have another IP Phone models, and it´s are with correct time
Wilson
You already configured daylight saving time to apply it automatically, If you live in a place where summer time does not follow the pattern, you can specify the exact date and times. In the following example, daylight saving time (summer time) is configured to start on April 01, 2015 at 2 a.m., and end on October 01, 2015 at 2 a.m
Router(config)#clock summer-time date 01 April 2015 2:00 01 October 2015 2:00
Shahzad
Hi Shahzad,
As told for You another models are worked without problem
Wilson
Did you try reset those two ip phones?
Shahzad
