CallManager Service Parameter - Maximum Number of Registered Device
bkresnanto
I'm looking at CallManager Service Parameter (publisher box) and noticed that the "Maximum Number of Registered Device" default is 5000 max 15,000.
Anyone know if this is maximum number for each server or enterprise wide?
CallManager 4.1(3)
1 Publisher
3 Subscriber (local)
3 Subscriber (remote)
Thanks in advance!!!
Chris Deren
This is maximum number per server. The marketing advertisement for cluster is 30,000.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/index.html
HTH, please rate all posts!
Chris
5 Replies 5
Chris Deren
Chris
Hi Where can you check this setting at ?
Go to Service Parameters --> any server --> Service Cisco CallManager
under system section you will see "Maximum Number of Registered Devices Required Field"
Chris
Thank you
You're welcome, please rate all helpful posts!
Chris
