Callmanager Express MOH for Internal SCCP to SCCP Calls not working
faiqmahdi
Beginner
Beginner
I am having issue with Music on Hold for Internal Calls.
Music on Hold works for SIP to SCCP and SCCP to SIP
But It does not work SCCP to SCCP
Here are the details of CUCME:
interface GigabitEthernet0/0
 ip address 10.20.30.2 255.255.255.0
 ip pim dense-mode
 duplex auto
 speed auto
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.20.30.2
Router#sh ip multicast
  Multicast Routing: enabled
  Multicast Multipath: disabled
  Multicast Route limit: No limit
  Multicast Fallback group mode: Dense
  Number of multicast boundaries configured with filter-autorp option: 0
  MoFRR: Disabled
ccm-manager music-on-hold
ROUTER#dir
Directory of flash0:/
    1  drw-           0  Apr 14 2016 17:18:34 +03:00  its
   77  -rw-      496521  Apr 20 2016 14:08:38 +03:00  music-on-hold.au
   83  -rw-   109748168  Jan 20 2016 15:56:20 +03:00  c2951-universalk9-mz.SPA.156-1.T0a.bin
ROUTER#show voice moh-group
telephony-service
 internal-call moh-group 0
 G.711 Music-on-Hold file: moh enable-g711 "flash0:music-on-hold.au"
 moh-file-buffer (not configured, default size 64 Kb)
 Moh multicast 239.1.1.5 port 16384 route 10.20.30.2
=== no voice moh-groups configured ===
ROUTER#show ephone moh
Skinny Music-on-Hold Process ID is 120.
Skinny Music On Hold Status - group 0
 Active MOH clients 0 (max 1300), Media Clients 0, B-ACD Clients 0
 File flash0:music-on-hold.au (not cached) type AU Media_Payload_G711Ulaw64k 160 bytes
G.729 Music-on-Hold File Status
 No MOH file loaded
Router#sh telephony
CONFIG (Version=11.0)
Version 11.0
ip source-address 10.20.30.2 port 2000
cnf-file location: flash:
cnf-file option: PER-PHONE
phone service webAccess 0
phone service displayOnWhenIncomingCall 1
phone service phoneBookWebAccess 1
mwi relay
multicast moh 239.1.1.5 port 16384 route 10.20.30.2
Router#
Debugs:
Hold from SIP (9001) to SCCP (9000)à Working
Router#
000764: Apr 20 18:44:06.957 KSA: SkinnyAddMediaMohClient: MOH re-Negotiation is NOT needed, start Association
000765: Apr 20 18:44:06.957 KSA: Added callID 46 to MOH in position 0 with 1 clients
000766: Apr 20 18:44:06.961 KSA: skinnyMohHandleCCEvent:889: receive CC_EV_CALL_ASSOCIATED, calllID=46
000767: Apr 20 18:44:06.961 KSA: skinnyMohHandleCCEvent:924: find media_play_client
000768: Apr 20 18:44:06.961 KSA:        media_play_client:
000769: Apr 20 18:44:06.961 KSA:                media_play_client->callID=46
000770: Apr 20 18:44:06.961 KSA:                media_play_client->context=0x0x22EB59C
000771: Apr 20 18:44:06.961 KSA:                media_play_client->stream_id=1
000772: Apr 20 18:44:06.961 KSA:                media_play_client->xmitFunc=0x0x0
000773: Apr 20 18:44:06.961 KSA:                media_play_client->spi_context=0x0x0
000774: Apr 20 18:44:06.961 KSA:                media_play_client->streamCallID=50
000775: Apr 20 18:44:06.961 KSA:                media_play_client->codec=5
000776: Apr 20 18:44:06.961 KSA:                media_play_client->xcodeXmitFunc=0x0
000777: Apr 20 18:44:06.961 KSA:                media_play_client->xcodeNeeded=FALSE
000778: Apr 20 18:44:06.961 KSA:                media_play_client->nego_codec= voipCodecG711ulaw
000779: Apr 20 18:44:06.961 KSA:                media_play_client->srcXcodeStreamID=-1
000780: Apr 20 18:44:06.961 KSA:                media_play_client->dstXcodeStreamID=-1
000781: Apr 20 18:44:06.961 KSA: skinnyMohHandleCCEvent:1012:Call ID 46 associated, disposition[0], pVdb[18C478C8], playFunc[966AABC], spi_context[13A26AB8]
000782: Apr 20 18:44:06.961 KSA:        media_play_client:
000783: Apr 20 18:44:06.961 KSA:                media_play_client->callID=46
000784: Apr 20 18:44:06.961 KSA:                media_play_client->context=0x0x22EB59C
000785: Apr 20 18:44:06.961 KSA:                media_play_client->stream_id=1
000786: Apr 20 18:44:06.961 KSA:                media_play_client->xmitFunc=0x0x0
000787: Apr 20 18:44:06.961 KSA:                media_play_client->spi_context=0x0x0
000788: Apr 20 18:44:06.961 KSA:                media_play_client->streamCallID=50
000789: Apr 20 18:44:06.961 KSA:                media_play_client->codec=5
000790: Apr 20 18:44:06.961 KSA:                media_play_client->xcodeXmitFunc=0x0
000791: Apr 20 18:44:06.961 KSA:                media_play_client->xcodeNeeded=FALSE
000792: Apr 20 18:44:06.961 KSA:                media_play_client->nego_codec= voipCodecG711ulaw
000793: Apr 20 18:44:06.961 KSA:                media_play_client->srcXcodeStreamID=-1
000794: Apr 20 18:44:06.961 KSA:                media_play_client->dstXcodeStreamID=-1
000795: Apr 20 18:44:06.961 KSA: skinnyMohHandleCCEvent:1025: the existing call xcode info:: Dst[46,0]
000796: Apr 20 18:44:06.961 KSA: skinnyMohHandleCCEvent:1058: xcode NOT involves, codec is: voipCodecG711ulaw, nego_codec is:voipCodecG711ulaw
000797: Apr 20 18:44:06.961 KSA: skinnyMohHandleCCEvent:1230: ERROR: media_play_client->callID[46] has NO gccb
000798: Apr 20 18:44:06.961 KSA:        media_play_client:
000799: Apr 20 18:44:06.961 KSA:                media_play_client->callID=46
000800: Apr 20 18:44:06.961 KSA:                media_play_client->context=0x0x22EB59C
000801: Apr 20 18:44:06.961 KSA:                media_play_client->stream_id=1
000802: Apr 20 18:44:06.961 KSA:                media_play_client->xmitFunc=0x0x966AABC
000803: Apr 20 18:44:06.961 KSA:                media_play_client->spi_context=0x0x13A26AB8
Router#
000804: Apr 20 18:44:06.961 KSA:                media_play_client->streamCallID=50
000805: Apr 20 18:44:06.961 KSA:                media_play_client->codec=5
000806: Apr 20 18:44:06.961 KSA:                media_play_client->xcodeXmitFunc=0x0
000807: Apr 20 18:44:06.961 KSA:                media_play_client->xcodeNeeded=FALSE
000808: Apr 20 18:44:06.961 KSA:                media_play_client->nego_codec= voipCodecG711ulaw
000809: Apr 20 18:44:06.961 KSA:                media_play_client->srcXcodeStreamID=-1
000810: Apr 20 18:44:06.961 KSA:                media_play_client->dstXcodeStreamID=-1
Router#
Router#
Router#
000811: Apr 20 18:44:08.929 KSA: ifs_read flash0:music-on-hold.au end of file at 490108 read 6413 = 496521
000812: Apr 20 18:44:08.933 KSA: moh-group 0: Tail fill from 24 at 0x444371A1 length 1587
Router#
Router#
Router#
000813: Apr 20 18:44:15.509 KSA: skinnyMohMediaClientCleanUp:128: Info: media_play_client->callID[46] has NO gccb
000814: Apr 20 18:44:15.509 KSA: skinnyMohMediaClientCleanUp:146: the existing call has xcode involved: stream3[0]
000815: Apr 20 18:44:15.509 KSA: MOH repack CallID 46 from position 0 to 0 (0 active)
000816: Apr 20 18:44:15.509 KSA: Removed callID 46 from MOH 0 clients at position 0
Router#
Router#
Hold from SCCP (9000) to SIP (9001) à Working
Router#
000820: Apr 20 18:45:34.473 KSA: skinny_find_mohgroup_by_dn: dn=100, chan=1, callState=9(HOLD), peer_dn=-1
000821: Apr 20 18:45:34.473 KSA: skinny_find_mohgroup_by_dn: external peer put on hold by DN(100),  or hold ended
000822: Apr 20 18:45:34.473 KSA: skinny_match_mohgroup_by_dn_ext: ephone_dn_template->moh_group=0
000823: Apr 20 18:45:34.473 KSA: skinny_match_mohgroup_by_dn_ext: dn=100, chan=1, holder callState=9(HOLD)
000824: Apr 20 18:45:34.473 KSA: *** dn_index=100, incoming=1, dn_ext='9000', called#='9000', calling#='9001'
000825: Apr 20 18:45:34.473 KSA: Added DN 100 chan 1 to MOH-group 0 in position 0 with 1 clients
Router#
Router#
Router#
Router#
Router#
Router#
000826: Apr 20 18:45:36.737 KSA: DN 100 chan 1 switching to MOH process at 57412 (was 57410) timestamp_offset 0
Router#
Router#
Router#
Router#
Router#
000827: Apr 20 18:45:43.077 KSA: SkinnyDeleteMohClientDn: dn=100, chan=1
000828: Apr 20 18:45:43.077 KSA: skinny_get_moh_entry_from_dn: retrieving moh_group 0 from skinnyDP[100]
000829: Apr 20 18:45:43.077 KSA: MOH repack DN 100 from position 0 to 0 (0 active)
000830: Apr 20 18:45:43.077 KSA: Removed DN 100 from MOH-group 0 at position 0, 0 clients remained
Router#
Router#
Router#
Router#
Debugs:
Not Working:
Hold from SCCP (9000) to SCCP (9004) à Not Working
Router#
000840: Apr 20 18:48:58.151 KSA: ephone_hold_resume ignored for s2s set on dn=100 chan=1 hold=1 callID=56
000841: Apr 20 18:48:58.155 KSA: skinny_find_mohgroup_by_dn: dn=100, chan=1, callState=9(HOLD), peer_dn=4
000842: Apr 20 18:48:58.155 KSA: skinny_find_mohgroup_by_dn: internal peer_dn(4) put on hold by DN(100)
000843: Apr 20 18:48:58.155 KSA: skinny_find_mohgroup_by_dn: internal-call rule applies, use moh-group 0
000844: Apr 20 18:48:58.155 KSA: McastMoh is Available for moh-group 0
000845: Apr 20 18:48:58.155 KSA: SkinnyGetMohMulticastInfo: dn=4, chan=1, peer_dn=100, peer_chan=1, dn callState=4(CONNECTED), peer_dn callState=9(HOLD)
Router#
Router#
Router#
Router#internal-call rule applies, use moh-group 0
Router#
Router#
Router#
Router#
Router#
Router#
Router#
000846: Apr 20 18:49:08.432 KSA: SkinnyDeleteMohClientDn: dn=100, chan=1
000847: Apr 20 18:49:08.432 KSA: skinny_find_mohgroup_by_dn: dn=100, chan=1, callState=0(IDLE), peer_dn=4
000848: Apr 20 18:49:08.432 KSA: skinny_match_mohgroup_by_dn_ext: ephone_dn_template->moh_group=0
000849: Apr 20 18:49:08.432 KSA: skinny_match_mohgroup_by_dn_ext: dn=4, chan=1, holder callState=4(CONNECTED)
000850: Apr 20 18:49:08.432 KSA: *** dn_index=4, incoming=0, dn_ext='9004', called#='9000', calling#='9004'
000851: Apr 20 18:49:08.436 KSA: No MOH entry for DN 100 in moh-group 0
Router#
Router#
Router#
000852: Apr 20 18:49:10.548 KSA: MoH route If GigabitEthernet0/0 ETHERNET 10.20.30.2 via ARP
Router#
Router#
Router#
Router#
0 REPLIES 0
